I saw the github issue but didn’t work for me, this is my output :
Output "pip install PyXiaomiGateway==0.6.0"
(homeassistant) homeassistant@pi3:/home/pi$ pip install PyXiaomiGateway==0.6.0
Collecting PyXiaomiGateway==0.6.0
Using cached https://www.piwheels.ho
stedpi.com/simple/pyxiaomigateway/PyXiaomiGateway-0.6.0-py3-none-any.whl
Collecting cryptography==2.1.1 (from PyXiaomiGateway==0.6.0)
Using cached cryptography-2.1.1.tar.gz
Requirement already satisfied: idna>=2.1 in /srv/homeassistant/lib/python3.5/site-packages (from cryptography==2.1.1->PyXiaomiGateway==0.6.0)
Requirement already satisfied: asn1crypto>=0.21.0 in /srv/homeassistant/lib/python3.5/site-packages (from cryptography==2.1.1->PyXiaomiGateway==0.6.0)
Requirement already satisfied: six>=1.4.1 in /srv/homeassistant/lib/python3.5/site-packages (from cryptography==2.1.1->PyXiaomiGateway==0.6.0)
Requirement already satisfied: cffi>=1.7 in /srv/homeassistant/lib/python3.5/site-packages (from cryptography==2.1.1->PyXiaomiGateway==0.6.0)
Requirement already satisfied: pycparser in /srv/homeassistant/lib/python3.5/site-packages (from cffi>=1.7->cryptography==2.1.1->PyXiaomiGateway==0.6.0)
Building wheels for collected packages: cryptography
Running setup.py bdist_wheel for cryptography … error
Complete output from command /srv/homeassistant/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-mt25v7jq/cryptography/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” bdist_wheel -d /tmp/tmpdh3x0b48pip-wheel- --python-tag cp35:
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.5
creating build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/init.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/about.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/utils.py -> build/lib.linux-armv7l-3.5/cryptography
creating build/lib.linux-armv7l-3.5/cryptography/hazmat
copying src/cryptography/hazmat/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat
creating build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/init.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-3.5/cryptography/x509
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/mac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/serialization.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
running egg_info
writing requirements to src/cryptography.egg-info/requires.txt
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
writing src/cryptography.egg-info/PKG-INFO
reading manifest file ‘src/cryptography.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
no previously-included directories found matching ‘docs/_build’
warning: no previously-included files matching ‘*’ found under directory ‘vectors’
writing manifest file ‘src/cryptography.egg-info/SOURCES.txt’
running build_ext
generating cffi module ‘build/temp.linux-armv7l-3.5/_padding.c’
creating build/temp.linux-armv7l-3.5
generating cffi module ‘build/temp.linux-armv7l-3.5/_constant_time.c’
generating cffi module ‘build/temp.linux-armv7l-3.5/_openssl.c’
building ‘_openssl’ extension
creating build/temp.linux-armv7l-3.5/build
creating build/temp.linux-armv7l-3.5/build/temp.linux-armv7l-3.5
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-RUbMX3/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.5m -I/srv/homeassistant/include/python3.5m -c build/temp.linux-armv7l-3.5/_openssl.c -o build/temp.linux-armv7l-3.5/build/temp.linux-armv7l-3.5/_openssl.o -Wconversion -Wno-error=sign-conversion
build/temp.linux-armv7l-3.5/_openssl.c:483:30: fatal error: openssl/opensslv.h: No such file or directory
#include <openssl/opensslv.h>
compilation terminated.
error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
Failed building wheel for cryptography
Running setup.py clean for cryptography
Failed to build cryptography
Installing collected packages: cryptography, PyXiaomiGateway
Running setup.py install for cryptography … error
Complete output from command /srv/homeassistant/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-mt25v7jq/cryptography/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-h597kz8u-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.5/cryptography:
running install
running build
running build_py
creating build
running egg_info
running build_ext
Command “/srv/homeassistant/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-mt25v7jq/cryptography/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-h597kz8u-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.5/cryptography” failed with error code 1 in /tmp/pip-build-mt25v7jq/cryptography/
Any idea ?
