I was thinking this: it’s called “BTicino Living Now with NETATMO”.
Maybe that means that the Netatmo HA component can control those devices. I’m unable to understand if this new BTicino series use Netatmo software, and that might mean that it is compatible with HA, or use a personal software DEVELOPED with Netatmo, but not compatible.
Does anyone has a BTicino Living Now system installed and want to try integration in HA with Netatmo component?
Hi, I have Bticino living Now roller shutter controller, it should be works with Homekit and Google Assistant, but now doesn’t work. Is there a plugin for HA to integrate some roller shutter controllers in HA and consequently in HomeKit?
Thank you
first of all, Happy new year.
@clau67, I have a problem, it seams your componente OpenWebNet trys to convert the password to an int, but unfortunally that is not an option for me:
My_home demands me to have at least one letter
And there for I have this error:
File "/config/deps/lib/python3.6/site-packages/OpenWebNet.py", line 188, in cmd_session
psw_open = '*#' + str(self.calculated_psw(answer)) + '##'
File "/config/deps/lib/python3.6/site-packages/OpenWebNet.py", line 79, in calculated_psw
self._psw = int(self._psw)
ValueError: invalid literal for int() with base 10: '111111111Ab'
Hi all,
is there any plan to add also shutter support to this my_home bTicino home assistant plugin?
thanks
bye
Marco
it works, but not so well … many errors and turn the lights on/off once in 10 !
Here my log:
normal_request 1 24 1
stato request 1 24 0
2019-01-28 21:58:43 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.test fails
File "C:\Program Files\Python\Python37\lib\site-packages\homeassistant\helpers\entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "C:\Program Files\Python\Python37\lib\site-packages\homeassistant\helpers\entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "C:\Program Files\Python\Python37\lib\concurrent\futures\thread.py", line 57, in run
File "C:\Users\Giancarlo\AppData\Roaming\.homeassistant\custom_components\light\my_home.py", line 99, in update
self._gate.ask_stato_luce(self._indirizzo)
File "C:\Program Files\Python\Python37\lib\site-packages\OpenWebNet.py", line 426, in ask_stato_luce
self.stato_request('1',where,'0')
File "C:\Program Files\Python\Python37\lib\site-packages\OpenWebNet.py", line 344, in stato_request
self.stato_request(who,where)
TypeError: stato_request() missing 1 required positional argument: 'what'
2019-01-28 21:58:43 ERROR (SyncWorker_10) [OpenWebNet] Non posso inizializzare la comunicazione con il gateway
NoneType: None
2019-01-28 21:58:43 ERROR (SyncWorker_0) [OpenWebNet] Password errata
NoneType: None
2019-01-28 21:58:43 ERROR (SyncWorker_10) [OpenWebNet] Il gateway rifiuta la sessione comandi
NoneType: None
2019-01-28 21:58:53 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.test is taking over 10 seconds
light_risposta {'24': '1'}
2019-01-28 22:01:15 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.test fails
File "C:\Program Files\Python\Python37\lib\site-packages\OpenWebNet.py", line 363, in stato_request
self.extractor(check_message)
File "C:\Program Files\Python\Python37\lib\site-packages\OpenWebNet.py", line 205, in extractor
if answer[1] == '1':
IndexError: string index out of range
I am facing the same issue with this @clau67 please help how to get rid of it
Well, I invite everyone to try this addon.
[BTicino/Legrand] Sdomotica Gateway Hass.io addon
@clau67 thx for the component! Can toggle my lights with Home Assistant now, awesome
Hi @clau67, I have some problem setting up your component.
No matter what address (“indirizzo”) I put in the config.yaml, I always get the following error:
stato request 1 5 0
2019-04-06 06:05:25 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.tavolo fails
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/home/homeassistant/.homeassistant/custom_components/light/my_home.py", line 100, in update
self._state=self._gate.answ_stato_luce(self._indirizzo)
File "/srv/homeassistant/lib/python3.5/site-packages/OpenWebNet.py", line 448, in answ_stato_luce
stato = self.stato_answer('1',where,'1')
File "/srv/homeassistant/lib/python3.5/site-packages/OpenWebNet.py", line 407, in stato_answer
return self.light_risposta[where]
KeyError: '5'
Note that the gateway (MH201) correctly works with JS homebridge plugin.
Any idea?
This is my config.yaml:
#MyHome bTicino
my_home:
host: 192.168.0.136
port: '20000'
password: '12345'
light:
- platform: my_home
scan_interval: 5
devices:
- name: 'Tavolo'
indirizzo: 5
Hi teejay-87,
I have the same errors in my log, but the system works without any problems, so if it doesn’t work there must be some other problem.
Are you sure about the address ?
In my installation all the addresses have two digits 11, 12, 13, 21, 22, 51, 61 etc
Another thing remember to change the custom_components/light/my_home.py in custom_components/my_home/light.py as reported in the update information of the latest version of HA
Honestly I don’t understand the syntax of your library addresses.
This is my configuration for HomeBridge JS plugin, as you can see the address syntax is quite different and I’m experiencing difficulties in translating them for your library:
Also what do you mean by updating the .py?
Why don’t you release it on GitHub?
Anyway I’m currently not on the latest version of HomeAssistant (0.84 I think).
try ‘scala1P’ indirizzo 19
‘Ext bagno pt’ indirizzo 110
‘Ext giardino’ indirizzo 111 etc…
check in this site
Hi clau… sorry for the delay.
I managed to switch on a light, Scala1P, using address 19.
But the problem is that Hass cannot retrieve the state correctly, as it states in the error log:
File “/home/homeassistant/.homeassistant/custom_components/light/my_home.py”, line 100, in update
File “/srv/homeassistant/lib/python3.5/site-packages/OpenWebNet.py”, line 448, in answ_stato_luce
stato = self.stato_answer(‘1’,where,‘1’)
File “/srv/homeassistant/lib/python3.5/site-packages/OpenWebNet.py”, line 407, in stato_answer
KeyError: ‘19’
So the light actually switched on, but than the toggle in Hass interface go back to OFF in some seconds, and I cannot switch off the light.
Hello all,
i’m using this plugin and it is awesome. Just a question, is there any way to “catch” when the “switch off all lights” button is pressed? This button identifier is only: 0 (zero).
Any idea?
Hello how can I configure the component to run with homeassistant 0.92?
thank you
Anyone managed to have it working on 0.92?
Any answer about the support to 0.92?
I ended up using Homebridge plugin for myHome by AngeloXX — see GitHub — and then reading entities from HomeKit via “HomeKit controller” component for Home Assistant.
The Homebridge plugin is way more stable.
When I’ll have some spare time, I’ll port it to Hass.
I’m using this component with succes, I just only have a question for @clau67, there is any possibilities to control blinds, like a roller?
Thanks in advance
Matteo,
we would be glad to know how you adapted it to new “custom component” management of recent HA versions (> =.92).
