No Backups in the list
I run Home Assistant on a PC hardware with HAOS installation. Latest version is installed/updated.
I configured a daily backup using an automation with the service hassio.backup_full. When I created this configuration it started working perfectly, backup file were created (on a NAS) and correctly shown in the list of backups.
But after a while (I can’t tell exactly) the list of backups was empty.
I tried the easy things like re-starting HA (incl. HW restart), different browsers, clean browser cache etc. But still no backups.
I also played around with manually creating backups, changing the location of the backups to local disk. But nothing helps.
Any ideas?
Regards,
Siggi
Hello Siggi,
Are you still having the issue or did you find a fix in the meantime?
If you still having the issue, please could a look at this post No backups showing after upgrade to 2024.1?
I assume you are having the same issue, right?
Thanks,
Thomas
