The two files (climate.py, init.py) have to be in the directory
custom_components/netatmo
Ok that in place - but whats in the climate folder then. I why am I getting a ThermostatData:-error
The climate folder has to be deleted.
How does your config look like?
Please try to add the following lines in your configuration.yaml
and restart HA. After restarting, please find the DEBUG messages in your log files and send to me by PM (or post here after removing privacy information).
logger:
logs:
custom_components.netatmo: debug
custom_components.climate.netatmo: debug
h4nc is correct, we need your configuration information to diagnose the issue.
hello, what is the card to add this custom components in ui-lovelace.yaml?
configuration.yaml
also, please.
Can you find a entity with this name in your HA? Mine is like:
- entity: climate.netatmo_bedroom
type: thermostat
configuration.yaml
climate:
platform: netatmo
home: Casa Matteo
rooms:
- Cucina
- Camera da letto
- Cameretta
- Salone
This is an outdated configuration format, as indicated in New Netatmo climate component supporting multiple thermostats/valves, you should use:
climate:
platform: netatmo
homes:
- name: Casa Matteo
rooms:
- Cucina
- Salone
The other two rooms also have thermostat/valve? Or just cameras? If no thermostat or valve, you should not include them.
all the rooms have valve
@matteos1 if you post code please use the correct format in future, as this makes it better readable.
You can try it at one of your posts above.
all done for formatting post
I’m very grateful that you will help. I will post the information as soon as I get back from a business trip later this week.
[quote=“matteos1, post:57, topic:91860, full:true”]
configuration.yaml
climate:
platform: netatmo
homes:
- name: Casa Matteo
rooms:
- Cucina
- Camera da letto
- Cameretta
- Salone
and with:
ui-lovelace.yaml
title: Temperatura
icon: mdi:thermometer-lines
cards:
- type: thermostat
entity:
- climate.netatmo_Cucina
- climate.netatmo_Camera da letto
- climate.netatmo_Cameretta
- climate.netatmo_Salone
but give this error
entity not found
here the configuration
This is not a valid entity name.
what is the correct entity name of thermostat?
entities do not have spaces.
Look in the devtools for the right entity name and copy it in your config.
Probably you will have to replace the spaces by underlines _ .
But better have a look in the devtools for the right entity name.
Have a look in the dev tools section.
