nylund
(Nicklas Nylund)
May 23, 2023, 6:15am
1
Hi!
I have a problem I have tried to troubleshoot a while but I can’t find what is causing it. Perhaps someone know?
My esphome update entities are not created. First they were all unavailable but after removing esphome completely and only importing my yaml files they are all gone.
When esphome 2023.2.0 was released I could update my esphome devices from HA but not anymore. The updates does not show up at all in HA even if I see updates available in esphome.
Does anyone know what could cause this?
I have “ota:” in my yaml files and I have tried to reinstall esphome. Can’t find anything related to this in my logs.
Running latest stable HA and esphome.
BR/Nicklas
nylund
(Nicklas Nylund)
May 24, 2023, 3:49pm
2
Am I the only one with this problem?
My esphome sensors work well. I only miss the ability to install OTA updates in parallel from HA.
jsuanet
(Jos)
May 24, 2023, 3:58pm
3
Please share your yaml and log file for one of the involved devices.
I had the same problem a while back, and found the solution in this forum post:
Esphome devices not showing up on dashboard but are working
nickrout
(Nick Rout)
May 24, 2023, 10:36pm
5
I don’t have update sensors there, and I am not sure if I ever did.
Are you sure you aren’t thinking of the esphome addon interface?
nylund
(Nicklas Nylund)
May 25, 2023, 12:32pm
6
Here is my yaml and log for one of my sensors.
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "******"
password: "***********"
domain: ".***********"
power_save_mode: none
fast_connect: false
ap:
ssid: "rad Fallback Hotspot"
password: "********"
ap_timeout: 5min
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: **********
dallas:
- pin: D4
update_interval: 20s
- platform: dallas
address: 0xF3041661D0D1FF28
- platform: dallas
address: 0x030316622997FF28
# Wifi signal sensor
- platform: wifi_signal
update_interval: 30s
# Extra sensor to keep track of plug uptime
- platform: uptime
icon: mdi:clock-outline
button:
- platform: restart
INFO Reading configuration /config/esphome/rad.yaml...
INFO Starting log output from rad.********** using esphome API
INFO Successfully connected to rad.**********
[14:26:35][I][app:102]: ESPHome version 2023.5.3 compiled on May 23 2023, 10:58:54
[14:26:35][C][wifi:505]: WiFi:
[14:26:35][C][wifi:363]: Local MAC: 5C:CF:7F:D7:1D:C9
[14:26:35][C][wifi:364]: SSID: [redacted]
[14:26:35][C][wifi:365]: IP Address: 10.10.10.150
[14:26:35][C][wifi:366]: BSSID: [redacted]
[14:26:35][C][wifi:368]: Hostname: 'rad'
[14:26:35][C][wifi:370]: Signal strength: -52 dB ▂▄▆█
[14:26:35][C][wifi:374]: Channel: 6
[14:26:35][C][wifi:375]: Subnet: 255.255.255.0
[14:26:35][C][wifi:376]: Gateway: 10.10.10.254
[14:26:35][C][wifi:377]: DNS1: 10.10.10.254
[14:26:35][C][wifi:378]: DNS2: 0.0.0.0
[14:26:35][C][logger:301]: Logger:
[14:26:35][C][logger:302]: Level: DEBUG
[14:26:35][C][logger:303]: Log Baud Rate: 115200
[14:26:35][C][logger:305]: Hardware UART: UART0
[14:26:35][C][uptime.sensor:031]: Uptime Sensor 'rad_Uptime Sensor'
[14:26:35][C][uptime.sensor:031]: Device Class: 'duration'
[14:26:35][C][uptime.sensor:031]: State Class: 'total_increasing'
[14:26:35][C][uptime.sensor:031]: Unit of Measurement: 's'
[14:26:35][C][uptime.sensor:031]: Accuracy Decimals: 0
[14:26:35][C][uptime.sensor:031]: Icon: 'mdi:clock-outline'
[14:26:35][C][dallas.sensor:075]: DallasComponent:
[14:26:35][C][dallas.sensor:076]: Pin: GPIO2
[14:26:35][C][dallas.sensor:077]: Update Interval: 20.0s
[14:26:35][D][dallas.sensor:082]: Found sensors:
[14:26:35][D][dallas.sensor:084]: 0xf3041661d0d1ff28
[14:26:35][D][dallas.sensor:084]: 0x030316622997ff28
[14:26:35][C][dallas.sensor:089]: Device 'Framledning'
[14:26:35][C][dallas.sensor:089]: Device Class: 'temperature'
[14:26:35][C][dallas.sensor:089]: State Class: 'measurement'
[14:26:35][C][dallas.sensor:089]: Unit of Measurement: '°C'
[14:26:35][C][dallas.sensor:089]: Accuracy Decimals: 1
[14:26:35][C][dallas.sensor:097]: Address: 0xf3041661d0d1ff28
[14:26:35][C][dallas.sensor:098]: Resolution: 12
[14:26:35][C][dallas.sensor:089]: Device 'Retur'
[14:26:35][C][dallas.sensor:097]: Address: 0x030316622997ff28
[14:26:35][C][restart.button:017]: Restart Button 'rad Restart'
[14:26:35][C][captive_portal:088]: Captive Portal:
[14:26:35][C][mdns:108]: mDNS:
[14:26:35][C][mdns:109]: Hostname: rad
[14:26:36][C][ota:093]: Over-The-Air Updates:
[14:26:36][C][ota:094]: Address: rad.**********:8266
[14:26:36][C][ota:097]: Using Password.
[14:26:36][C][api:138]: API Server:
[14:26:36][C][api:139]: Address: rad.**********:6053
[14:26:36][C][api:143]: Using noise encryption: NO
[14:26:36][C][wifi_signal.sensor:009]: WiFi Signal 'rad_wifi_signal'
[14:26:36][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[14:26:36][C][wifi_signal.sensor:009]: State Class: 'measurement'
[14:26:36][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[14:26:36][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[14:26:38][D][sensor:093]: 'rad_wifi_signal': Sending state -57.00000 dBm with 0 decimals of accuracy
[14:26:51][D][dallas.sensor:143]: 'Framledning': Got Temperature=23.3°C
[14:26:51][D][sensor:093]: 'Framledning': Sending state 23.31250 °C with 1 decimals of accuracy
[14:26:51][D][dallas.sensor:143]: 'Retur': Got Temperature=23.1°C
[14:26:51][D][sensor:093]: 'Retur': Sending state 23.06250 °C with 1 decimals of accuracy
[14:27:08][D][sensor:093]: 'rad_wifi_signal': Sending state -57.00000 dBm with 0 decimals of accuracy
[14:27:08][D][sensor:093]: 'rad_Uptime Sensor': Sending state 185202.01562 s with 0 decimals of accuracy
[14:27:11][D][dallas.sensor:143]: 'Framledning': Got Temperature=23.2°C
[14:27:11][D][sensor:093]: 'Framledning': Sending state 23.25000 °C with 1 decimals of accuracy
nylund
(Nicklas Nylund)
May 26, 2023, 5:57am
7
Seems like a totally different problem?
nylund
(Nicklas Nylund)
May 26, 2023, 6:47am
8
Here is a screenshot showing what I mean. It is from a friends HA.
There you see the “firmware” sensor that I don’t have.
nickrout
(Nick Rout)
May 26, 2023, 9:43am
9
Yes but you did say that you were referring to an update entity. Update - Home Assistant
Blacky
May 26, 2023, 10:56am
10
Could you have a look at your api, I remember this was talked about and may not help but is an idea.
api:
encryption:
key: !secret encryption_key
EDIT: More information here
If you run ESPHome separately from HA (separate Docker container, for example) and have existing ESPHome devices that are now warning about deprecated passwords following an HA update to 2023.2 or later , here’s how to fix:
Go here , and copy the randomly-generated base64 key (or generate your own).
[image]
In your ESPHome configuration for each device, find the lines:
api:
password: "YOUR_PASSWORD"
Replace it with this, substituting in the key from above:
api:
encryption:
key: "YOUR…
nylund
(Nicklas Nylund)
May 27, 2023, 7:46am
11
I did change from password to encryption key long time ago.
Strange is that the sensors now have been created and seems to work.
I added this to only one of my sensors:
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: ${device_name} ESPHome Version
After installing (compiling) the firmware update sensor was created for all esphome devices.
But, I also got a new esphome version that I installed at the same time so I’m not sure what solved the problem…
Sorry for my late response.
Apparently I misunderstood the problem.
In my case the problem was that I could not anymore update the firmware of one of my ESP devices because it was missing from the ESPHome Dashboard, and the link provided me with the solution.
The solution in my case was to copy back a Yaml file for the device in the config/esphome folder.
But your problem indeed is different.
