Hello there,
After Playing around a little bit in a VM, I installed HAOS on the NUC I was running the VM on using a portable Ubuntu and etcher to write the image to the ssd. (Making an bootable USB Stick never installed HAOS on the SSD)
After my first Login i was greeted by problems initialising the connection for the weather and Radio Integration.
Also trying to connect to the detected Tado API I only got an Error “Unexpected exeption”
Tried restarting multiple times and changing the DNS to 1.1.1.1
I don’t really know what to do or how to troubleshoot the problem, hope you can help me or can link to a similat Thread.
Lukas
The Logs:
2023-08-27 17:17:21.553 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Radio Browser' for radio_browser integration not ready yet: Could not connect to Radio Browser API; Retrying in background
2023-08-27 17:17:26.968 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2023-08-27 17:17:27.003 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Home' for met integration not ready yet: Update failed: ; Retrying in background
2023-08-27 17:17:38.102 WARNING (MainThread) [homeassistant.components.media_player] Error retrieving proxied image from http://10.23.9.26:1400/getaa?s=1&u=x-sonos-http:track%253a1230752593.mp3?sid%3D160%26flags%3D8232%26sn%3D8
2023-08-27 17:17:40.071 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Error requesting homeassistant_alerts data: Cannot connect to host alerts.home-assistant.io:443 ssl:default [Try again]
2023-08-27 17:17:40.082 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2023-08-27 17:17:55.398 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2023-08-27 17:18:20.472 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2023-08-27 17:19:05.587 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2023-08-27 17:20:31.023 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2023-08-27 17:21:56.419 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2023-08-27 17:23:21.497 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2023-08-27 17:24:01.933 ERROR (MainThread) [homeassistant.components.tado.config_flow] Unexpected exception
File "/usr/local/lib/python3.11/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.11/site-packages/urllib3/util/connection.py", line 72, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.11/socket.py", line 962, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py", line 714, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py", line 403, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py", line 1053, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.11/site-packages/urllib3/connection.py", line 363, in connect
self.sock = conn = self._new_conn()
File "/usr/local/lib/python3.11/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7f21a739d350>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.11/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py", line 798, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.11/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='auth.tado.com', port=443): Max retries exceeded with url: /oauth/token?client_id=tado-web-app&client_secret=wZaRN7rpjn3FoNyF5IFuxg9uMzYJcvOoQ8QWiIqS3hfk6gLhVlG57j5YNoZL2Rtc&grant_type=password&password=Test&scope=home.user&username=lukashix%40gmail.com (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f21a739d350>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/src/homeassistant/homeassistant/components/tado/config_flow.py", line 74, in async_step_user
validated = await validate_input(self.hass, user_input)
File "/usr/src/homeassistant/homeassistant/components/tado/config_flow.py", line 41, in validate_input
tado = await hass.async_add_executor_job(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.11/site-packages/PyTado/interface.py", line 535, in __init__
self._loginV2(username, password)
File "/usr/local/lib/python3.11/site-packages/PyTado/interface.py", line 158, in _loginV2
response = self._http_session.request("post", url, params=data, timeout=self.timeout, data=json.dumps({}).encode('utf8'),
File "/usr/local/lib/python3.11/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.11/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.11/site-packages/requests/adapters.py", line 519, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='auth.tado.com', port=443): Max retries exceeded with url: /oauth/token?client_id=tado-web-app&client_secret=wZaRN7rpjn3FoNyF5IFuxg9uMzYJcvOoQ8QWiIqS3hfk6gLhVlG57j5YNoZL2Rtc&grant_type=password&password=Test&scope=home.user&username=lukashix%40gmail.com (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f21a739d350>: Failed to establish a new connection: [Errno -3] Try again'))
2023-08-27 17:24:46.769 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
