after the upgrade to 2021.5.0 I have proble to integrate Netatmo thermostat, the new version of integration seems to not properly work: I see a lot of entities but not mine!
thaks for yior help
A fix will land in 2021.5.1
Looks like in version 2021.5.1 battery_level attribute is still missing
It has never been reliable as far as Iām aware. Nothing I have changed. Iāll put it on the list.
For me worked like a charm for the past 18 months. Thanks for adding to the queue
Thank you, mostly working for me to!
But yes, all of a sudden the ābattery_levelā and the āselected_scheduleā attributes have disappeared now.
Not major, would be nice to get them back for Lovelace viewing.
Actually it appears there is a problem with service call - netatmo.set_schedule.
Said Goodnight to my house in the UK and heating schedule did not change. Soooo not quite back where we were.
NN!
It was a quick fix. Iāll take a look at the other issues.
Thank you Tobi.
After the installation of the new release (2021.5.1) everything is ok: thaks!
bye
I havenāt really investigated it much, but battery will be fixed soon and the schedule probably too. Iāll keep you posted.
Iām running 5.1 and I still canāt reinstall the integration⦠
āThe component is not configured. Please see the documentation.ā
Battery and schedule is fixed locally. Just waiting for the upstream release.
Wonderful, Thank you!
Almost a Cloud strikes again!! Would be so nice if Netatmo Ble devices could operate locally.
Hiya,
I see the changes have been made in the latest Core and battery level is now available (showing simplified this time), however āselected_scheduleā attribute still is not available to switch different schedules.
Attribute available after 2021.5.4 update:
Thank you
Yes, because the upstream library has not yet issued a back port of the fix. If this wonāt happen before the release of 2021.6.0 it will be included there as it will ship with overhauled internals that contain a fir for that issue.
OK, Thank you for responding.
With version HA 2021.7.2
the battery level attribute is missing again. i am using netatmo integration.
Anyone finding on a HA Restart, the Netatmo integration will not load and all entities are unavailable?
After three reboots or so, things show up.
Can you please check your logs (debug level for Netatmo)?
