Node Red has been working for over a month. All of a sudden it won’t connect with Hassio. I get this error over and over again.
5 May 22:42:42 - [error] [server:Home Assistant] Home assistant connection failed with error: Connection to home assistant could not be established with config: http://hassio/homeassistant
I have tried restarting nodered, re-building and deleting the server and re-setting it up. Nothing works. I am considering uninstalling node red and trying again. I have all my nodes stored in my library.
What am I missing. Even after I deleted the server I still get the same connection message every 2 seconds. Looking like my only option is to uninstall and try installing again. Makes me think Node Red isn’t ready/
Ok I am sure you all think I am nuts and sometimes I do myself. But, I deleted the server - rebuilt Node Red them re-set up the server and it all started working. No updates to any software and nothing changed in the server.
Me too: was working fine for weeks on end, and then this evening, bam, errors out the wazoo.
I wondered if the problem started happening after the frontend was upgraded (believe that was yesterday?). So this evening I tried downgrading from 0.74.0 to a 0.73.2 snapshot I made a couple of days ago. Didn’t work. I’m still receiving the same errors.
I am so frustrated with this I can’t believe I am stall working with this. Everything was working just fine and all of a sudden node red can’t connect with hassio. I have tried everything I can think of short of un-installing node red and re-installing. I deleted all of my connection and still get the same thing “Connection to home assistant could not be established with config: http://hassio/homeassistant <password redacted”. It makes no sense to me that the message says password redacted. Redacted usually means no longer supported. OK, so I took out the password and same thing.
Same issue here but I haven’t updated anything.Strangely enough, two days ago the addon has been marked as deprecated
I changed the local server address with the external address of HA and it seems to work but the documentation discourages it.
24 Jul 18:15:54 - [error] [server:Home Assistant] Home assistant connection failed with error: Connection to home assistant could not be established with config: http://hassio/homeassistant
“Redacted” means something is not shown, in this case, for security. Like when sensitive information is redacted (edited, removed) from a classified document.
