Can anyone specify what this has to do with?
Staffan, they have updated the syntax for command line sensors. Check:
You also have numerous of posts in this thread about the same issue:
And in future please read the breaking changes in the release notes before updating.
Never been much of a YAML user but I had some sensors. A System Monitor and a Ping. I think I managed to rewrite the CPU, GPU and the Ping. However what to do with System Monitoring lines, I cant figure out by myself. Can anyone help out with the ones I have commented out for now?
command_line:
- sensor:
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
# If errors occur, make sure configuration file is encoded as UTF-8
unit_of_measurement: "°C"
value_template: "{{ value | multiply(0.001) | round(1) }}"
- sensor:
name: GPU Temperature
command: "/opt/vc/bin/vcgencmd measure_temp"
value_template: '{{ value | replace("temp=", "") | replace("''C", "") }}'
# - platform: systemmonitor
# resources:
# - type: last_boot
# - type: disk_use_percent
# arg: /
# - type: memory_use_percent
# - type: processor_use
- binary_sensor:
command: "ping -W 1 -c 1 192.168.1.50 > /dev/null 2>&1 && echo success || echo fail"
device_class: connectivity
payload_on: "success"
payload_off: "fail"
Trying to fix the same issue here…
I have moved this from sensor.yaml to configuration.yaml
# update the lastest ABC News Podcast
- platform: command_line
name: Latest ABC News Bulletin
scan_interval: 3600 # Every hour
command: curl -k -s https://www.abc.net.au/feeds/101858056/podcast.xml | grep -E -o 'https?://[^"]+mp3' | uniq | head -n 1
Not I get… Configuration invalid!
Invalid config for [command_line]: [name] is an invalid option for [command_line]. Check: command_line->command_line->0->name. (See /config/configuration.yaml, line 61).
The documentation clearly specifies a name, so what’s the story?
**** Update ****
Seems you need to put “- sensor:” in the configuration. Don’t think that is clear in the documentation… ie:
command_line:
- sensor:
Every example has the dash, literally
So it does , it also says that the map is optional. Doesn’t seem to be. Perhaps I am not reading the documentation correctly.
