Here is a cap with DNS fallback disabled. Please tell WHERE is 1 single query for my DNS server which is at x.5.
22:06:06.446890 IP 172.16.101.3.41108 > 172.16.101.1.53: UDP, length 43
22:06:08.448235 IP 172.16.101.3.41108 > 172.16.101.1.53: UDP, length 43
22:06:10.450074 IP 172.16.101.3.41108 > 172.16.101.1.53: UDP, length 43
22:06:12.451042 IP 172.16.101.3.41108 > 172.16.101.1.53: UDP, length 43
22:06:14.451968 IP 172.16.101.3.41108 > 172.16.101.1.53: UDP, length 43
22:06:49.028685 IP 172.16.101.3.54770 > 172.16.101.1.53: UDP, length 58
22:06:49.029105 IP 172.16.101.3.45537 > 172.16.101.1.53: UDP, length 58
22:06:49.057747 IP 172.16.101.3.47573 > 172.16.101.1.53: UDP, length 47
22:06:49.057946 IP 172.16.101.3.57946 > 172.16.101.1.53: UDP, length 47
22:06:49.058115 IP 172.16.101.3.39126 > 172.16.101.1.53: UDP, length 47
22:06:49.058266 IP 172.16.101.3.42785 > 172.16.101.1.53: UDP, length 47
22:06:49.058567 IP 172.16.101.3.43193 > 172.16.101.1.53: UDP, length 47
22:06:49.058727 IP 172.16.101.3.38901 > 172.16.101.1.53: UDP, length 47
22:06:49.058913 IP 172.16.101.3.55489 > 172.16.101.1.53: UDP, length 47
22:06:49.059149 IP 172.16.101.3.38155 > 172.16.101.1.53: UDP, length 47
22:06:49.059343 IP 172.16.101.3.45908 > 172.16.101.1.53: UDP, length 47
22:06:49.059510 IP 172.16.101.3.45239 > 172.16.101.1.53: UDP, length 47
22:06:49.059752 IP 172.16.101.3.56844 > 172.16.101.1.53: UDP, length 47
22:06:49.059875 IP 172.16.101.3.49142 > 172.16.101.1.53: UDP, length 47
22:06:49.060077 IP 172.16.101.3.51005 > 172.16.101.1.53: UDP, length 47
22:06:49.060229 IP 172.16.101.3.49349 > 172.16.101.1.53: UDP, length 47
22:06:49.060358 IP 172.16.101.3.42820 > 172.16.101.1.53: UDP, length 47
22:06:54.063091 IP 172.16.101.3.47031 > 8.8.8.8.53: UDP, length 47
22:06:54.063099 IP 172.16.101.3.60463 > 8.8.8.8.53: UDP, length 47
22:06:54.063108 IP 172.16.101.3.50104 > 8.8.8.8.53: UDP, length 47
22:06:54.063111 IP 172.16.101.3.39378 > 8.8.8.8.53: UDP, length 47
22:06:54.063111 IP 172.16.101.3.49634 > 8.8.8.8.53: UDP, length 47
22:06:54.063114 IP 172.16.101.3.42991 > 8.8.8.8.53: UDP, length 47
22:06:54.063192 IP 172.16.101.3.50457 > 8.8.8.8.53: UDP, length 47
22:06:54.063196 IP 172.16.101.3.46682 > 8.8.8.8.53: UDP, length 47
22:06:54.063197 IP 172.16.101.3.46074 > 8.8.8.8.53: UDP, length 47
22:06:54.063221 IP 172.16.101.3.46850 > 8.8.8.8.53: UDP, length 47
22:06:54.063232 IP 172.16.101.3.40393 > 8.8.8.8.53: UDP, length 47
22:06:54.063240 IP 172.16.101.3.47853 > 8.8.8.8.53: UDP, length 47
22:06:54.064135 IP 172.16.101.3.48863 > 8.8.8.8.53: UDP, length 47
22:06:54.064151 IP 172.16.101.3.34234 > 8.8.8.8.53: UDP, length 47
22:06:54.064250 IP 172.16.101.3.40359 > 8.8.8.8.53: UDP, length 47
22:06:54.137941 IP 172.16.101.3.54770 > 172.16.101.1.53: UDP, length 58
22:06:54.137952 IP 172.16.101.3.45537 > 172.16.101.1.53: UDP, length 58
22:06:59.068439 IP 172.16.101.3.49142 > 172.16.101.1.53: UDP, length 47
22:06:59.068445 IP 172.16.101.3.45908 > 172.16.101.1.53: UDP, length 47
22:06:59.068449 IP 172.16.101.3.51005 > 172.16.101.1.53: UDP, length 47
22:06:59.068451 IP 172.16.101.3.57946 > 172.16.101.1.53: UDP, length 47
22:06:59.068453 IP 172.16.101.3.38155 > 172.16.101.1.53: UDP, length 47
22:06:59.068453 IP 172.16.101.3.39126 > 172.16.101.1.53: UDP, length 47
22:06:59.068455 IP 172.16.101.3.43193 > 172.16.101.1.53: UDP, length 47
22:06:59.068456 IP 172.16.101.3.42785 > 172.16.101.1.53: UDP, length 47
22:06:59.068458 IP 172.16.101.3.47573 > 172.16.101.1.53: UDP, length 47
22:06:59.068459 IP 172.16.101.3.38901 > 172.16.101.1.53: UDP, length 47
22:06:59.068460 IP 172.16.101.3.45239 > 172.16.101.1.53: UDP, length 47
22:06:59.068461 IP 172.16.101.3.55489 > 172.16.101.1.53: UDP, length 47
22:06:59.068463 IP 172.16.101.3.49349 > 172.16.101.1.53: UDP, length 47
22:06:59.068550 IP 172.16.101.3.56844 > 172.16.101.1.53: UDP, length 47
22:06:59.068578 IP 172.16.101.3.42820 > 172.16.101.1.53: UDP, length 47
22:06:59.388097 IP 172.16.101.3.54770 > 172.16.101.1.53: UDP, length 47
22:06:59.388109 IP 172.16.101.3.45537 > 172.16.101.1.53: UDP, length 47
22:07:04.071700 IP 172.16.101.3.42991 > 8.8.8.8.53: UDP, length 47
22:07:04.071707 IP 172.16.101.3.50457 > 8.8.8.8.53: UDP, length 47
22:07:04.071715 IP 172.16.101.3.39378 > 8.8.8.8.53: UDP, length 47
22:07:04.071731 IP 172.16.101.3.47853 > 8.8.8.8.53: UDP, length 47
22:07:04.071821 IP 172.16.101.3.34234 > 8.8.8.8.53: UDP, length 47
22:07:04.073742 IP 172.16.101.3.49634 > 8.8.8.8.53: UDP, length 47
22:07:04.073745 IP 172.16.101.3.60463 > 8.8.8.8.53: UDP, length 47
22:07:04.073747 IP 172.16.101.3.46074 > 8.8.8.8.53: UDP, length 47
22:07:04.073867 IP 172.16.101.3.46682 > 8.8.8.8.53: UDP, length 47
22:07:04.073868 IP 172.16.101.3.40393 > 8.8.8.8.53: UDP, length 47
22:07:04.073871 IP 172.16.101.3.48863 > 8.8.8.8.53: UDP, length 47
22:07:04.073872 IP 172.16.101.3.46850 > 8.8.8.8.53: UDP, length 47
22:07:04.073874 IP 172.16.101.3.50104 > 8.8.8.8.53: UDP, length 47
22:07:04.073877 IP 172.16.101.3.47031 > 8.8.8.8.53: UDP, length 47
22:07:04.073878 IP 172.16.101.3.40359 > 8.8.8.8.53: UDP, length 47
22:07:04.638117 IP 172.16.101.3.45537 > 172.16.101.1.53: UDP, length 47
22:07:04.638133 IP 172.16.101.3.54770 > 172.16.101.1.53: UDP, length 47
22:07:09.888248 IP 172.16.101.3.58484 > 172.16.101.1.53: tcp 0
22:07:10.919441 IP 172.16.101.3.58484 > 172.16.101.1.53: tcp 0
22:07:12.935574 IP 172.16.101.3.58484 > 172.16.101.1.53: tcp 0
22:07:14.027409 IP 172.16.101.3.33133 > 172.16.101.1.53: UDP, length 47
22:07:14.027418 IP 172.16.101.3.49623 > 172.16.101.1.53: UDP, length 47
22:07:14.057040 IP 172.16.101.3.60792 > 172.16.101.1.53: UDP, length 47
22:07:14.057062 IP 172.16.101.3.53770 > 172.16.101.1.53: UDP, length 47
22:07:15.058229 IP 172.16.101.3.53053 > 172.16.101.1.53: UDP, length 47
22:07:15.058234 IP 172.16.101.3.38004 > 172.16.101.1.53: UDP, length 47
22:07:17.057835 IP 172.16.101.3.59427 > 172.16.101.1.53: UDP, length 47
22:07:17.057848 IP 172.16.101.3.40042 > 172.16.101.1.53: UDP, length 47
22:07:17.159550 IP 172.16.101.3.58484 > 172.16.101.1.53: tcp 0
22:07:19.032745 IP 172.16.101.3.35158 > 8.8.8.8.53: UDP, length 47
22:07:19.032757 IP 172.16.101.3.53370 > 8.8.8.8.53: UDP, length 47
22:07:19.062422 IP 172.16.101.3.54844 > 8.8.8.8.53: UDP, length 47
22:07:19.062423 IP 172.16.101.3.56652 > 8.8.8.8.53: UDP, length 47
22:07:20.057746 IP 172.16.101.3.45314 > 172.16.101.1.53: tcp 0
22:07:20.059588 IP 172.16.101.3.60460 > 8.8.8.8.53: UDP, length 47
22:07:20.059593 IP 172.16.101.3.40747 > 8.8.8.8.53: UDP, length 47
22:07:21.057430 IP 172.16.101.3.50848 > 172.16.101.1.53: UDP, length 47
22:07:21.057449 IP 172.16.101.3.35147 > 172.16.101.1.53: UDP, length 47
22:07:21.063597 IP 172.16.101.3.45314 > 172.16.101.1.53: tcp 0
22:07:22.041752 IP 172.16.101.3.38983 > 172.16.101.1.53: UDP, length 47
22:07:22.041804 IP 172.16.101.3.38520 > 172.16.101.1.53: UDP, length 47
22:07:22.059700 IP 172.16.101.3.38217 > 8.8.8.8.53: UDP, length 47
22:07:22.059724 IP 172.16.101.3.57736 > 8.8.8.8.53: UDP, length 47
22:07:22.067726 IP 172.16.101.3.53499 > 172.16.101.1.53: UDP, length 47
22:07:22.069740 IP 172.16.101.3.60690 > 172.16.101.1.53: UDP, length 47
22:07:23.066717 IP 172.16.101.3.36145 > 172.16.101.1.53: UDP, length 47
22:07:23.066737 IP 172.16.101.3.48992 > 172.16.101.1.53: UDP, length 47
22:07:23.079524 IP 172.16.101.3.45314 > 172.16.101.1.53: tcp 0
22:07:25.065837 IP 172.16.101.3.42791 > 172.16.101.1.53: UDP, length 47
22:07:25.065842 IP 172.16.101.3.38745 > 172.16.101.1.53: UDP, length 47
22:07:26.062496 IP 172.16.101.3.56899 > 8.8.8.8.53: UDP, length 47
22:07:26.062540 IP 172.16.101.3.39135 > 8.8.8.8.53: UDP, length 47
22:07:27.047020 IP 172.16.101.3.34365 > 8.8.8.8.53: UDP, length 47
22:07:27.047058 IP 172.16.101.3.56746 > 8.8.8.8.53: UDP, length 47
22:07:27.073061 IP 172.16.101.3.41917 > 8.8.8.8.53: UDP, length 47
22:07:27.074981 IP 172.16.101.3.34683 > 8.8.8.8.53: UDP, length 47
22:07:27.143596 IP 172.16.101.3.45314 > 172.16.101.1.53: tcp 0
22:07:28.072033 IP 172.16.101.3.49425 > 8.8.8.8.53: UDP, length 47
22:07:28.072049 IP 172.16.101.3.53660 > 8.8.8.8.53: UDP, length 47
22:07:29.058434 IP 172.16.101.3.55070 > 172.16.101.1.53: UDP, length 47
22:07:29.058441 IP 172.16.101.3.45913 > 172.16.101.1.53: UDP, length 47
22:07:29.068275 IP 172.16.101.3.40218 > 172.16.101.1.53: UDP, length 47
22:07:29.068290 IP 172.16.101.3.43348 > 172.16.101.1.53: UDP, length 47
22:07:30.070882 IP 172.16.101.3.42773 > 8.8.8.8.53: UDP, length 47
22:07:30.070884 IP 172.16.101.3.51353 > 8.8.8.8.53: UDP, length 47
22:07:30.138178 IP 172.16.101.3.54404 > 172.16.101.1.53: UDP, length 47
22:07:30.138184 IP 172.16.101.3.50634 > 172.16.101.1.53: UDP, length 47
22:07:34.060442 IP 172.16.101.3.54498 > 8.8.8.8.53: UDP, length 47
22:07:34.063570 IP 172.16.101.3.50462 > 8.8.8.8.53: UDP, length 47
22:07:34.073654 IP 172.16.101.3.49128 > 8.8.8.8.53: UDP, length 47
22:07:34.073665 IP 172.16.101.3.34218 > 8.8.8.8.53: UDP, length 47
22:12:42.842049 IP 172.16.101.3.56371 > 172.16.101.1.53: UDP, length 43
22:12:44.843152 IP 172.16.101.3.56371 > 172.16.101.1.53: UDP, length 43
22:12:46.843469 IP 172.16.101.3.56371 > 172.16.101.1.53: UDP, length 43
22:12:48.850842 IP 172.16.101.3.56371 > 172.16.101.1.53: UDP, length 43
22:12:50.851830 IP 172.16.101.3.56371 > 172.16.101.1.53: UDP, length 43
22:17:47.586864 IP 172.16.101.3.33441 > 172.16.101.1.53: UDP, length 43
22:17:49.589016 IP 172.16.101.3.33441 > 172.16.101.1.53: UDP, length 43
22:17:51.590467 IP 172.16.101.3.33441 > 172.16.101.1.53: UDP, length 43
22:17:53.591385 IP 172.16.101.3.33441 > 172.16.101.1.53: UDP, length 43
22:17:55.592539 IP 172.16.101.3.33441 > 172.16.101.1.53: UDP, length 43
There is not 1. Instead now its trying google and my gateway. I have set my DNS server static.
