The previous threads about missing cogs in the pop-up GUI windows all reference mistakenly using capital letters in the entity ID. I seem to have lost all cogs for all devices (couple dozen switches and a handful of sensors) and I still have the default all-lower case entity IDs. I just want to rename the sensor directly on the pop-up window and can’t seem to do this because the cog is gone.
I’ve searched last few release notes, and the online docs still reference using it. They still don’t appear even when I try in Edge (normally use Chrome). Any ideas?
@aidbish thanks but I was trying to avoid that. I’ve just done a clean install for the very reason that my entity registry was a bit of a mess due to previous manual renames. I’ll wait for it to be fixed so can rename devices via the ui.
I am seeing this issue in 0.91.3 (docker as well). Removed the entire instance and started completely clean only to find that this “feature” is now present. One thought was probably a feature added to limit “permissions” for users you can create/setup within HASS. But I am using admin account… So, it is a bug then OR the new feature…
present in 0.91.4 as well. Probably the new way of doing things now.
I wish these changes are documented so laymen like me don’t get all wired up thinking something is wrong.
