Simple install error…but I’m chasing my tail. Any suggestions appreciated.
clean build of HassIO (0.69.1), config wifi, boot - no issues
pi3, removed zwave stick. hassio.local resolves correctly (as does IP)
HassIO now asks for password on startup, using ‘password’, opens fine
install add-ons for samba (easy config file access) & Node-Red (via notoriousbdg)
start node red from add-on details - “Open Web UI”
No problems. Node-Red UI comes up (v 0.18.6), prompts for default UN/PW. (no mods to config yet)
add home-assistant to the palette - (node-red-contrib-home-assistant v0.3.2)
drag ‘call service’ node - double-click it (red triangle visible on the node)
Log in to hassio.local:1880 pop up. (the node-red port – use node red default un/pw)
Popup shows “Cannot GET /homeassistant/services” - fades out.
Solved - work around (from a tip in the discord channel from cavemanzzz)
Add an Inject Node (string “Hello Word”) and wired to Debug node.
Deployed it and confirmed basic nodes working
BAM! home-assistant now accessing correctly.
bloody hell – lost many many hours googling and scratching my head.
There is a bug in there but it can be worked around for now.
You should be able to deploy non-HA flows. You don’t need the HA plugin to use the add-on for generic flows (and would be pointless.) But getting any flow working and tested that doesn’t use the plug-in…then the plugin started working for me.
