Notifications to close an open door or window after a set number of minutes
Sends two reminders as notifications to a mobile device to close a window or door after opening it, if the temperature outside is below a certain degree.
Thanks to @KTibow for the improvement.
# Home Assistant Automation Blueprint
# Sends two notifications to close a window or door after opening it,
# if the temperature outside is below a certain degree.
# Revision 2
# Roozbeh Farahbod, Jan. 2021
blueprint:
  name: Notification to Close a Window
  description: Notification to close windows if it is cold outside
  domain: automation
  input:
    contact_sensor:
      description: 'The window or door sensor that triggers the automation.'
      selector:
        entity:
          domain: binary_sensor
    first_timer:
      description: 'The first notification timer (in minutes).'
      default: 10
      selector:
        number:
          min: 1
          step: 1
          max: 60
          mode: slider
    second_timer:
      description: 'The second notification timer (in minutes).'
      default: 15
      selector:
        number:
          min: 1
          step: 1
          max: 60
          mode: slider
    temperature:
      description: 'The outside temperature below which the notification should be sent.'
      default: 20
      selector:
        number:
          min: 0
          step: 1
          max: 25
          mode: slider
    device_identifier:
      name: Device to notify
      description: >
        The device to receive the notification; it needs to run the official
        Home Assistant app to receive notifications.
      selector:
        device:
          integration: mobile_app
# We will have two triggers, for the two different reminders.
# However, a reminder will be ignored if the door or window is already closed by then.
- platform: state
  entity_id: !input contact_sensor
  to: 'on'
  for:
    hours: 0
    minutes: !input first_timer
    seconds: 0
- platform: state
  to: 'on'
  for:
    hours: 0
    minutes: !input second_timer
    seconds: 0
# Two conditions:
# 1. The door or window should still be open.
# 2. The temperature reading must be below the set value.
condition:
- condition: state
  state: 'on'
- condition: numeric_state
  entity_id: weather.pihome
  attribute: temperature
  below: !input temperature
# Send a notification to the mobile device.
- device_id: !input device_identifier
  domain: mobile_app
  type: notify
  message: 'Time to close {{trigger.to_state.attributes.friendly_name}}.'
  title: 'Close {{trigger.to_state.attributes.friendly_name}}!'
mode: single
GitHub: https://github.com/home-IoT/hass-blueprints/blob/main/reminder_to_close_window.yaml
    notify_device:
      description: Device needs to run the official Home Assistant app to receive notifications.
      selector:
        device:
Nice work. Was looking after something like this.
Instead of notification on phone, my plan is to use this setup
and have an announcement saying ‘windows xxx has now been open for 10 minutes’.
/Jorn
Thank you! I did try integration: 'Mobile App' which was wrong apparently.
Where does it get the outside temperature from?
It’s hardcoded as weather.pihome.
Could you make it configurable so the user can choose the most apropriate sensor?
That would be greate, or even choose a sensor if its rainy or not (binary)
@NKH Yes, sure; I can share a different version in a bit (in the middle of a busy workday now). I assume that you mean a sensor with a temperature reading, correct?
@r100gs anything is possible and I will be happy to help; however, in my view we will end up with a too generic of a blueprint. For me, the core point of a blueprint is to capture a pattern and reduce cost of creating similar automations by fixing the logic and common structure. To offer the freedom of choosing a temperature sensor or a binary sensor (and then with values), will make the blueprint too generic.
We can create a version that depends on the state of a binary sensor, and for example remove the temperature choice.
Yeah, that’s perfect (and there’s no rush :smile:)!
@roozbeh. Everything ist ok THX about the very nice blueprint
Hi @NKH , here is a version I made for a custom temperature sensor. Keep in mind that I set the class of the selector to limit the choices to temperature devices. Depending on your setup it may not list your device. If you find any problems, let me know and we can debug it together.
# Two Notifications to close a window or door after opening it,
# if the temperature reading of a given sensor is below a certain degree.
# Revision 1
blueprint:
  name: 'Notification to Close a Window (custom sensor)'
  domain: automation
  input:
    contact_sensor:
      selector:
        entity:
    first_timer:
      default: 10
      selector:
        number:
          min: 1
          step: 1
          max: 60
          mode: slider
    second_timer:
      default: 15
      selector:
        number:
          min: 1
          step: 1
          max: 60
          mode: slider
    temperature_sensor:
      description: 'The sensor used for reading the temperature.'
      selector:
        entity:
          domain: sensor
          device_class: temperature
    temperature:
      default: 20
      selector:
        number:
          min: 0
          step: 1
          max: 25
          mode: slider
    device_identifier:
      description: >
      selector:
        device:
- platform: state
  to: 'on'
  for:
    hours: 0
    seconds: 0
- platform: state
  to: 'on'
  for:
    hours: 0
    seconds: 0
# Two conditions:
# 2. The outside temperature must be below the set value.
condition:
- condition: state
  state: 'on'
  entity_id: !input temperature_sensor
  domain: mobile_app
  type: notify
mode: single
Cheers!
Hi I’m not getting any notifications, have tried all mobiles in HA
@soylant let’s see where the root cause is.
Do you receive notifications from any other automation on this instance of HA?
So sorry my bad​:pensive::grimacing: it’s working perfect
No sorries! :slight_smile: I’m happy that it’s working.
Thanks for the update! It looks like it works, at least the config/setup part 'cos I’m not home to actually open windows to check the function yet :smiley:
This is a better solution for those that want to use a specific temperature sensor
Hi!
It could be useful with a third alarm, can you implement that aswell? :slight_smile:
