I have just updated to 79.2 and have no GUI. This is my error log - but the last line about the pychromecast sticks out. would this prevent the GUI from loading? If so - how would I solve this?
core-ssh:~# hassio ha logs
Error decoding json invalid character '-' after top-level value: 2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setting up map
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded notify.pushbullet from homeassistant.components.notify.pushbullet
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setting up notify
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded light.lightwave from custom_components.light.lightwave
2018-10-02 12:49:21 WARNING (MainThread) [homeassistant.loader] You are using a custom component for light.lightwave which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setting up cast
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setup of domain cast took 0.0 seconds.
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds.
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setting up discovery
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.2 seconds.
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.setup] Setting up updater
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded sensor.yr from homeassistant.components.sensor.yr
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded sensor.wunderground from homeassistant.components.sensor.wunderground
2018-10-02 12:49:21 INFO (MainThread) [homeassistant.loader] Loaded sensor.darksky from homeassistant.components.sensor.darksky
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded sensor.hue from custom_components.sensor.hue
2018-10-02 12:49:22 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.hue which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded sensor.template from homeassistant.components.sensor.template
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setting up sensor
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setting up group
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.components.notify] Setting up notify.pushbullet
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.wunderground
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hue
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.darksky
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.template
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.4 seconds.
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setting up tts
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setting up cloud
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setting up logbook
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setup of domain ifttt took 2.5 seconds.
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setting up conversation
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.1 seconds.
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setting up config
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.device_registry from homeassistant.components.config.device_registry
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.entity_registry from homeassistant.components.config.entity_registry
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.config_entries from homeassistant.components.config.config_entries
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.script from homeassistant.components.config.script
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.auth from homeassistant.components.config.auth
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.loader] Loaded config.auth_provider_homeassistant from homeassistant.components.config.auth_provider_homeassistant
2018-10-02 12:49:22 INFO (MainThread) [homeassistant.setup] Setting up media_player
2018-10-02 12:49:23 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.3 seconds.
2018-10-02 12:49:23 INFO (MainThread) [homeassistant.loader] Loaded media_player.cast from homeassistant.components.media_player.cast
2018-10-02 12:49:23 WARNING (SyncWorker_8) [homeassistant.components.sensor.darksky] Monitored condition temperature_min is deprecated
2018-10-02 12:49:23 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast
2018-10-02 12:49:23 WARNING (SyncWorker_8) [homeassistant.components.sensor.darksky] Monitored condition temperature_max is deprecated
2018-10-02 12:49:23 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.7 seconds.
2018-10-02 12:49:23 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.9 seconds.
2018-10-02 12:49:24 INFO (SyncWorker_4) [pychromecast] Querying device status
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setup of domain group took 3.0 seconds.
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 3.0 seconds.
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setting up switch
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setting up automation
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setting up light
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setting up script
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.components.switch] Setting up switch.lightwave
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.components.light] Setting up light.lightwave
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.3 seconds.
2018-10-02 12:49:25 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 4.7 seconds.
2018-10-02 12:49:26 INFO (SyncWorker_12) [pychromecast] Querying device status
2018-10-02 12:49:26 INFO (SyncWorker_13) [pychromecast] Querying device status
2018-10-02 12:49:26 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 1.1 seconds.
2018-10-02 12:49:26 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new media_player.cast entity: media_player.kitchen_bass
2018-10-02 12:49:26 INFO (SyncWorker_0) [pychromecast] Querying device status
2018-10-02 12:49:26 INFO (MainThread) [homeassistant.setup] Setup of domain light took 1.1 seconds.
2018-10-02 12:49:26 INFO (MainThread) [homeassistant.loader] Loaded light.hue from homeassistant.components.light.hue
2018-10-02 12:49:26 INFO (MainThread) [homeassistant.components.light] Setting up light.hue
2018-10-02 12:49:26 INFO (SyncWorker_6) [pychromecast] Querying device status
2018-10-02 12:49:26 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new media_player.cast entity: media_player.bass_group
2018-10-02 12:49:26 INFO (SyncWorker_14) [pychromecast] Querying device status
2018-10-02 12:49:26 INFO (SyncWorker_15) [pychromecast] Querying device status
2018-10-02 12:49:26 INFO (SyncWorker_16) [pychromecast] Querying device status
2018-10-02 12:49:27 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 2.0 seconds.
2018-10-02 12:49:27 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.asuswrt
2018-10-02 12:49:27 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.google_maps
2018-10-02 12:49:31 INFO (SyncWorker_18) [homeassistant.components.device_tracker.asuswrt] Checking Devices
2018-10-02 12:49:31 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 6.4 seconds.
2018-10-02 12:50:06 ERROR (SyncWorker_13) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
