First off, I’m very new to home automation and thus some of what I write might be odd or ever plain wrong - any corrections are much appreciated.
GOAL: Measure 3x temperature, 2x moisture level, 1x EU (schuko) plug for energy consumption (16 A fuse). Do this preferably without third party cloud services and have the ability to pull out graphs of desired start and end dates for at least 12 months of logged data.
NOW: Understood that Z-Wave has less connectivity / interoperability risks than Zigbee and want to get Z-Wave temp/moisture sensors. Looking at Aeotec Z-Stick 7 and Aeotec - aërQ Temperature & Humidity Sensor as the most appealing so far… for indoor use. I can use a Raspberry or Intel NUC to run Home Assistant.
HELP WANTED: I am utterly lost with the energy meter.
I found FIBARO FGWP-102, but what really puts me off were the complaints that its firmware was not upgradable, unless you own ~400 EUR Home Center of theirs. It also has butt-ugly LED light, but this might be something that can be toggled OFF. Lastly, the Amazon page lists it as “Z-Wave Red”, which means nothing to me - all I know are these chip series 500, 600, 700, and now 800 - which to my understanding equate to “gen 5”, “gen 5+”(?), “gen 7” and maybe now “gen 8”?
But perhaps the energy meter does not need to be Z-Wave, since it can run off the socket. Maybe it could be a Wi-Fi device? Z-Wave is the preferred for battery run sensors, because changing batteries once a year is at the very limit of my tolerances
Looking into Wi-Fi devices confuse me to no end. Some appear to work only with manufacturer’s own crappy software (usually a smartphone app, which I hope never to have to use). And I haven’t found a listing that would explicitly point out those that will work with HA.
That FIBARO wall plug energy meter is at least a good example what I hope to find - be it Z-wave or Wi-Fi (or some other?). Following wishes included:
- Data points at least once a minute, preferably configurable for shorter intervals.
- 16 A (device is 10 A)
- Would be a bonus if it can tolerate freezing temperatures in dry conditions
- Preferably no silly LEDs or they can be disabled somehow without voiding warranty
- Big plus if the product has been proven stable and maintenance free (some complaints revolve around having to reset the device every so-and-so many weeks, for some products)
Distance from the HA unit and the energy meter is about 20 m, but it will be behind two concrete walls. Am I correct to assume that run-of-the-mill BT 4.0 chips found in PCs and RPis do not support the long-range mode (found in motorcycle helmet intercoms and headsets) and I would need BT 5.0 dongle to be able to consider BT based options? Do I have some other options that I have failed to consider?
I would love to hear advice, suggestions, recommendations, and especially any shared experiences if someone has worked with plug-type energy metering.
