I feel like I am missing something obvious. I keep reading the instructions but don’t see any way to put my stick into inclusion mode.
I followed the steps to install my homeseer smart stick in the zwave js add=on. I believe my stick was recognized and installed. I see a bunch of security key values that were generated in the config.
Now - where do I go to put the device into inclusion mode?
I tried going to:
Settings->Device and Services->Devices and choosing zwave-js.
From there what I am supposed to click on? Under the configuration widget, the only option is Update and it say up to date.
I don’t see anything else related to z-wave anywhere in the UI.
Thanks!
In Setting -) Devices and Services -) ZWave:
Then click on devices and lower right on Add Device:
Thanks - as I expected; I was in the wrong place and missed the obvious ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=12)
Z-wave-JS Has it’s own UI. All the Z-wave options like rescan, change parameters, Network Map, etc. can be found there.
To conveniently get to the UI, enable it in the sidebar. Settings > Add-ons > Z-wave JS UI. Then toggle “Show in sidebar”.
![image](https://community-assets.home-assistant.io/original/4X/d/a/f/daf71f4fc6289159ba32129d4d4524e7dbe229b3.png)
After that an entry is created in the sidebar
![image](https://community-assets.home-assistant.io/original/4X/2/f/5/2f5c7030a9109197bf1eda5150aa83ac6836d1de.png)
You can also open the UI directly in the Add-on page by clicking “OPEN WEB UI”.
![image](https://community-assets.home-assistant.io/original/4X/2/8/f/28f1b90fff5a63aabc95f05989a723deccc8040c.png)
You are right and I use both. It is just that I find the above method more convenient.
Yes, I agree. Just wanted to point out to the OP there is a whole UI to Z-wave JS UI when they need the additional features outside of adding devices.
Can js ui coexist with js without disabling the other?
