Node Red addon Whitescreen
stopped working around the 6th and havent been able to get it back up…
output from log where it goes to trash
  npm audit fix
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[07:03:16] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
15 Jan 07:03:21 - [info]
Welcome to Node-RED
15 Jan 07:03:21 - [info] Node-RED version: v3.0.2
15 Jan 07:03:21 - [info] Node.js  version: v18.12.1
15 Jan 07:03:21 - [info] Linux 5.15.76-v8 arm64 LE
15 Jan 07:03:23 - [info] Loading palette nodes
15 Jan 07:03:34 - [info] Dashboard version 3.2.3 started at /endpoint/ui
15 Jan 07:03:37 - [warn] ------------------------------------------------------
15 Jan 07:03:37 - [warn] [node-red-contrib-noble/noble] Error: Cannot find module 'bluetooth-hci-socket'
Require stack:
- /config/node-red/node_modules/noble/lib/hci-socket/hci.js
- /config/node-red/node_modules/noble/lib/hci-socket/bindings.js
- /config/node-red/node_modules/noble/lib/resolve-bindings.js
- /config/node-red/node_modules/noble/index.js
- /config/node-red/node_modules/node-red-contrib-ignoble/ignoble-node.js
- /opt/node_modules/@node-red/registry/lib/loader.js
- /opt/node_modules/@node-red/registry/lib/index.js
- /opt/node_modules/@node-red/runtime/lib/nodes/index.js
- /opt/node_modules/@node-red/runtime/lib/index.js
- /opt/node_modules/node-red/lib/red.js
- /opt/node_modules/node-red/red.js
15 Jan 07:03:37 - [warn] [node-red-contrib-ignoble/noble] Error: Cannot find module 'bluetooth-hci-socket'
Require stack:
15 Jan 07:03:37 - [info] Settings file  : /etc/node-red/config.js
15 Jan 07:03:37 - [info] Context store  : 'default' [module=memory]
15 Jan 07:03:37 - [info] User directory : /config/node-red/
15 Jan 07:03:37 - [warn] Projects disabled : editorTheme.projects.enabled=false
15 Jan 07:03:37 - [info] Flows file     : /config/node-red/flows.json
(node:341) [DEP0128] DeprecationWarning: Invalid 'main' field in '/config/node-red/node_modules/javascript-opentimestamps/package.json' of 'open-timestamps.js'. Please either fix that or report it to the module author
(Use `node --trace-deprecation ...` to show where the warning was created)
15 Jan 07:03:37 - [info] Server now running at http://127.0.0.1:46836/
15 Jan 07:03:37 - [info] +-----------------------------------------------------
15 Jan 07:03:37 - [info] | uibuilder v6.0.0 initialised
15 Jan 07:03:37 - [info] | root folder: /config/node-red/uibuilder
15 Jan 07:03:37 - [info] | Using Node-RED's webserver at:
15 Jan 07:03:37 - [info] |   http://127.0.0.1:46836/endpoint/
15 Jan 07:03:37 - [info] | Installed packages:
15 Jan 07:03:37 - [info] Starting flows
[07:03:37] INFO: Starting NGinx...
15 Jan 07:03:37 - [info] Started flows
15 Jan 07:03:38 - [info] [server:Home Assistant] Connecting to http://supervisor/core
15 Jan 07:03:38 - [info] [server:Hassio] Connecting to https://v8bgtvjr8w4kzm0s7qy115zannzjfa2y.ui.nabu.casa/
15 Jan 07:03:38 - [error] [api-current-state:goV2] Entity could not be found in cache for entity_id: sensor.govee_two
15 Jan 07:03:38 - [error] [api-current-state:goV2] Entity could not be found in cache for entity_id: sensor.ble_humidity_a4c13840b6a3
15 Jan 07:03:38 - [error] [api-current-state:co2] Entity could not be found in cache for entity_id: sensor.co2
15 Jan 07:03:38 - [error] [api-current-state:AP Humidity] Entity could not be found in cache for entity_id: sensor.alderpoint_humidity
15 Jan 07:03:38 - [error] [api-current-state:AP Temp] Entity could not be found in cache for entity_id: sensor.alderpoint_temperature
15 Jan 07:03:41 - [warn] [csv:3d7c9fa820a3468b] Malformed CSV data - output probably corrupt.
got it to load in safe mode but the new release is fkd and damn near impossible to have my code work now
it says it cant read csv files?
Have you tried one of your backups prior to the 6th? Could it be a corrupt SD / file system?
found it
        "id": "b0bb61f9c3d068b8",
        "type": "csv",
        "z": "deb79f81e4ba7f60",
        "name": "",
        "sep": ",",
        "hdrin": "",
        "hdrout": "none",
        "multi": "one",
        "ret": "\\n",
        "temp": "",
        "skip": "0",
        "strings": true,
        "include_empty_strings": "",
        "include_null_values": "",
        "x": 1650,
        "y": 700,
        "wires": [
                "12582550baca173e"
adding false for the includes should be fine right?
@MaxK with the new update are we supposed to add the api node for home assistant when usin the node red addon inside home assistant to call service?
new update seems to have crashed my call service function nodes and also my csv parser
changed the home assistant call service to not call home assistant addon api but using long lasting token…see how that goes, i did like the ability to just know it worked because they were one program but oh well see how this goes
still havent figured out what the csv file expects included
I don’t.
Are there any nodes that need to be updated?
Anything in the debug window?
“TypeError: Cannot read properties of undefined (reading ‘includes’)”
i would add export of program but its too large
heres the front few nodes
        "id": "94ae320a7f2aae7a",
        "type": "api-current-state",
        "name": "dose",
        "server": "a52fadfc.d75d",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "input_number.ph_dose",
        "state_type": "str",
        "blockInputOverrides": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "entity"
                "property": "topic",
                "value": "dose",
                "valueType": "str"
        "for": 0,
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 970,
        "y": 260,
        "wires": [
                "edd55a10f9fe46ce"
        "id": "d7b5efe95dda9d37",
        "name": "low",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.ph_low",
                "value": "",
                "property": "data",
                "value": "",
                "value": "low",
                "valueType": "str"
        "for": 0,
        "forType": "num",
        "x": 970,
        "y": 320,
        "wires": [
                "edd55a10f9fe46ce"
        "id": "33707ea677151864",
        "name": "high",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.ph_high",
                "value": "",
                "property": "data",
                "value": "",
                "value": "high",
                "valueType": "str"
        "for": 0,
        "forType": "num",
        "x": 970,
        "y": 380,
        "wires": [
                "edd55a10f9fe46ce"
        "id": "4c86ba645e6ebcc1",
        "name": "warn",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.ph_warn",
                "value": "",
                "property": "data",
                "value": "",
                "value": "warn",
                "valueType": "str"
        "for": 0,
        "forType": "num",
        "x": 970,
        "y": 440,
        "wires": [
                "edd55a10f9fe46ce"
        "id": "6e3283317d29cb31",
        "type": "switch",
        "name": "",
        "property": "payload.difference",
        "rules": [
                "t": "lte",
                "v": "3",
                "vt": "num"
                "t": "gte",
                "v": "4",
                "vt": "num"
        "checkall": "true",
        "repair": true,
        "outputs": 2,
        "x": 810,
        "y": 520,
        "wires": [
                "4c86ba645e6ebcc1",
                "33707ea677151864",
                "d7b5efe95dda9d37",
                "94ae320a7f2aae7a",
                "940b105763c6bf08",
                "15ce497af439d2ce",
                "b11ad83a55b9a03d",
                "e1af138b06734d45",
                "37fe55562b751139",
                "bfc674c5b5565421",
                "d484e054a4155287"
                "f7fb7d61cb77cf44"
        "id": "d53f7fbbd5c25227",
        "type": "function",
        "name": "Check Time",
        "func": "let lines = msg.payload\nlet dateFromFile = new Date(lines[lines.length - 2].col1).getTime()\nlet dateNow = new Date().getTime()\n\n\n//node.warn(dateFromFile);\n//node.warn(dateNow);\n\nlet difference = (dateNow - dateFromFile) / (1000 * 60)  // minutes\n\nmsg.payload = { \n          difference : difference,\n          col5 : lines[lines.length - 2].col5,\n          col4 : lines[lines.length - 2].col4,  \n          date : new Date().getTime()\n        \n    }\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 670,
        "y": 520,
        "wires": [
                "6e3283317d29cb31"
        "id": "007da55dfaeefa5b",
        "type": "join",
        "name": "ph",
        "mode": "custom",
        "build": "array",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 530,
        "y": 520,
        "wires": [
                "d53f7fbbd5c25227"
        "id": "940b105763c6bf08",
        "type": "change",
        "name": "SMC",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "smc",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload.col5",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 970,
        "y": 500,
        "wires": [
                "edd55a10f9fe46ce"
        "id": "b11ad83a55b9a03d",
        "name": "dose",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.ppm_dose",
                "value": "",
                "property": "data",
                "value": "",
                "value": "dose",
                "valueType": "str"
        "for": 0,
        "forType": "num",
        "x": 970,
        "y": 620,
        "wires": [
                "9e799741d1586fa1"
        "id": "e1af138b06734d45",
        "name": "low",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.ppm_low",
                "value": "",
                "property": "data",
                "value": "",
                "value": "low",
                "valueType": "str"
        "for": 0,
        "forType": "num",
        "x": 970,
        "y": 680,
        "wires": [
                "9e799741d1586fa1"
        "id": "37fe55562b751139",
        "name": "high",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.ppm_high",
                "value": "",
                "property": "data",
                "value": "",
                "value": "high",
                "valueType": "str"
        "for": 0,
        "forType": "num",
        "x": 970,
        "y": 740,
        "wires": [
                "9e799741d1586fa1"
        "id": "bfc674c5b5565421",
        "name": "warn",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.ppm_warn",
                "value": "",
                "property": "data",
                "value": "",
                "value": "warn",
                "valueType": "str"
        "for": 0,
        "forType": "num",
        "x": 970,
        "y": 800,
        "wires": [
                "9e799741d1586fa1"
        "id": "d484e054a4155287",
        "type": "change",
        "name": "SMC",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "smc2",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload.col4",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 970,
        "y": 860,
        "wires": [
                "9e799741d1586fa1"
        "id": "15ce497af439d2ce",
        "type": "change",
        "name": "SMC",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "date",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload.date",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 970,
        "y": 540,
        "wires": [
                "edd55a10f9fe46ce",
                "cca161c449f0039f"
        "id": "e9623b41612ce06e",
        "type": "file in",
        "name": "file",
        "filename": "/config/grogreen.csv",
        "filenameType": "str",
        "format": "lines",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 270,
        "y": 520,
        "wires": [
                "963969060c3a64e5"
        "id": "ea57bb65e5f106ed",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "600",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 110,
        "y": 520,
        "wires": [
                "e9623b41612ce06e"
        "id": "963969060c3a64e5",
        "type": "csv",
        "name": "csv",
        "sep": ",",
        "hdrin": "",
        "hdrout": "none",
        "multi": "one",
        "ret": "\\n",
        "temp": "",
        "skip": "0",
        "strings": true,
        "x": 390,
        "y": 520,
        "wires": [
                "007da55dfaeefa5b"
        "id": "a52fadfc.d75d",
        "type": "server",
        "name": "Home Assistant",
        "version": 2,
        "addon": false,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": true,
        "heartbeatInterval": "30"
open topic not allowing message to process correctly… silly but never caused an error until update
having call service error still with home assistant… may have to rebuild this with an automation instead if i can rely on NR to complete the process
