It wasn’t documented very well in the post, but you need a separate FAT32 USB stick with a volume name of CONFIG, and the resin-sample file in a “/network/” directory.
Took me a while to figure it out last night, but working fine now.
I don’t know about running slower but I am pretty sure it starts slower.
It was bad enough before but several minutes to restart when making changes to my config is putting me off wanting to change/add/enhance anything!
Hi, guys. I installed a new HassOS on my Raspberry Pi 3B+ and I am a little confused: How should I connect like Pi user now for installing some new features or configurations? e.g. I need to install LIRC, configure CloudMQTT bridge, configure raspi-config, setting up platform rpi_rf, etc. Thanks in advance for yours advices.
It actually appears that the correct method (and other updates regarding this new version) got pushed to the Getting Started page already: https://www.home-assistant.io/getting-started/
I have been running hass.io on a rpi3B+ with Raspbian Stretch. Webmin and Node-Red are also running.
Conversion to HassOS worked as advertised except that four of thirteen add-ons were not installed. They are all from third parties. One is a local modification found in the Addon directory. Not difficult to fix if you have local backups of the other available Samba directories (share, addon, config, ssl) in addition to backup.
But, the HassOS version seems slower to (re)start than the Raspbian version. So I timed them. The HassOS version consistently takes 4 minutes and 24 seconds to present the UI upon restart. The Raspbian version is ready in 2 minutes and 26 seconds. No errors in either log. Have repeated these results many times.
