Consider using Zigbee2MQTT binding before using this Node-Red flow (and probably only use this if your devices doesn’t support binding)
This is mostly about re-sharing the great work of NotEnoughTech (IKEA TRADFRI Wireless dimmer in NodeRED - NotEnoughTech), and also about some minor tweaks I did to:
- Make it work with the latest versions of software and/or hardware.
- Payload and button events did not work
- Be able to use it as a subflow with multiple lamps and remotes.
- Replaced hardcoded light and remote with subflow environment variables.
Here is how to use it:
And here is how the subflow looks:
And the code:
[{"id":"e5817ab55eab8ab8","type":"subflow","name":"Subflow: IKEA Light Dimmer","info":"","category":"","in":[],"out":[],"env":[{"name":"lightEntity","type":"str","value":""},{"name":"remoteEntity","type":"env","value":"NR_NODE_NAME"},{"name":"dimmerStep","type":"num","value":"15"},{"name":"lightTopic","type":"env","value":"zigbee2mqtt/${lightEntity}","ui":{"type":"hide"}},{"name":"remoteTopic","type":"env","value":"zigbee2mqtt/${remoteEntity}","ui":{"type":"hide"}},{"name":"lightTopicGet","type":"env","value":"${lightTopic}/get","ui":{"type":"hide"}},{"name":"lightTopicSet","type":"env","value":"${lightTopic}/set","ui":{"type":"hide"}}],"meta":{},"color":"#DDAA99"},{"id":"c786b38d.959c2","type":"switch","z":"e5817ab55eab8ab8","name":"Messages","property":"payload.action","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"},{"t":"eq","v":"brightness_stop","vt":"str"},{"t":"eq","v":"brightness_move_up","vt":"str"},{"t":"eq","v":"brightness_move_down","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":410,"y":340,"wires":[["e6af827.9be108"],["d39b4454.a0cc78"],["d9fd37b3.5511c8"],["dc0cf8a0.604028","359b8cf5.78b704"],["cebc76c0.d58538","359b8cf5.78b704"]]},{"id":"dc0cf8a0.604028","type":"function","z":"e5817ab55eab8ab8","name":"Brightness up","func":"var step = Number.parseInt(env.get('dimmerStep'));\nvar brightness = flow.get(\"IKEA_bulb1_brightness\");\n\nif(brightness > 0){\n brightness = brightness + step;\n flow.set(\"IKEA_bulb1_brightness\", brightness);\n\t}\n\t\nif(brightness >= 255){\n brightness = 254;\n flow.set('press', false);\n flow.set(\"IKEA_bulb1_brightness\", brightness);\n }\n\nmsg.payload = {\"state\":\"ON\",\n \"brightness\":brightness};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":580,"wires":[["aab4e92d.c91e28","51644345.67539c"]]},{"id":"cebc76c0.d58538","type":"function","z":"e5817ab55eab8ab8","name":"Brightness down","func":"var step = Number.parseInt(env.get('dimmerStep'));\nvar brightness = flow.get(\"IKEA_bulb1_brightness\");\n\nif(brightness <= 255){\n brightness = brightness - step; \n flow.set(\"IKEA_bulb1_brightness\", brightness);\n\t}\n\t\nif(brightness <= 0){\n brightness = 1;\n flow.set('press', false);\n flow.set(\"IKEA_bulb1_brightness\", brightness);\n }\n\nmsg.payload = {\"state\":\"ON\",\n \"brightness\":brightness};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":620,"wires":[["aab4e92d.c91e28","bf17a32.3347d6"]]},{"id":"b132cd47.5361c","type":"switch","z":"e5817ab55eab8ab8","name":"Control loop","property":"press","propertyType":"flow","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":970,"y":760,"wires":[["cebc76c0.d58538"]]},{"id":"420aac7b.c64574","type":"switch","z":"e5817ab55eab8ab8","name":"Control loop","property":"press","propertyType":"flow","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":970,"y":800,"wires":[["dc0cf8a0.604028"]]},{"id":"51644345.67539c","type":"delay","z":"e5817ab55eab8ab8","name":"","pauseType":"delay","timeout":"1000","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":680,"y":800,"wires":[["420aac7b.c64574"]]},{"id":"bf17a32.3347d6","type":"delay","z":"e5817ab55eab8ab8","name":"","pauseType":"delay","timeout":"1000","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":680,"y":760,"wires":[["b132cd47.5361c"]]},{"id":"359b8cf5.78b704","type":"change","z":"e5817ab55eab8ab8","name":"start","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":380,"wires":[["30695df.bdaa9a2"]]},{"id":"d9fd37b3.5511c8","type":"change","z":"e5817ab55eab8ab8","name":"stop","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":420,"wires":[["30695df.bdaa9a2"]]},{"id":"30695df.bdaa9a2","type":"change","z":"e5817ab55eab8ab8","name":"Control the loop","rules":[{"t":"set","p":"press","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":395,"wires":[[]]},{"id":"da10d307.eded8","type":"mqtt in","z":"e5817ab55eab8ab8","name":"IKEA Light","topic":"${lightTopic}","qos":"2","datatype":"json","broker":"eca6af44.5297b","nl":false,"rap":false,"inputs":0,"x":220,"y":200,"wires":[["8a13f8be.ca9058"]]},{"id":"aab4e92d.c91e28","type":"mqtt out","z":"e5817ab55eab8ab8","name":"IKEA Light Control","topic":"${lightTopicSet}","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"eca6af44.5297b","x":1050,"y":280,"wires":[]},{"id":"394c130c.943f4c","type":"mqtt out","z":"e5817ab55eab8ab8","name":"IKEA Light Status","topic":"${lightTopicGet}","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"eca6af44.5297b","x":570,"y":140,"wires":[]},{"id":"e79a3c52.ae408","type":"inject","z":"e5817ab55eab8ab8","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"state\":\"\"}","payloadType":"json","x":240,"y":140,"wires":[["394c130c.943f4c"]]},{"id":"e6af827.9be108","type":"function","z":"e5817ab55eab8ab8","name":"ON","func":"msg.payload = { \"state\":\"ON\"};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":650,"y":280,"wires":[["aab4e92d.c91e28"]]},{"id":"d39b4454.a0cc78","type":"function","z":"e5817ab55eab8ab8","name":"OFF","func":"msg.payload = { \"state\":\"OFF\"};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":650,"y":320,"wires":[["aab4e92d.c91e28"]]},{"id":"8a13f8be.ca9058","type":"delay","z":"e5817ab55eab8ab8","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"outputs":1,"x":490,"y":200,"wires":[["523a3a9a.7d63f4"]]},{"id":"523a3a9a.7d63f4","type":"function","z":"e5817ab55eab8ab8","name":"Update","func":"\nflow.set(\"IKEA_bulb1_brightness\", msg.payload.brightness);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":200,"wires":[[]]},{"id":"c10f24b5.2fcc78","type":"mqtt in","z":"e5817ab55eab8ab8","name":"IKEA Button","topic":"${remoteTopic}","qos":"1","datatype":"json","broker":"eca6af44.5297b","nl":false,"rap":false,"inputs":0,"x":190,"y":340,"wires":[["c786b38d.959c2"]]},{"id":"1da55aa957bc76db","type":"delay","z":"e5817ab55eab8ab8","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"outputs":1,"x":890,"y":160,"wires":[[]]},{"id":"eca6af44.5297b","type":"mqtt-broker","name":"MQTT","broker":"192.168.50.94","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
Praise (and coffee)? Go to the link above!
I’ll update the first post later
