I removed this configuration since then.
But you can have the same results using A different take on designing a Lovelace UI, all credits goes to this genius !
Hi, can you use or not the mop direcly in HA. Because when i get the card for my S7 i didn’t get the button for the mop.
Thx
Out of curiosity, after integrating the Roborock S7 with Home Assistant, can you use the Home Assistant integration without the Roborock S7 needing a connection to the Cloud?
No, the Roborock integration with HA uses the cloud to access the vacuum robot.
Maybe, in the future, the integration can be implemented locally…
Thanks for the info!
Beautiful ! Could you please share how you did that ?
Im having an issue with adding s7 when i Already have added an s5. Just says no new devices in that account. Anyone know why?
Is this still the case? I noticed on the Xiaomi Miio integration page, it mentions the IoT class is local polling. There’s also an issue about HA communicating with the Roborock S7 across different subnets which leads me to believe the integration is communicating locally.
I don’t think so. Just check the integration setup page…
I’ve also checked with Wireshark and the integration is pooling the cloud…
Hi @MrFroggy
Like a lot of people, I’m ‘borrowing’ your dashboard images and config.
the reset timers? does that call service reset the timers on the Mi home app?
How did you do that?
