I am having the same issue but unlike in your case, I am still unable to uninstall the add-on.
Anyone have any ideas as to how this can be removed manually? I know of the folder location but am very hesistant to just delete it as that can cause other issues.
I’ve not used node-red so I decided to remove it from my implementation (on a Pi 4)
I’ve removed the node-red companion from HACS, I’ve removed the node-red integration from HA, I’ve deleted the node-red directory under config (there wasn’t one under share). But node red refuses to go away
I tried a reboot, and it happily repopulated the deleted directories.
Any suggestions on how to remove it?
UPDATED - you also have to remove it from “Add-Ons” ! Silly me.
