Just created brand new home assistant install and I am trying to get the HACS integration working. I have created the custom_components folder (via SAMBA and SSH) and then copied HACS folder over. Restarted HA (and even VM) but when trying to add the HACS integration after restart, it does still not appear in the search results.
Any ideas? Home Assistant 0.116.4 running on Virtualbox Ubuntu 64-bit
Iām having the exact same issue. Iām running Home Assistant 0.116.4 in Docker. Iāve been able to get all the other integrations that I have tried working without a problem, but Iāve spent the last two hours on this so far.
I can see that Home Assistant sees HACS from the log, since I get the following message every time Home Assistant starts:
Logger: homeassistant.loader
Source: loader.py:440
First occurred: 4:06:58 PM (1 occurrences)
Last logged: 4:06:58 PM
You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
So far, HACS has not shown up in Integrations, even after clearing my browsers cache multiple times and restarting HA and the docker container. I am unable to get the point of adding my GitHub token. Any help would be greatly appreciated.
Alright, I was able to get it to work after I manually configured it with YAML. For whatever reason, the non-legacy method never worked for my install. Up until this point, I have been able to use all of the standard methods of setting up Home Assistant so I donāt know what could be the cause of this. If there is anything that more experienced users would like to see to troubleshoot this further, please let me know. Iād be happy to help.
I am seeing the same problem. Log shows āYou are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistantā
I just added my personal token from GitHub on the token line and then specified by country with its two-character code on the country line. After restarting Home Assistant, everything worked as it should.
I checked that the hacs directory was installed in the custom_components directory, and that the files were there and restarted using the RESTART Option under the Hardware menu/Restart HomeAssistant, but when trying to add the integration, hacs was not found.
I then deleted the directory and repeated the process, but this time I rebooted the Pi both after deleting the hcas directory and after readding it, but when it came back the hacs was still not found. I have reviewed the logs and there is no indication that the integration is seen.
I then ran the process by deleting the hacs directory again and using direct wget of the hacs.zip file from the ssh command and then unpacking to the directory, and deleting the zip file. This time i did a full shutdown of the Pi and rebooted from cold.
in all cases I have used a different browser, cleared the cache and the hacs is not found.
The most recent attempt I added the bit of code from general_tux in the configuration.yaml, and did a Restart from Developer Tools. but I received this message
āThe system cannot restart because the configuration is not valid: Integration error: hacs - Integration āhacsā not foundā
I am using the standard SSH/Terminal Addon, but have gone through the proccess several times by using the SSH from my Mac with the same results.
I checked and the filetree looks like
/config
/config/custom_components
/config/custom_components/hacs
Is there anything else I need to do? Any other fixes that may cause the hacs integration to be found?
