Node unstable after recompilation with new esphome version. power consumption higher?
Hey everyone,
this is a bit of a weird scenario, so asking here is more of a “shot in the dark”.
Situation at hand: I’ve got a esp32 devkit v1 board running for almost a year now, as the main info display in our hallway. It has a waveshare 2.9 epaper display connected, a MH-Z19C co2 sensor (via UART), a DHT22 temperatur/humidity sensor, 5 physical pushbuttons, and a neopixel led “spot” with 3 LEDs.
The board is powered by a samsung phone “wall wart”, and the peripherals are all run by the various V pins of the board itself. The YAML code was deployed the last time last summer/autumn and was running without issues since then, except for an occasional hard reboot when the epaper display had a glitch once month.
Over the weekend I moved the whole hardware into a new housing. Same components, same cables, same everything. Fired it back up, everything fine. Sensors available in HA, buttons and display work, also the LED, everything fine.
But: as the new housing has a different display position, I needed to change the code to turn the display by 180 degrees, so the ONLY code change I then made was from “rotation: 90°” to “rotation: 270°”.
After learning the hard way that old build files can mess with a newer esphome version (D1 mini in boot loop after OTA flash (and still after USB flash) - #10 by Lakini), I cleaned the old files via “esphome clean”, compiled without issues, and pushed things to the board via OTA.
Since then, the components connected to the board (or their representation in the logs and sensors) work unreliably to say the least. The epaper display doesnt refresh anymore, the co2 sensor either continuosly provides a fixed 500ppm as a value (occasionally works with correct values), the 3-LED-neopixel showed a random color for once, and from time to time I see a UART error in the logs.
A bit of context about my dev environment: I use the command line version of esphome on a windows10 laptop to compile and flash my nodes.
Are newer esphome versions more power-hungry and can therefore make not so “beefy” esp boards unstable that worked fine with old code/firmware from an older esphome version?
Next step for me will be removing everything and adding everything back one by one, but I’ll have to rewire things for that first. Worst case I’ll upgrade to a different esp board.
So any hints are welcome, thanks a lot in advance :slight_smile:
Are you on the latest versions of both Home Assistant and ESPHome? I would start there.
Then I would go back and triple check all of my wiring is still solid.
I don’t personally reckon it would be a version resourcing thing, but am not sure.
Echoing @Mahko_Mahko comment that my first guess would be a random wiring issue due to the physical movement.
If it were me, I’d download an old version of ESPHome that you knew worked and verify whether it’s truly that versus a physical issue.
Bit of a status update, not sure about the root cause in the old system, but working on a new setup. Observations/tests so far:
I had another identical “fresh from the package” devkit1 board laying around, so I connected just the display to that one, flashed the code, started it => nothing.
Out of frustration I ordered a new display (same model), also connected it to the new/second devkit board => again nothing.
What I then did: I had recently ordered some of the quinled esp32 boards, so I unpacked one of those, flashed a basic esphome setup onto it, added a “hello world” and the display code and connected the new display, and fired it up. it worked!
Since then I started adding more and more of the other components as well, one by one. DHT, co2, LED, push buttons, everything works fine. My plan for now it to move the whole node over to the quinled esp board. But I still have no idea why BOTH the old and the new devkit board failed.
More updates once everything is fully moved and works like before.
Weird. But also yet another win for quinled esp32 boards. My favourite for low hassle, especially if you want to load up an esp with lots of stuff.
Okay, this is getting ridiculous. I had written a minimal yaml file for the new setup which allowed me to test all connected devices. That yaml code already had the 270° display rotation:
esphome:
esp32:
  board: mhetesp32minikit
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: ""
ota:
  password: ""
wifi:
  ssid: "xxxxxxxxx"
  password: "xxxxxxxxxx"
  ap:
    ssid: "Quinled1 Fallback Hotspot"
    password: "xxxxxxxx"
captive_portal:
uart:
  rx_pin: 21
  tx_pin: 22
  baud_rate: 9600
spi:
  clk_pin: 16
  mosi_pin: 23
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812X
    pin: 13
    num_leds: 3
    name: "qLED notification hallway"
    effects:
      - addressable_twinkle:
          twinkle_probability: 5%
          progress_interval: 4ms
  - platform: dht
    pin: 17
    model: DHT22
    temperature:
      name: "qHallway Temperature"
    humidity:
      name: "qHallway Humidity"
    update_interval: 60s
  - platform: mhz19
    co2:
    temperature:
      name: "MH-Z19 Temperature"
    automatic_baseline_calibration: false
binary_sensor:
  - platform: gpio
    pin:
      number: 4
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
    on_press:
      - light.turn_on:
          brightness: 20%
          red: 50%
          green: 30%
          blue: 0%
  - platform: gpio
    pin:
      number: 12
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
    on_press:
      - light.turn_off:
display:
  - platform: waveshare_epaper
    cs_pin: 19
    dc_pin: 18
    busy_pin: 26
    reset_pin: 33
    model: 2.90inv2
    rotation: 270°
    update_interval: 90s
    full_update_every: 1
    #reset_duration: 2ms
    lambda: |-
      it.line(0, 0, 50, 50);
When all of that worked fine, I finished the new housing and put all components in, still with the test code above. Still everyone running smooth.
So now I took the old yaml file of the original node, and changed all board and pin settings to the new quinled board.
Flashed that, worked fine, but of course still had the screen the wrong way around. So I did the same thing that got me here 2 weeks ago: changed “rotation: 90°” to “rotation: 270°”, compiled flashed, and the display IS DEAD AGAIN!
The log shows this:
[21:51:18][E][waveshare_epaper:119]: Timeout while displaying image!
I have to miss something, but I don’t know what. It cannot be the 270 itself, because that works fine in the test code. But once I switch to 270 in the proper code, the display stops working. Frustration galore.
This is the code that works fine with 90°, but breaks the display when switched to 270°. Any ideas what the issue could be?
esphome:
esp32:
  framework:
    type: arduino
# Enable logging
logger:
json:
api:
  password: ""
ota:
  password: ""
wifi:
  ssid: "xxxxxxxxx"
  ap:
    ssid: "Epaper Fallback Hotspot"
captive_portal:
light:
    type: GRB
    variant: WS2812X
    pin: 13
    num_leds: 3
    name: "LED notification hallway"
    effects:
uart:
  rx_pin: 21
  tx_pin: 22
  baud_rate: 9600
font:
  - file: 'arial.ttf'
  - file: 'arial.ttf'
  - file: 'arial.ttf'
  - file: 'arial.ttf'
    glyphs:
      ['&', '@', '!', ',', '.', '"', '%', '(', ')', '+', '-', '_', ':', '°', '0',
       '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E',
       'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S',
       'T', 'U', 'V', 'W', 'X', 'Y', 'Z', ' ', 'a', 'b', 'c', 'd', 'e', 'f',
       'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't',
       'u', 'v', 'w', 'x', 'y', 'z','å', 'ä', 'ö', '/']
  - file: 'DejaVuSansMono-Bold.ttf'
    glyphs:
    glyphs:
image:
  - file: "puppy30.bmp"
  - file: "puppy30left.bmp"
  - file: "moonthick.bmp"
  - file: "moonthin.bmp"
  - file: "clear-night.bmp"
  - file: "cloudy.bmp"
  - file: "exceptional.bmp"
  - file: "fog.bmp"
  - file: "hail.bmp"
  - file: "lightning.bmp"
  - file: "lightning-rainy.bmp"
  - file: "partlycloudy.bmp"
  - file: "pouring.bmp"
  - file: "rainy.bmp"
  - file: "snowy.bmp"
  - file: "snowy-rainy.bmp"
  - file: "sunny.bmp"
  - file: "windy.bmp"
  - file: "windyvariant.bmp"
  - file: "clearnight45.bmp"
  - file: "cloudy45.bmp"
  - file: "exceptional45.bmp"
  - file: "fog45.bmp"
  - file: "hail45.bmp"
  - file: "lightning45.bmp"
  - file: "lightningrainy45.bmp"
  - file: "partlycloudy45.bmp"
  - file: "pouring45.bmp"
  - file: "rainy45.bmp"
  - file: "snowy45.bmp"
  - file: "snowy-rainy45.bmp"
  - file: "sunny45.bmp"
  - file: "windy45.bmp"
  - file: "windy-variant45.bmp"
globals:
  - id: dogmeter
    type: int
    restore_value: no
    initial_value: '1'
time:
  - platform: homeassistant
    on_time:
      - hours: 6
        minutes: 0
        seconds: 0
        then:
          - globals.set:
              value: '2'
      - hours: 9
        minutes: 0
        seconds: 0
        then:
          - globals.set:
              value: '1'
      - hours: 17
        minutes: 0
        seconds: 0
        then:
          - globals.set:
              value: '2'
      - hours: 21
        minutes: 0
        seconds: 0
        then:
          - globals.set:
              value: '0'
    entity_id: sensor.lumi_lumi_weather_a5f3bb07_temperature
    internal: true
    entity_id: sensor.openweathermap_wind_speed
    internal: true
    entity_id: sensor.openweathermap_forecast_temperature_2
    internal: true
    entity_id: sensor.openweathermap_forecast_temperature_low_2
    internal: true
  - platform: dht
    pin: 17
    model: DHT22
    temperature:
      name: "Hallway Temperature"
    humidity:
      name: "Hallway Humidity"
  - platform: mhz19
    co2:
      on_value_range:
        - above: 800
          below: 1000
          then:
            - light.turn_on:
                brightness: 20%
                red: 50%
                green: 30%
                blue: 0%
        - above: 999
          then:
            - light.turn_on:
                brightness: 20%
                red: 100%
                green: 0%
                blue: 0%
        - below: 800
          then:
            - light.turn_off:
    temperature:
text_sensor:
    entity_id: sensor.openweathermap_condition
    internal: true
    entity_id: weather.openweathermap
    internal: true
    attribute: forecast
    entity_id: weather.openweathermap_2
    internal: true
    attribute: forecast
binary_sensor:
  - platform: gpio
    pin:
      number: 32
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
    on_press:
      - display.page.show: page1
      - delay: 1s
      - component.update: eink
  - platform: gpio
    pin:
      number: 12
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
    on_press:
      - display.page.show: page2
      - delay: 1s
  - platform: gpio
    pin:
      number: 4
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
    on_press:
      - display.page.show: page3
      - delay: 1s
  - platform: gpio
    pin:
      number: 27
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
    on_press:
      - delay: 1s
  - platform: gpio
    pin:
      number: 25
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
    entity_id: binary_sensor.lumi_lumi_sensor_magnet_aq2_4420d107_on_off
    internal: true
    on_state:
      - delay: 1s
spi:
  clk_pin: 16
  mosi_pin: 23
display:
    cs_pin: 19
    dc_pin: 18
    busy_pin: 26
    reset_pin: 33
    model: 2.90inv2
    rotation: 90°
    update_interval: 300s
    pages:
      - id: page1
        lambda: |-
          std::map<std::string, Image *> imgDict;
          imgDict["clear-night"] = id(clear_night);
          imgDict["cloudy"] = id(cloudy);
          imgDict["fog"] = id(fog);
          imgDict["hail"] = id(hail);
          imgDict["lightning"] = id(lightning);
          imgDict["lightning-rainy"] = id(lightning_rainy);
          imgDict["partlycloudy"] = id(partlycloudy);
          imgDict["pouring"] = id(pouring);
          imgDict["rainy"] = id(rainy);
          imgDict["snowy"] = id(snowy);
          imgDict["snowy-rainy"] = id(snowy_rainy);
          imgDict["sunny"] = id(sunny);
          imgDict["windy"] = id(windy);
          imgDict["windy-variant"] = id(windy_variant);
          imgDict["exceptional"] = id(exceptional);
          it.line(1, 33, 33, 1);
          it.line(1, 34, 34, 1);
          it.line(1, 35, 35, 1);
          it.line(35, 1, 80, 45);
          it.line(36, 1, 81, 45);
          it.line(37, 1, 82, 45);
          it.line(80, 45, 80, 126);
          it.line(81, 45, 81, 126);
          it.line(80, 125, 206, 125);
          it.line(80, 126, 206, 126);
          if (id(bathroom_window).has_state()) {
          if (id(bathroom_window).state == true) {
          it.rectangle(80, 55, 20, 30);
          it.rectangle(81, 56, 18, 28);
          if (id(outside_temperature).has_state()) {
          it.printf(90, 5, id(dejamonobold), TextAlign::TOP_LEFT, "%2.0f", id(outside_temperature).state);
          it.printf(160, 5, id(dejamonobold), TextAlign::TOP_RIGHT, "°");
          it.printf(200, 8, id(dejamonoboldsmall), TextAlign::TOP_RIGHT, "%.0f°", id(maxtemp).state);
          it.printf(200, 28, id(dejamonoboldsmall), TextAlign::TOP_RIGHT, "%.0f°", id(mintemp).state);
          if (id(hallwayco2).has_state()) {
          it.printf(10, 35, id(dejamonobold), TextAlign::TOP_LEFT, "%2.0f", id(hallwaytemp).state);
          it.printf(80, 35, id(dejamonobold), TextAlign::TOP_RIGHT, "°");
          it.printf(10, 75, id(dejamonoboldsmall), "%.0f%%", id(hallwayhum).state);
          it.printf(10, 96, id(dejamonoboldsmall),  "%.0f", id(hallwayco2).state);
          if (id(outside_weather).has_state()) {
          it.image(206, 2, imgDict[id(outside_weather).state]);
          if (id(owm_forecast).has_state())
          DynamicJsonDocument doc(5048);
          deserializeJson(doc, (id(owm_forecast).state.c_str()));
          JsonArray root = doc.as<JsonArray>();
          int linestart = 192;
          int startX = 206;
          int startY = 126;
          for (int d=0; d <= 7; ++d)
          JsonObject root_1 = root[d];
          float root_1_precipitation_probability = root_1["precipitation_probability"];
          int heighthelper = (2 + (int)root_1_precipitation_probability) / 2;
          int offsethelper = 120 - heighthelper;
          it.line(startX, startY, startX+12, offsethelper);
          it.line(startX, startY-1, startX+12, offsethelper-1);
          linestart += 12;
          startX += 12;
          startY = offsethelper;
          int dogstart = 175;
          for (int dog=0; dog <= id(dogmeter); ++dog)
          it.image(dogstart, 94, id(puppyleft));
          dogstart -= 30;
      - id: page2
        lambda: |-
          imgDict["clear-night"] = id(clear_night45);
          imgDict["cloudy"] = id(cloudy45);
          imgDict["fog"] = id(fog45);
          imgDict["hail"] = id(hail45);
          imgDict["lightning"] = id(lightning45);
          imgDict["lightning-rainy"] = id(lightning_rainy45);
          imgDict["partlycloudy"] = id(partlycloudy45);
          imgDict["pouring"] = id(pouring45);
          imgDict["rainy"] = id(rainy45);
          imgDict["snowy"] = id(snowy45);
          imgDict["snowy-rainy"] = id(snowy_rainy45);
          imgDict["sunny"] = id(sunny45);
          imgDict["windy"] = id(windy45);
          imgDict["windy-variant"] = id(windy_variant45);
          imgDict["exceptional"] = id(exceptional45);
          std::map<int, const char *> dayDict;
          dayDict[1] = "MO";
          dayDict[2] = "TU";
          dayDict[3] = "WE";
          dayDict[4] = "TH";
          dayDict[5] = "FR";
          dayDict[6] = "SA";
          dayDict[7] = "SU";
          int day = id(esptime).now().day_of_week;
          if (id(owm_forecast_days).has_state())
          deserializeJson(doc, (id(owm_forecast_days).state.c_str()));
          int linestarticon = 3;
          for (int i=1; i <= 6; ++i)
          if (day > 7)
          day = 1;
          JsonObject root_0 = root[i];
          float maxtempforecast = root_0["temperature"];
          float chanceofrainforecast = root_0["precipitation_probability"];
          it.printf(linestarticon, -2, id(dejamonoboldsmall), TextAlign::TOP_LEFT, "%s", dayDict[day]);
          it.image(linestarticon, 22, imgDict[root_0["condition"]]);
          it.printf(linestarticon, 70, id(dejamonoboldsmall), TextAlign::TOP_LEFT, "%.0f°", maxtempforecast);
          if (chanceofrainforecast == 100)
          it.printf(linestarticon, 93, id(dejamonoboldsmall), TextAlign::TOP_LEFT, "%.0f", chanceofrainforecast);
          else
          it.printf(linestarticon, 93, id(dejamonoboldsmall), TextAlign::TOP_LEFT, "%.0f%%", chanceofrainforecast);
          linestarticon += 48;
          day += 1;
      - id: page3
        lambda: |-
          it.printf(5, 5, id(dejamonoboldsmall), "co2:");
          it.printf(5, 30, id(dejamonobold), "%.0f", id(hallwayco2).state);
          it.printf(130, 5, id(dejamonoboldsmall), "temp:");
          if (id(hallwaytemp).has_state()) {
          it.printf(130, 30, id(dejamonobold), "%.0f°", id(hallwaytemp).state);
          it.printf(220, 5, id(dejamonoboldsmall), "hum:");
          if (id(hallwayhum).has_state()) {
          it.printf(220, 30, id(dejamonobold), "%.0f%%", id(hallwayhum).state);
Can this be a memory thing? Does it require more memory to rotate the content by 270 degrees than it takes for 90 degrees? That might explain why the test code with the single line drawn still works with 270, while the bigger code with weather icons etc doesnt…
When I first saw this post, it reminded me of a recent bug I saw.
Maybe you could investigate if they are somehow they are related?
Okay, interesting development: I decluttered the code a bit (removing unused fonts and images), now it does work with 270 degrees mostly. When I switch the refresh time from every 30 seconds to 120 or 300 seconds, it sometimes works, and sometimes shows a timeout error again.
What I was thinking now (after never caring much about it before): if I understand it right, the esp32 chip has dedicated hardware spi, but can simulate spi basically on any other gpio pin. According to a YouTube video i saw around a different display with an arduino-driven esp32 board, using the dedicated hardware pins can make quite a difference in display performance.
Next step therefore: checking how much I need to resolder to try it put with dedicated pins…
I won’t mark it as the solution yet, because it only runs for half an hour now, but: I got everything to work :slight_smile: I stuck to the hardware spi pins mentioned in https://techoverflow.net/2021/07/26/what-is-the-spi-pinout-of-the-esp32-esp-wroom-32/ (for SPI3 in my case, as I only had to resolder one pin compared to my original pcb design), and that seems to have made the difference. Display runs smooth so far, all sensors working, HA sensors pulling data in to display, and the manual display refresh via gpio binary sensor push button also works. Will keep it running for a bit and move it to it’s original spot on that wall again, and then let’s hope this was it. At least withe the quinled board, still no idea why 2 devkits in a row didnt work (anymore).
thanks guys for bouncing a few things back and forth in this thread!
