These are commands run at initialization (hence init_commands) as Node-RED starts up.
If you still have the ‘patch’ from last year, then this command must be removed.
This won’t help anyone having issues right now but having been burned a few times on NR major releases I have found it to be best practice to wait until a x.0.1 release before attempting the upgrade. I am all about cutting edge adoption but NR is a pivotal part of my automation environment so I wait.
The update (version: 18.0.1) also started correctly for me after Removing “sed -i “772,775d” /opt/node_modules/@node-red/util/lib/util.js” from ‘init_commands’
I did not apply the patch myself last year and could not make sense of the OP error message until @d_tech and @walberjunior posted, so they should get the credit.
Does 18.0.3 correct this or does it still require the change to init commands? I don’t believe I ever entered that work around but didn’t want to find out after I updated if it can be avoided.
My understanding is the init command was a workaround for people who didn’t want to fix the issue “right”, and so is not anything that will be fixed. But I could be wrong.
FWIW I instralled 18.0.3 last night and had no issues (but I also had not edited the startup sequence).
If you have this command in your configuration, it needs to be removed. It was a temporary fix for a certain problem. If you are using the addon, goto the configuration tab on the addon page.
Scroll down to init commands, do you have an entry for sed -i “772,775d” /opt....? No you can upgrade without worrying about this. If it is there upgrade NR and then remove the command from the configuration and restart.
