Is it possible to run only the HA integration or do you have to run both the android/ios roborock app and the HA integration?
Hello.
Thanks for the sharing.
Can you control the “mopa” as you can choose on the roborock application? To turn off and on , to set the desired type of clean with “mopa”… soft… medium or high?
Can you put the yaml of the card that you have configured?
All that is on the image that you show @MrFroggy ?
I use both. But you can use only the app or only the integration with HA.
You do have an attribute to show if the mop is installed or not, but I don’t think you can control that from HA, you can control it only from the app.
This functionality is already asked at Roborock integration github page. Maybe in the near future…
Sure!
- title: Vacuum
path: vacuum
icon: mdi:robot-vacuum
badges: []
cards:
- type: vertical-stack
cards:
- type: custom:xiaomi-vacuum-card
entity: vacuum.lucineide
image: /local/vacuum/vacuum.png
vendor: xiaomi
attributes:
mop_attached:
key: mop_attached
label: 'Mop: '
- type: horizontal-stack
cards:
- elements:
- entity: sensor.lucineide_side_brush_remaining
style:
background-color: rgba(0, 0, 0, 0.3)
bottom: 0px
color: orange
font-size: 30px
left: 0px
right: 0px
transform: translate(0%,0%)
title: '% Remaining Until Side Brush Should Be Replaced'
type: state-label
- entity: sensor.lucineide_side_brush_hrs_remaining
style:
bottom: 0px
color: white
font-size: 16px
line-height: 16px
right: 0px
prefix: 'Remaining '
title: Hours Remaining Until Side Brush Should Be Replaced
type: state-label
- icon: mdi:restart
style:
color: white
padding: 7px
right: 0px
top: 0px
tap_action:
action: call-service
confirmation:
text: >-
Are you sure you want to reset the hours remaining
counter for replacing the side brush?
service: vacuum.send_command
service_data:
command: reset_consumable
entity_id: vacuum.lucineide
params:
- side_brush_work_time
title: Reset Hours
type: icon
image: /local/vacuum/side_brush.png
type: picture-elements
- elements:
- entity: sensor.lucineide_sensors_remaining
style:
bottom: 0px
color: orange
font-size: 30px
left: 0px
right: 0px
title: '% Remaining Until Sensors Should Be Cleaned'
type: state-label
- entity: sensor.lucineide_sensors_hrs_remaining
style:
bottom: 0px
color: white
font-size: 16px
line-height: 16px
right: 0px
title: Hours Remaining Until Sensors Should Be Cleaned
type: state-label
- icon: mdi:restart
style:
color: white
padding: 7px
right: 0px
top: 0px
tap_action:
confirmation:
text: >-
counter for cleaning the sensors?
service_data:
params:
- sensor_dirty_time
title: Reset Hours
type: icon
image: /local/vacuum/sensors.png
cards:
- elements:
- entity: sensor.lucineide_filter_remaining
style:
bottom: 0px
color: orange
font-size: 30px
left: 0px
right: 0px
title: '% Remaining Until Filter Should Be Replaced'
type: state-label
- entity: sensor.lucineide_filter_hrs_remaining
style:
bottom: 0px
color: white
font-size: 16px
line-height: 16px
right: 0px
title: Hours Remaining Until Filter Should Be Replaced
type: state-label
- icon: mdi:restart
style:
color: white
padding: 7px
right: 0px
top: 0px
tap_action:
confirmation:
text: >-
counter for replacing the filter?
service_data:
params:
- filter_work_time
title: Reset Hours
type: icon
image: /local/vacuum/filter.png
- elements:
- entity: sensor.lucineide_main_brush_remaining
style:
bottom: 0px
color: orange
font-size: 30px
left: 0px
right: 0px
title: '% Remaining Until Main Brush Should Be Replaced'
type: state-label
- entity: sensor.lucineide_main_brush_hrs_remaining
style:
bottom: 0px
color: white
font-size: 16px
line-height: 16px
right: 0px
title: Hours Remaining Until Main Brush Should Be Replaced
type: state-label
- icon: mdi:restart
style:
color: white
padding: 7px
right: 0px
top: 0px
tap_action:
confirmation:
text: >-
counter for replacing the main brush?
service_data:
params:
- main_brush_work_time
title: Reset Hours
type: icon
image: /local/vacuum/main_brush.png
cards:
- type: custom:xiaomi-vacuum-map-card
map_camera: camera.lucineide_map
camera_calibration: true
- show_header: true
type: entities
entities:
- head:
entity: input_boolean.aspirar_iniciar
secondary_info: last-changed
type: custom:fold-entity-row
entities:
- entity: input_number.aspirar_cozinha
type: custom:numberbox-card
icon_plus: mdi:chevron-up
icon_minus: mdi:chevron-down
style: |
.cur-num{font-size:20px !important}
- entity: input_number.aspirar_sala
style: |
- entity: input_number.aspirar_escritorio
style: |
- entity: input_number.aspirar_hall_entrada
style: |
- entity: input_number.aspirar_wc
style: |
![sensors](https://community-assets.home-assistant.io/original/3X/a/b/ab339ca78a5d3fd1961b09b3cd89445d02735d03.png)
![side_brush](https://community-assets.home-assistant.io/original/3X/7/8/78b77a9bf083ea3c23e5a9355670e4270e9fdc0f.png)
![8249fd50a958e80bd226584a09acd534471bbb4a](https://community-assets.home-assistant.io/original/3X/8/2/8249fd50a958e80bd226584a09acd534471bbb4a.png)
Thank you for sharing the images too
Really appreciate. Let’s wait for a github version for s7.
Or in a near future the root for s7 too
From HA helpers. Those input_numbers as well as the “input_boolean.aspirar_iniciar” are all helpers to make an automation within NodeRed.
This works like this: I expand the “Iniciar” (Start in Portuguese) dropdown and all zones appears. Then I just select how many passes I want for each zone and just press “Iniciar”.
Ahh and to optimize bandwidth, I just update the map when the vacuum is ON. If it’s OFF, the map does not update at all.
Sorry to ask you. I understand that I choose from the dropdown box, but is it needed NodeRed to accomplish this?
Thank you
No, you can do your automations within HA automations as well.
The use of NodeRed is just my preference. All my automations are implemented in NodeRed.
I cannot get the picture working…
I tried the path inside config/photos/name.png
But it does not show the pic…
Any ideia why? Can you help me with that.?
Other question…
In ha where I can find the entities input…?
You talk in nodered but as I don’t have it where can I find that in HA?
All images need to be saved inside “/config/www” directory. Inside the “www” directory you can create any directory tree you want.
Goto Configuration->Helpers.
Install NodeRed depends on your HA installation. If you have HASSOS, then just install it from “Supervisor->Addon Store”.
@MrFroggy ok… but without NodeRed i already got into the HA → Helpers , but honestly i don’t know how to create on my side based on the yaml. Sorry for not to know so much about HA , but this regarding helpers and the sensors , i would be really appreciated if you can provide me some guidance. ?
i also intalled NodeRed in HA and installed the nodes for RoboRock , but i don’t know what to do…
can you show me how please?
or without NodeRed …
i Am almost there i think heeheh.
Many thanks
Hi @nbexiga,
You don’t need the roborock palette in NodeRed to work with your S7. This palette is for people that doesn’t use HomeAssistant, only NodeRed. In your cenario (HA+NR) you should use only the HA<->Roborock integration, not the palette.
NodeRed is another chapter. First you need to learn HA and how it works (including helpers, automations, entities, attributes, services, templates, events, etc). Only then you should move to NodeRed. Just do as I did, learn from youtube videos, forum and the community. It’s not difficult, you just need to spend some time and patience.
For helpers, check those 2 videos:
Video 1
Video 2
But this is too much Offtopic. If you need more help, PM me.
BTW, these are the sensors created to help display some information on the cards.
# Roborock S7
sensors:
# Used for the Filter maintenance card
lucineide_filter_remaining:
friendly_name: 'HEPA Filter Life (%)'
unit_of_measurement: '%'
value_template: "{{((state_attr('vacuum.lucineide', 'filter_left') / 150) * 100) | round | int}}"
lucineide_filter_hrs_remaining:
friendly_name: 'HEPA Filter Life (hr)'
unit_of_measurement: 'hrs'
value_template: "{{state_attr('vacuum.lucineide', 'filter_left')}}"
# Used for the Side Brush maintenance card
lucineide_side_brush_remaining:
friendly_name: 'Side Brush Life (%)'
value_template: "{{((state_attr('vacuum.lucineide', 'side_brush_left') / 200) * 100) | round | int}}"
lucineide_side_brush_hrs_remaining:
friendly_name: 'Side Brush Life (hr)'
value_template: "{{state_attr('vacuum.lucineide', 'side_brush_left')}}"
# Used for the Main Brush maintenance card
lucineide_main_brush_remaining:
friendly_name: 'Main Brush Life (%)'
value_template: "{{((state_attr('vacuum.lucineide', 'main_brush_left') / 300) * 100) | round | int}}"
lucineide_main_brush_hrs_remaining:
friendly_name: 'Main Brush Life (hr)'
value_template: "{{state_attr('vacuum.lucineide', 'main_brush_left')}}"
# Used for the Sensors maintenance card
lucineide_sensors_remaining:
friendly_name: 'Sensors Usage (%)'
value_template: "{{((state_attr('vacuum.lucineide', 'sensor_dirty_left') / 30) * 100) | round | int}}"
lucineide_sensors_hrs_remaining:
friendly_name: 'Sensors Usage (hr)'
value_template: "{{state_attr('vacuum.lucineide', 'sensor_dirty_left')}}"
Thank you all for all this lovely sharing !
Finally got the Roborock S7 fully integrated in HA, I’m loving it :
![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
You are welcome.
BTW, nice vacuum card!
