No experience on the dual plug, using a Tellur dual plug myself and have no issues when I adopt it with Local Tuya.
I’m trying my luck on the Kruidvat motion sensor, but noticed that it has a down time after each detection for a few minutes… showstopper for me for the moment but a logic choice as the motion sensor works on a battery. So to save power they go in sleep mode after detection.
Ok all ready to go. Serial setup via arduino is ready.
Which program to flash to the homeplug?
I have to do it OTA as will be difficult to unsolder the chip.
With OTA you don’t need to open the device at all, it’s over-the-air
If the device has already been updated you might run into some issues because tuya has tried preventing people from flashing OTA, in that case I think you will have to open up the device to flash it. I’d still give it a try though before messing with serial.
You can use ESPFlash tool and you just have to solder some wires like I mentioned earlier.
Else, you can use probably use TuyaConvert. Should work also. It’s the same Tuya chip used in the LSC Plugs. I’ve flashed a couple of them via TuyaConvert and a few via serials because some of them didn’t want to
Ok will try later, but want first to understand what to flash etc. Also what is tasmota etc…
What program/instructions to flash etc.
All input is welcome. Then I keep you in the loop of the progress.
Aim is the arrive in a plug controllable by home assistant.
Like ESP8266 based DIY Smart Plug to Make Your Home Appliances IoT Enabled
The flashing part is mostly universal for these devices.
You should look up the official guides and wikis on the tasmota or esphome websites.
Also, good to know. ESPhome is acquired by Nabu Casa(HA). So for you as beginner in that stuff, I would use that. The ease of setting up devices and copying configurations from one device to another is very nice.
Learning curve, yeah. But worth it, if you’d ask me.
As far I’m reading and learning I will:
Solder wires on the ESP module and flash it with firmware like explained in Arduino
Then I will be able to upload further programs with OTA
and make my plug connection with Home assistant.
ESPhome is a piece of software that lets you create a configuration for a type of device that you are using. After creating your own “YAML” file, you can create a BIN(flashable file). Flash that with Espeasy Flasher.
Thén you can upload firmware OTA.
I would also recommend to create your own topic if you need help with this. This is kinda hijacking this thread.
Did you try to follow the guide I linked? I’ve already converted 2 Kruidvat Dual Plugs OTA using this guide without any issues. Note: I didn’t update the plugs or connect them via the app prior to flashing. Updating will probably block your ability to flash them OTA.
Hi, as suggested by tuncaya I started new topic on the forum.
And no did not do it yet.
Still learning and reading…
I want to understand all the different possibilities.
I think you are trying to invent the wheel all over again. Visit the website shared with you earlier. That’s all the info you need. If you want any visual guidance, just check YouTube. Search for “TuyaConvert”
Sure you can create a new thread, but I feel like you need to watch some tutorials and read some more. If you are an absolute beginner, start there.
