New install - Login attempt or request with invalid authentication from 172.30.32.2 supervisor.auth
I did a new install via the supervisor method on a Pi. The HA ui shows continously
“Login attempt or request with invalid authentication from 172.30.32.2”
the IP belongs to container homeassistant/armv7-hassio-supervisor.
ha su logs shows
20-04-21 13:52:16 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-04-21 13:53:49 INFO (MainThread) [supervisor.auth] Auth request from core_mosquitto for DVES_USER
20-04-21 13:53:49 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-04-21 13:53:51 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-04-21 13:53:52 ERROR (MainThread) [supervisor.auth] Can't request auth on Home Assistant
How can I fix this issue?
core version: “217”
su version: 0.108.6
Thanks, Andre
I also just installed on a Pi and am getting this. Have you got any further in working it out?
Haha I just worked it out. I’ve got some ESP based devices running Tasmota firmware. It seems the default MQTT username they use is DVES_USER. These devices happened to be pointing to Homeassistant as it had the same IP as my previous MQTT server.
I just configured homeassistant MQTT server to accept this user:
logins:
  - username: DVES_USER
    password: password
anonymous: true
customize:
  active: false
  folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
Yes, indeed. My MQTT is also the same and I did not create setup the user.
Now that’s all explainable :slight_smile:
Hello, one more question about this.
This user is one that you have created for that purpose (with Admin privileges), is the general HA admin user or is another?
Thanks.
I created the user just inside the Mosquitto broker config. This means DVES_USER can only log in to MQTT, and not the HA interface.
Hi
I am new to HA , i too had to install MQTT , I already had a sensor working thru MQTT on Core -Mosquitto. Now i have an error within the logs regarding MQTT . I see that you have added the Tasmota devices with its own login in MQTT. Can i ask did you setup the new login for this device in the configuratioin yaml . Any advise would be appreciated.
I have the same question as this one? Can someone please help for this?
try it here
<HA_IP>:<HA_port>/hassio/addon/core_mosquitto/config
