0.115.1 on Rpi4. When I try to edit a NFS tag automation, it doesn’t get saved. Its Action always resets to “Device” (with no entity). I see nothing relevant in logs, restarting HA and the host did nothing. Anyone else?
Yes same issues here with 0.115.2
Do you have a single file automations.yaml?
In my case my automations were in a sub directory so saving in the UI wasn’t working. I had to migrate to a single automations.yaml. Also worth making sure each automation has an ‘id’ set.
Yes, single automations.yaml, in root.
It makes a new automations every time.
If you have made it go to the general automations part and you can edit them there.
