hunterxd
(Tullio Conte)
November 17, 2023, 4:12pm
1
Hi all,
NSPanel Pro stock firmware expose mqtt broker without auth.
With mqtt explorer i can connect to mqtt broker and see the device and the topic,
but I can’t get it to work.
could you help me to connect nspanel pro zigbee gateway to home assistant and use via mqtt?
many thanks.
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
November 17, 2023, 5:56pm
2
Not sure what you are doing or how this pertains to Home Assistant, much less what it has to do with Blueprints.
I would suggest to change your topic to
Hardware - Home Assistant Community .
This will get you a better audience for your question.
And re-read some of this from the FAQ you read when you signed up. It will help you form a better question so we can help you.
How to help us help you - or How to ask a good question .
You may want to ask this question in this forum, there are people that that have this hardware in that thread.
Sonoff NSPanel Blueprint - Configure your own custom NSPanel easy via a Blueprint .
energiez
(EnergieZ)
March 28, 2024, 9:49pm
3
Hi Hunterxd,
I’m triing to achieve the samething without succes. Did you find a solution ?
Any help is welcom, thank you
My nspanel pro is up to date (version 3.0), with zigbee gateway mode.
best way is to follow Blakadders tutorial how to sideload apps: Sideload Apps to Sonoff NSPanel Pro | Blakadder's Smarthome Shenanigans
and then sideload Nspanel Pro Tools onto the sonoff. You can still use the stock app. but why would you if you use home assistant!
