Not able to select my device on Grid Consumption
Hi folks,
I’m trying to have my power meter device showing on Energy Dashboard and I’m stuck on my configuration.
This is the device I have running ESPHome (no more Tuya :slight_smile:): https://pt.aliexpress.com/item/1005004190441810.html?spm=a2g0o.productlist.main.23.48a23905YRhAPO&algo_pvid=47dcf09f-ce4e-4e73-bb72-17b0287e8a4c&algo_exp_id=47dcf09f-ce4e-4e73-bb72-17b0287e8a4c-11&pdp_ext_f={"sku_id"%3A"12000028330294490"}&pdp_npi=3%40dis!BRL!304.57!243.65!!!!!%40211bda9b16804759898108343d078a!12000028330294490!sea!BR!0&curPageLogUid=bFTJiyiUNswq
This is my device ESPHome config:
substitutions:
  ipaddress: 192.168.2.49
  device: medidor
  friendly_name: "Medidor Energia"
esphome:
  platform: ESP8266
  board: esp01_1m
<<: !include common/basic.yaml
<<: !include common/wifi.yaml
logger:
  baud_rate: 0
uart:
  rx_pin: GPIO3
  tx_pin: GPIO1
  baud_rate: 9600
tuya:
time:
  - platform: sntp
binary_sensor:
  - platform: gpio
    pin: 16
#    on_press:
#      then:
#      - switch.toggle:
  - platform: "tuya"
    sensor_datapoint: 18
    accuracy_decimals: 2
    unit_of_measurement: A
    icon: "mdi:flash"
    filters:
      - multiply: 0.001
  - platform: "tuya"
    sensor_datapoint: 19
    accuracy_decimals: 1
    unit_of_measurement: W
    icon: "mdi:flash"
    filters:
      - multiply: 0.1
  - platform: "tuya"
    sensor_datapoint: 20
    unit_of_measurement: V
    icon: "mdi:flash"
    filters:
      - multiply: 0.1
  - platform: "tuya"
    name: "${friendly_name} kWh +"
    sensor_datapoint: 101
    accuracy_decimals: 3
    unit_of_measurement: kWh
    icon: "mdi:flash"
    device_class: power
    filters:
      - multiply: 0.01
  - platform: "tuya"
    name: "${friendly_name} kWh -"
    sensor_datapoint: 9
    unit_of_measurement: "kWh"
    icon: "mdi:flash"
    device_class: power
    filters:
      - multiply: 0.01
  - platform: total_daily_energy
    name: "Total Daily Power"
    power_id: my_power
    device_class: power
    state_class: measurement
This is basic.yaml file:
logger:
  level: DEBUG
api:
ota:
And this is wifi.yaml file:
wifi:
  ssid: !secret wifinetwork
  password: !secret wifipassword
  fast_connect: on
  manual_ip:
    static_ip: ${ipaddress}
    gateway: 192.168.2.1
    subnet: 255.255.255.0
    dns1: 1.1.1.1
    dns2: 8.8.8.8
  ap:
    ssid: ${device}
    password: ""
captive_portal:
web_server:
  port: 80
When I go to Energy Configuration and click on Add Consumption under Grid consumption, it is not showing my device, but I can see all readings on Home Assistant:
Can someone help me?
Thanks in advice
Energy Dashboard - Sensor not showing up - Configuration - Home Assistant Community (home-assistant.io)
Usually, the entity is missing a required attribute such as the state_class.
The link above covers a few things to look for.
