It works really well with the Hue app, although even better with the eve app which lets you use double click and triple click on the buttons.
I can set rules up in the app so that if a light is on, another click on the same button turns it off etc so the switch is mega useful.
My issue is I would really like to connect it HA so that the buttons could maybe start a sonos playing, or operate plug sockets etc but because the switch is hubless/powerless etc HA does not discover it at all?
Unless anyone knows a way of getting the switch to be detected by HA I was wondering if I could create dummy hue lights somehow in HA? some sort of emulator or similar and then use HA to set my sonos play state to on if this imaginary light is on?
Yeah a friend says it will be zigbee too so it’s whether it’s worth the risk of buying some sort of zigbee controller / detector to try and pick up whatever signal it sends then code these.
I’m interested in the friends of hue switches but not working with HA is a dealbreaker for me. If anyone knows how to make these switches work with HA I would love to hear it
https://hacs.xyz/
Start with the above link to install HACS. I use hassio (not regular HA). When installation is done it should show up in the hassio menu as community. Start HACS and install Hue sensor custom component. This will make the friends of hue switches available to HA. Search for entities named sensor.switch_name
Hi SarumaN, thank you for this info. I’m still new in hass.io but am I correct that if I install Hassio + HACS + Hue sensor custom component that I won’t need additional hardware (aside from the Niko Hue Switch)? In other posts I read that you would also need a Zigbee USB stick?
I would like to be able to add the Niko Hue Switch to HA so that I can use I to control other automatons.
You either need a zigbee stick (according to other users) or a philips hue bridge (part of my setup). Zigbee devices always need a coordinator (bridge) in the mesh network. Most devices (switches, lights) are also routers at the same time. Zigbee network image
When you connect the Niko switch with a Hue Bridge you can control scenes in Home assistant using the “Hue sensor custom component” mentioned above. However you will need 2 buttons to controle the light (on/of) and only have 2 buttons left on the right side of the switch.
using the deconz app with a conbee , I was able to toggle light on/of & dim up/down with only 1 of the 4 switches and connect the other 3 with other scenes or automations in Home Assistant after tracing what every switch would trigger in het HA.
For example a trigger for an automation using the left upper button:
Depends on your zigbee channel. Check the Deconz faq on how to configurate. For channel 15 it is the top left ( hold it for 10sec), and then press lower left and top right together once.
Tip for anybody who is interested. I came upon this message looking for a method to make an existing “dumb” Niko wall Switch smart. Because of the limitations of the Niko friends of hue switch I ended up buying the Shelly 1 WiFi Switch for € 15. This is a relay that can be mounted behind your existing Niko Switch. Installation was fast and simple.
I can highly recommend the deconz setup. I bought a conbee II stick on Amazon and paired my Niko friends of hue switch to it. Some essential info to support the pairing process can be found here:Switch orientation info provided by dresden elektronik and here: Phoscon app zigbee channels. What you need to do is press the right button on the FOH switch that matches your zigbee channel. To confirm this channel you need to briefly press two other FOH buttons simultaneously. If you omit this last step the deconz_event will not show up in HA. It took me a while before I got my head around this one (first tested a regular battery powered HUE dimmer which works really well). Main advantage compared to a regular hue bridge is that HA polls the hue bridge (slow-ish) and the conbee solution is event based (much faster). I am planning to do double clicks etc.
Hello SarumaN,
Thx for your tips about the Niko friends of hue. I follow every steps :
check the channel : ok (it s 15 for me)
i push the button 1 (pairing-friends-of-hue-switch)(i ll do in Other --> Add switch in Phoscon integreted in HA by Deconz add-on (new switch is active for 3 minutes).
i push briefly buttons 2 and 3 simultaneously. (i ll do in Other --> Add switch in Phoscon integreted in HA by Deconz add-on (new switch is active for 3 minutes).
I can see my switch in Deconz , the integration seems to be ok in HA (i can see the switch in HA but impossible to make an automation and i don t see the deconz_events… I m a little confused.
