According to the information here…
Apex Charts custom card can be told to use HA Statistics for the graphs, but I don’t see an example of how to do that. What I’d like is to have a year long monthly graph showing the DIFFERENCE in data used month to month. I can’t figure it out.
Here’s what I have without using statistics…
type: custom:apexcharts-card
graph_span: 1month
update_interval: 1d
header:
show: true
title: Monthly Internet Data Consumption
show_states: true
colorize_states: true
series:
- entity: sensor.freebsd_router_b_received
color: rgb(10, 55, 58)
type: column
group_by:
func: diff
duration: 1w
- entity: sensor.freebsd_router_b_sent
color: rgb(255, 152, 0)
type: column
group_by:
func: diff
duration: 1w
This shows one month, stacked by week, but if I try to expand the chart past that, it crashes the card. I’m thinking because I don’t have history that long. I’d like to convert that to use statistics, and show the increase each month for the last year. This is easy on the statistics graph card, but there are no configuration options to speak of for that card.
Any ideas what I’m doing wrong?
Thanks!
Example:
series:
- entity: sensor.havingstatistics
offset: '-10d'
statistics:
type: sum
period: hour
align: start
Thanks!
Here is what I have now…
graph_span: 1y
update_interval: 1d
header:
show: true
show_states: true
series:
type: column
statistics:
type: sum
period: month
align: start
type: column
statistics:
type: sum
period: month
align: start
This seems to be grouping everything correctly. I just reset the HA database, so there isn’t anything except the current month to report on just yet. I left out the “offset” in your example. I’m not sure if that matters.
Since I have you, are you aware if it’s possible to convert the number displayed from bytes (what it’s stored as) to megabytes? To shorten the number displayed?
Thanks for your help!
Just an update…
The “transform” option allows you divide the results and shorten the number, but it still shows that the result is in bytes. So although the number gets smaller as it’s transformed into kb or mb, it lists that smaller number as bytes which is wrong.
Getting closer though…
Never did this before but a bit of digging in below HUGE thread helped
ApexCharts card - A highly customizable graph card - Share your Projects! / Dashboards & Frontend - Home Assistant Community (home-assistant.io)
THIS is just me fiddling around, the values/lables make no sense
header:
title: TEST
show: true
floating: false
show_states: true
apex_config:
legend:
show: false
show_states:
formatter: |
EVAL:function(value, opts) {
u = Math.floor(value);
m = Math.floor((value - u) * 60);
result = "";
if (u > 0)
result = u + "u ";
if (m > 0)
result += m + "m";
return result;
yaxis:
- id: temperature
labels:
formatter: |
EVAL:v => `${Math.round(v)}°C`
dataLabels:
formatter: |
series:
- entity: weather.home
type: column
show:
as_duration: hour
datalabels: true
data_generator: |
return entity.attributes.forecast.map((entry) => {
return [new Date(entry.datetime), entry.temperature];
For those following along at home, you can add a “unit:” line and specify what you want displayed…
series:
type: column
statistics:
type: sum
period: month
align: start
transform: return x / 1073741824;
unit: GB
Printscreen on your working apex? Thanks
I gave up on Apex. I have used Plotly and find it better in every way.
That would only be true if your technical skills are up to plotly-par. I can agree that plotly does offer good flexibility but it comes at a considerable price, i.e. being able to configure the details. A simple example in plotly: how to show the state of one of the configured entities in the header…and then, what about 2 states, or 5. The code explodes.
Apexcharts tried to bridge the gap…an with that it has limitations
I am 100% in no way against plotly (I am using this for complex things too) as it can go beyond way apex but for sure not (!) for all
