Same here. According to their faq, they track their service health at http://www.intodns.com/duckdns.org and you can see many errors there. Not sure how to report it to them though…
It’s not a router issue, it’s a propagation issue of Duckdns. Other DNS authorities loosing intermittent DNS entries…
Check it here https://dnspropagation.net/
I have the same issue, just that google thought to make my life hell and added Deceptive website label to my HA, so I lost many hours trying to figure out if I have been hacked, when in fact it was duckdns dying out that most likely generated all the problems.
Changing dyndns now means reconfiguring lots of stuff for everything manually linked but there is no way around it apparently.
Same problem here started 1 oct. Reset everything.(restored backups) factory reset router/modem. days/night work.
Didn’t work. sometimes I get connection and 2 min later its gone. Hope they fix this.
I run three HA setups at three different locations with three different routers, all with a DuckDNS setup. All facing the problem since yesterday… definitely not a „router issue“.
Having issues with duckdns resolving, been about 2nd day now, hence reaching out.
I am using haproxy, and needed to find out where the issue could be, thanks for raising this post.
I switched before years from duckdns to cloudflare since the problems with duckdns come again and again.
If you have a spare domain, you can use this as an alternative to duckdns:
Works like a charm, i had 0 problems since i switched.
Now I think about it, it started for me around noon as well. Something might have been deactivated/changed around noon at the 1st of October on their end I tried to find a channel where I can find some updates on the issue by the DuckDNS-team, but I cannot find it.
Same problem here. I can only reach my home assistant locally. The problems started yesterday. I’ve restarted duckdns several times but unfortunately it won’t work.
Is there a file where the URL is stored in order to change it back to homeassistant.local:8123?
In mean somewhere in the config folder or another folder which can be accessed via network share.
