No internet
hello everyone. where i can get old version hassio 0.114.4 and 0.115.2 img files? new os for me not working i have back up files for 114 and 115. my sd card broken i buy new one but i was forget to clone old sd card now im stuck as cant found any more his versions and new on not working cant nothing install it just looks like everything frozen no errors in log. any one have his img files for raspberry pi 4? thank you
any one have? please help to get old os. or maybe someone cant share working sd card cloned img ?
What installation method were/are you using?
balena or rufus flash sd.fallow official guide
So hassos?
yes 5.9 im try as i dont found any more 0.114.4 and 0.115.2
If you click the link I kindly pasted for you it has every single release in it going back a very long time, including all the individual images available for download.
i need to try all versions from begining till i found again worked version
You can probably just do it by date, if you think back to when you last upgraded, and just go back to that date and use that version.
i try it still how hassio os 4.2 not 0.114.4 and supervision 2020.12…
whan i select backup file it shows version 0.114.4 it back up and give tons of errors.
here is my worked back up
after i buck up it give alot errors and nothing works
Probably best to do a fresh installation with the latest version and then slowly copy over your configuration bit by bit and correct any problems as you go.
problem is fresh sd with 5.9 latest version not working nothing cant install nothing it just show install intergration and it stay over 1h it like frozen and all versions from 5.9 to 4.0 same. dont know reason why not working i do everything fallow official install guide i cant post log of forum limitation for new user.can you make your sd card back up and share for my? please as i spend 2 days and cant it make working for some reason any of version not working and i dont know why
thanks for help but i found openhab less function but working great installing be a guide without trouble. homeassistant all versions still not working at all for some reason
What you need to realise is that between the version you have a backup of and the current version there have been changes which may have been ‘breaking changes’ for some of your config. It just depends on what integrations you use. You can read the blog posts for each version between your old one and now to see what those breaking changes were. Either that or you have done something wrong to cause the issue since HA is actually really quite stable these days.
As Marc suggested: Install the latest HA and copy across you config bit by bit to see where the issue is.
HA is miles ahead of OpenHAB in my opinion.
so can you tell me reason of fresh sd card ha not working also? like mark say install latest ha i install same nothing work even on fresh install cant install anything even after first boot weather not working. yes openhab is less function and other stuff but it works from first time of boot. like i say im try many times different versions from 0, also with backups nothing working, even from 0 cant get it run. i dont do nothing special just fallow official guide download right os fallow my raspbery burn in be guide balenaether boot, create user,password and result no weeather, try install simple speedtest.net result not instaling spin over 1h without result
Maybe for most, certainly not all… just like H, works fine for most, today not for you.
So are you saying that a fresh SD card with the latest (2020.12.1) version of HA (using HA OS) and it works, so it does load on first boot?
Where is this ‘spinning’? Does the RPi have an internet connection? Are the network settings properly configured?
fresh install latest ha 5.9 insert in to raspberry, wait 20min, create user,password, and no weather try install speedtest nothing not instaling. it show please wait intergration installing. ofcourse it have internet im use cable wot network configuration you need? plug cable and works. problem is no mater is fresh os or fresh os with backup nothing not working. i need to get old 0.114.4 and 0.115.2 img files. his 2 100% from first boot have weather and all installings work as shut work. now with his all versions nothing notworking. i dont understand point of create official installing guide if fallow guide homeassistant after boot not functional at all. im try 4 different sd cards, 2 different raspberry pi’s, 3 different routers, dirrectly internet cable from modem, different wifi, still homeassistant not working how shut working. no matter i have finish set up open hab it works great all my light/socket control back to normally working. admins can close his post as im not wasting any more my time to try get work ha not worst at all just wasting time. os shut working perfect after oficial guide installing not after install need to figure out why not working an bla bla bla
Bye. Given that others have NO issues doing a fresh install there must be something that you are not doing correctly, but hey. No logs, no answers.
I think this should be made a sticky and added to Tinkerers post to show an example of diagnosing without any information.
