I know this is a fairly old thread… but is there any way to get “System Alerts” (that’s what shows in the SL app) data into home assistant?
What alerts are you specifically referring to?
There is already chemistry alarm and flow alarm binary_sensor
s as part of the basic integration. If you have an IntelliChem device, there are additional alarm binary_sensor
s that are created.
Hmm… I don’t have a flow alarm binary_sensor
created. The only binary_sensor
is for the Chemistry Alarm.
Sorry, you’re right. Flow alarm is part of IntelliChem’s reporting.
I couldn’t find any “System Alerts” in the mobile app. Were you referring to the desktop PC app?
Unfortunately I have the Android version of the app which doesn’t have that information.
If you provide me with specific alerts, I can see if they exist in the data I currently have access-to/decoded.
I’ll grab a screenshot next time I see it. Thanks!
But one I’ve seen is priming failure. And another I have is something about solar sensor missing. I know it’s not helpful without the exact messages.
I just switched from Hubitat to HA a week ago and I have to admit I’m so impressed with HA and the community and device support/integrations. With Hubitat I had to have a dedicated RPi with serial device and all sorts of custom scripts just to decode the Pentair info to be used in automations. My jaw dropped when it was just THERE in HA. I’m now learning all the ins and outs of HA and customizing my dashboard and looking at the Pentair data. Was anyone able to elaborate on the Chemistry Alarm? Like @Geoff_Blachstein mentioned, I don’t have the IntelliChem either and I see that show up in my list and it changes status as well. I am not sure what it is referring to.
Thank you so much for all the work put into this! I am thoroughly impressed!
The Chemistry Alarm is really more of a general system alert. In other projects/implementations of decoding the data returned from the ScreenLogic gateway, it was described as a chemistry alarm so that’s the name that data was initially mapped to, but it seems as if that’s not really all it’s limited to.
At some point after a little more testing, I’ll likely rename that sensor.
I am looking to control the pentair intellipool controller (Belgium) to start filtration by MQTT … would this integration help?
No. This integration is specific to the ScreenLogic system’s custom protocol.
Hello, i’m new here and already learned a lot from this forum. I have a poolautamation of Pentair called Intellipool. It looks a lot like the pentair integration but i can’t get it working for Intellipool. Is there someone who knows what i have to do to use the intellipool with Home Assistant? The main things that i want to do is read out the temperature of the pool and the Ph and redox. It would be nice if i could control my poolpump (intelliflo) also. These things can now be mannaged with the app of intellipool but i would like to integrate it in my home assistant.
As an enhancement, can you please add the ability to control the pump speed itself? My use case is when the filter gets clogged up over time the water flow slows down and eventually the SWG chlorine generator will stop generating chlorine when it reaches the speed that is too low to activate it. I need the ability to monitor this issue (which I can do already) and turn up the speed when this situation is detected. I had this happen when I was on a 1 month vacation and I had to run my pump on HIGH instead which really burned quite a bit of electricity. I’d like the ability to bump up the minimum speed via HA.
THank you for your considersation.
pool-controller.js (GitHub - tagyoureit/nodejs-poolController: An application to control pool equipment from various manufacturers.) is an application that connects in to a Pentair system directly via the RS485 bus, and gives you MUCH more detailed control; and visibility than the normal pentair integration does. This includes pump speed controls and a whole host of scheduling and other capabilities.
It’s also easily interfaced to HA via a HACS integration here: nodejs-PoolController Integration
I run it on a separate raspberry Pi that is close to the pool equipment, but I guess you could try and run it on the same computer you run HA on. It will be easier if its split out of course.
That should give you the level of control you are looking for.
I agree. Loaded it up due to some issues I am fighting on my system. Super easy and I run on same pc I run ha on. Ha is in vbox. Nodejs running natively. No issues at all.
And it backs up your config which is a big deal imo having programmed easytouch from scratch. Recreating that is tuff…
Only thing i’d say is get the recommended rs-485 adapter
The Pentair ScreenLogic integration is limited by the functionality available to the ScreenLogic apps. While those apps allow you to configure the pump speeds associated with a circuit or feature, it does not allow you to temporarily set an arbitrary speed.
In theory, one could continually configure the speed for the current circuit or feature, but that functionality appears to be achieved in the apps by setting the entire pool equipment configuration, just with updated flow/rpm values. That’s not something the integrations supports.
Your best bet for that level of control is what @fresnoboy suggests, where in that setup the commands are sent directly into the communication bus for the pool equipment, effectively acting as an official pool controller.
Yea that is exactly what I was thinking to do. I’ve been bumping the speeds up in the slconfig app for at the moment and was looking to emulate that.
The nodejs solution would work but its a hammer for a nail as I have everything I need in the built in integration which works great btw.
Thanks for the input/consideration anyway. I appreciate it.
There is supposedly an ScreenLogic request command labeled as Set Pump Flow, but it doesn’t appear that the apps make use of it so I don’t have anything to go off of as to it’s usage or parameters, or know if it’ll even do what it’s name describes.
As the intellipool (Europe) pentair stuff is not compatible (pitty, but probably very similar to since same equipment), maybe somebody can help us to get some valuable pointers in the right direction. I logged the rs485 communications between intellipool controller, whisperflo pump, chlorinator and heatpump.
Does this communication seem familiar/recognizable or can give some pointers on how to start understand this protocol? Help is very appreciated!
here is an abstract of comm:
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688725378604}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725421487}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725421502}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725471474}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725471493}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725521514}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725521545}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725571444}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725571476}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725621429}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725621447}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725671414}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725671438}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,241,253,255,253,197]}},"timestamp":1688725686406}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,241,225,235,237,251,253,153,124,49,229,255,255,255,255,217,159,249,141,255]}},"timestamp":1688725686439}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688725686516}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725721399}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725721431}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725771385}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725771402}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725821370}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725821393}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725871354}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725871385}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725921340}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725921356}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688725971323}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688725971347}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,241,253,255,253,197]}},"timestamp":1688725994312}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1]}},"timestamp":1688725994321}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,45,223,63,241,225,235,237,251,253,153,124,49,229,255,255,255,255,217,149,249,131,255]}},"timestamp":1688725994349}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688725994422}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726021306}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726021338}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726071291}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726071310}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726121274}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726121300}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[171,157,121,157,141,143,149,141,157,159,141,121,151,115,157,159,159,117,141,159,159,159,159,149,159,151,143,159,159,125,149,159,147,151,143,159,155,123,159,159,151,159,159,117,117,159,159,121,145,159,159,123,159,159,151,159,159,159,143,143,159,185,229,235,224]}},"timestamp":1688726147127}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726171261}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726171293}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145,1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726221264}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726271235}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726271255}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,241,253,255,253,197]}},"timestamp":1688726302222}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[8,1,45,223,63,241,225,235,237,251,253,153,124,49,229,255,255,255,255,217,137,249,119,255]}},"timestamp":1688726302259}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688726302331}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726321219}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726321247}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726371205}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726371238}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726421192}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726421209}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726471180}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726471201}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726521165}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726521191}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726571152}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726571184}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,241,253,255,253,197]}},"timestamp":1688726610136}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,241,225,235,237,251,253,149,124,49,229,255,255,255,255,215,247,249,223,255]}},"timestamp":1688726610169}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688726610246}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726621137}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726621155}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726671179}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726671206}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726721107}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726721138}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726771093}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726771109}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726821082}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726821100}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726871069}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726871092}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,241,253,255,253,197]}},"timestamp":1688726918053}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,241,225,235,237,251,253,149,124,49,229,255,255,255,255,215,237,249,213,255]}},"timestamp":1688726918098}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688726918161}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726921054}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726921084}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688726971041}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688726971075}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727021027}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727021046}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[171,157,121,157,141,143,149,141,157,145,155,117,147,115,157,159,159,117,121,159,159,159,159,149,159,151,143,159,159,125,119,159,147,153,115,159,155,123,159,159,151,159,159,115,159,159,159,121,145,159,159,123,159,159,151,159,159,159,141,159,115,185,229,235,224]}},"timestamp":1688727047489}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727071014}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727071046}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727121000}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727121018}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727170986}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727171009}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727220971}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727221000}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,241,253,255,253,197]}},"timestamp":1688727226466}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,241,225,235,237,251,253,153,124,49,229,255,255,255,255,215,227,249,207,255]}},"timestamp":1688727226498}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688727226575}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727270954}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727270972}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727320940}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727320963}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727370925}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727370955}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727420911}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727420946}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727470898}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727470917}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727520885}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727520909}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,241,253,255,253,197]}},"timestamp":1688727534378}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,241,225,235,237,251,253,153,124,49,229,255,255,255,255,215,217,249,197,255]}},"timestamp":1688727534428}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688727534488}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727570871}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727570900}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[183,95,255,255,59,223,249]}},"timestamp":1688727617754}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727620858}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727620891}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727670846}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727670862}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[181,150,117,141,143,149,141,157,125,123,153,151,115,121,159,155,159,155,143,159,159,159,159,157,153,159,159,155,157,119,159,159,159,159,159,159,159,159,125,119,159,159,159,159,115,159,159,159,117,121,159,159,155,159,159,159,159,147,143,145,185,229,235]}},"timestamp":1688727677894}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727720832}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727720855}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727770815}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727770846}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727820856}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727820877}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,241,253,255,253,197]}},"timestamp":1688727842290}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,241,225,235,237,251,253,153,124,49,229,255,255,255,255,215,207,249,187,255]}},"timestamp":1688727842339}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,31,223,27,235,223,127,255,255,255,255,255,255,255,251,155]}},"timestamp":1688727842400}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727870786}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727870808}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727920772}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727920800}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[171,157,121,157,141,143,149,141,157,141,125,151,159,115,157,159,159,117,117,159,159,159,159,149,159,151,145,159,159,123,155,159,147,153,145,159,155,123,159,159,151,159,159,115,155,159,159,121,145,159,159,123,159,159,151,159,159,159,143,141,157,185,229,235,224]}},"timestamp":1688727947852}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,253,247,251,119,124,177,145]}},"timestamp":1688727970758}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,241,95,127,8]}},"timestamp":1688727970791}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,63,223,253,247,251,119,190,203,235]}},"timestamp":1688727975757}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,253,251,243,183,127,143]}},"timestamp":1688727975779}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[181,150,117,141,143,149,141,157,141,119,125,115,115,123,155,145,153,155,123,143,159,123,119,159,159,145,125,151,159,147,125,151,159,147,151,159,159,147,119,159,159,145,119,159,159,145,119,159,159,145,123,143,159,123,117,149,159,123,153,159,185,229,235]}},"timestamp":1688727975908}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[0,1,45,63,223,241,253,255,253,197]}},"timestamp":1688727977753}]}
{"precision":"ms","data":[{"measurement":"rs485Measurement","tags":{"type":"pentair_rs485"},"fields":{"message":{"type":"Buffer","data":[1,1,45,223,63,241,225,235,237,251,253,219,243,183,174,239,255,255,255,215,203,251,103,255]}},"timestamp":1688727977789}]}
