hi,
I’m new here and with ha.
I wanted to discover ha. I installed it with the preconfigured vmdk.
The backbone of my setup is knx, but i have other protocols.
I don’t really understand how ha works and what lies behind entity or device.
At the start ha discovered my sonos play one and my phoscon gateway.
I have only 4 or 5 zigbee devices but i see that a device or entity came up : " configuration tool"
what is it ?
Then i wanted to add my first knx device. I read the docs but struggled with conf files.
Finally, for easing things i put all the conf in the configuration.yaml and i was able to see my first light.
The problem is it isn’t editable in ha as it doesn’t have a unique id.
I have certainly misconfigured something but i can’t see what.
Here is my config:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
knx:
tunneling:
host: '192.168.0.21'
port: 3671
local_ip: '192.168.0.104'
light:
# See "sensor" remarks above for an explanation of the resulting entity_ids
platform: knx
# switched light
address: '0/0/32'
state_address: '0/1/32'
when i go to config/entity it appears to be read only.
When i go to config/integration i don’t see an integration related to knx.
i changed the “è” for “e” but same result.
i must admit i’m a bit lost. I can use a light with ha or xknx but for now it’s very simple configuration.
I can not imagine how i’ll do the equivalent of i have now.
Yes almost right - you need to do a yaml list for the lights. So it’s
light:
- platform: knx
address: '1/0/9'
Note the - and the indentation.
And light is not defined in Knx config. So I’d just use
knx:
# init Knx before including lights. No arguments needed for tunneling connections.
!include: light.yaml
# lights are defined at the same level as knx
# this file would hold all lights for all your platforms.
In my opinion xknx style has no advantages (except maybe for Routing connections because of own_address).
HA style is better documented so I’d stick with this.
Im not sure if you can use both config together.
Yes i made that change.
What i meant is if you split conf with include directive, for example for the lights,
in configuration.yaml you write light: !include lights.yaml
then in the lights.yaml file you mustn’t start with light:
but directly with - platform
Now i see how to declare my devices even if then don’t appear in devices.
I have not found how to put them in a room.
I have to find out if i can use all of my devices and then how to translate my automations scripts and i have around 50 written in php.
So did you find you to setup your KNX device into a room?
Am trying HA (I am using at this time Jeedom), I hace the same behavior as you that “The problem is it isn’t editable in ha as it doesn’t have a unique id.”
