Hi - I see there are a lot of posts about the new Tuya integration, but I can’t find anyone who has experienced this problem yet. A few posts are similar though (with region issues) so sorry if I’ve missed a solution somewhere
I followed the instructions at https://www.home-assistant.io/integrations/tuya and managed to register with the IoT platform, find my correct data centre (Central Europe), link my Tuya Smart app, see my devices, and extract an access ID/key.
When I try to set up the Tuya integration in Home Assistant, using my Tuya Smart app login, the IoT access ID and key, and UK as country, it gives me an immediate “login error 1106 permission deny”
I looked through the app and noticed that the Region shows as “Isle of Man/United Kingdom”. Under Country in the integration setup, there is both UK and Isle of Man as separate entries. If I select Isle of Man, it sits there thinking for a while, then gives me “login error 2406 skill ID invalid”
Under the integration setup instructions, it gives two points to troubleshoot this error, both of which I think I’m already doing correctly:
- Make sure you use the Tuya Smart or SmartLife app account to log in. Also, choose the right data center endpoint related to your country region. For more details, please check Country Regions and Data Center.
- Your cloud project on the Tuya IoT Development Platform should be created after May 25, 2021. Otherwise, you need to create a new project.
What else can I do to try and get this working?
