Hi there @yonny24, I set one up yesterday with a .tk from freenom. What can I look out for that might indicate that it’s not working as expected?
I already have a domain so probably should have just used that, but I wasn’t sure if it would conflict with the hosting I already have setup on it, even if it was with a subdomain.
So, found the problem to my issue: Somehow duckdns add-on has uninstalled itself from home assistant and that’s why the IP was not updated anymore → no connection.
Bingo! DuckDNS was not reachable again on 2023-03-08!
The site was, but not the DNS service… Next day, it was OK again.
Perhaps Cloudflair is a better alternative? I don’t know…
I pulled the plug on DuckDNS yesterday. Too unreliable. Went to NabuCasa remote access. Might switch to Cloudflare or Dynu in the future, but working now at least. Goodbye and good riddens DuckDNS. As always in life, you get what you pay for…
Sounds helpfull and i want to try it because i have the same issue, but how can i acces my homeassistant to adjust these settings? because the local ip is not working anymore for me since i setup the cloudflare tunnel.
DuckDNS has worked pretty good for more than half a year for me, but Tuesday this week I had problems connecting and after some hour it worked again.
Today I have problems connecting now and then and then it works for a while…
Have tried to connect to external IP (and LAN IP via VPN) and that works perfectly fine all the time.
Have not seen anything in the logs until now - this just came in there - but doesn’t say me much:
Logger: frontend.js.latest.202308021
Source: components/system_log/init.py:270
First occurred: 12:28:52 (1 occurrences)
Last logged: 12:28:52
https://xxxxxx.duckdns.org:YYYY/frontend_latest/core-WCIePk4vYnw.js:1:8205 Uncaught Error: Suspend promise not set
(xxxx=domain name YYYY=port number)
What a coinsidence… I had a letsencrypt setup broken for past few weeks and didn’t noticed that until my certificate expired today. After fixing it I spent few hours investigating why I can’t renew these damn certificates only to find out, duckdns is causing all of this… What a shame, I will consider switching to some paid option.
thanks…even though I don’t wish any other problems, it feels good to know for sure it’s outside my stuff and hopefully someone else (duckdns) will solve it soon.
I have seen a few reports on downdetector and updownradar now as well
