same erors nothing different
From you CLI in Home Assistant, try to Ping 8.8.8.8
Ok, so once it finishes you should be able to create your user etc during the onboarding. Don’t try loading your old backup file because clearly there is an issue with it. My guess is that something has changed in between the version of your backup and the current version. One of those likely being the Met.no integration since that’s the error you had earlier. What you can do is progressively copy across bits of your old code making sure to run a config check each time. At some point you will find the culprit.
i set lan and 5g wifi now it looks like working as i see weather and no more error. now question is it works on lan or wifi
Awesome! I was sure it was a network config issue. Glad you got it sorted.
how i can disable wifi?
Remove the wifi settings in the file on the USB stick you previously used, plug it back into the RPi and reboot.
HA will update it’s network settings and you can then unplug the USB again.
i dont use usb his time i do directly in supervisor /system/host system change network settings. so i can reset network be usb. ok i will reboot as for now it looks works everything fine
Yeah, I’ve never had to do it so I wasn’t sure if there was an easier way.
it was so easy o go on lan0 type my detail after to wlan0 select my wifi type pass reboot and everythng works fine. just not sure it works on cable or wifi
now i can tell exactly problem why rpi not working. it was not my fault but official guide for network setup
fallow guide shut be
[ipv4]
method=manual
address=192.168.1.111/24;192.168.1.1
dns=8.8.8.8;8.8.4.4;
my setting directly in supervisor on cable
[ipv4]
method=manual
address=192.168.1.22/24
getaway=255.255.255.128
dns=89.42.108.254
it works now how shut work
The guide gives you an example. You still need to change the settings to suit your network.
Also, you have a typo- ‘getaway’ should be ‘gateway’
yesterday was working fine today i shut down network as allocated router to other room and again no internet connection
