I use this setup to send my Proxmox stats via MQTT to HA, I just changed to from RPi to Proxmox, which is almost the same:
This is my script in Proxmox:
# Python 2 script to check cpu load, cpu temperature and free space,
# on a Raspberry Pi computer and publish the data to a MQTT server.
# RUN pip install paho-mqtt
# RUN sudo apt-get install python-pip
from __future__ import division
import subprocess, time, socket, os
import paho.mqtt.client as paho
import json
import config
# get device host name - used in mqtt topic
hostname = socket.gethostname()
def check_used_space(path):
st = os.statvfs(path)
free_space2 = st.f_bavail * st.f_frsize
total_space2 = st.f_blocks * st.f_frsize
used_space = int(100 - ((free_space2 / total_space2) * 100))
return used_space
def check_free_space(path):
free_space = st.f_bavail * st.f_frsize
#total_space = st.f_blocks * st.f_frsize
#used_space = int(100 - ((free_space / total_space) * 100))
gb = 1024 * 1024 * 1024
return round(float(free_space / gb), 1)
def check_total_space(path):
#free_space = st.f_bavail * st.f_frsize
return round(float(total_space / gb), 1)
def check_cpu_load():
# bash command to get cpu load from uptime command
p = subprocess.Popen("uptime", shell=True, stdout=subprocess.PIPE).communicate()[0]
cores = subprocess.Popen("nproc", shell=True, stdout=subprocess.PIPE).communicate()[0]
cpu_load = p.split("average:")[1].split(",")[0].replace(' ', '')
cpu_load = float(cpu_load)/int(cores)*100
cpu_load = round(float(cpu_load), 1)
return cpu_load
def check_uptime():
p = subprocess.Popen("uptime -p", shell=True, stdout=subprocess.PIPE).communicate()[0]
#uptime = p.split("up ")
uptime = p.replace('up ', '').replace(',', '').replace('\n', '')
return uptime
def check_voltage():
full_cmd = "vcgencmd measure_volts | cut -f2 -d= | sed 's/000//'"
voltage = subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
voltage = voltage.strip()[:-1]
return voltage
def check_swap():
full_cmd = "free -t | awk 'NR == 3 {print $3/$2*100}'"
swap = subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
swap = round(float(swap), 1)
return swap
def check_memory():
full_cmd = "free -t | awk 'NR == 2 {print $3/$2*100}'"
memory = subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
memory = round(float(memory), 1)
return memory
def check_cpu_temp():
#full_cmd = "cat /sys/class/thermal/thermal_zone3/temp"
cpu_temp = subprocess.check_output("cat /sys/class/thermal/thermal_zone5/temp", shell=True)
#cpu_temp = subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
#cpu_temp = p.replace('\n', ' ').replace('\r', '').split("=")[1].split("'")[0]
cpu_temp = [int(i) for i in cpu_temp.split() if i.isdigit()][0]
return cpu_temp/1000
def check_sys_clock_speed():
full_cmd = "awk '{printf (\"%0.0f\",$1/1000); }' </sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq"
return subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
def publish_to_mqtt (cpu_load = 0, cpu_temp = 0, used_space = 0, free_space = 0, uptime = 0, total_space = 0, memory = 0):
# connect to mqtt server
client = paho.Client()
client.username_pw_set(config.mqtt_user, config.mqtt_password)
client.connect(config.mqtt_host, config.mqtt_port)
# publish monitored values to MQTT
if config.cpu_load:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/cpuload", cpu_load, qos=1)
time.sleep(config.sleep_time)
if config.cpu_temp:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/cputemp", cpu_temp, qos=1)
if config.used_space:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/diskusage", used_space, qos=1)
if config.free_space:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/freespace", free_space, qos=1)
if config.total_space:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/totalspace", total_space, qos=1)
if config.memory:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/memory", memory, qos=1)
if config.uptime:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/uptime", uptime, qos=1)
# disconect from mqtt server
client.disconnect()
def bulk_publish_to_mqtt (cpu_load = 0, cpu_temp = 0, used_space = 0, free_space = 0, uptime = 0, total_space = 0, memory = 0):
# compose the CSV message containing the measured values
values = cpu_load, float(cpu_temp), used_space, free_space, uptime, total_space, memory
values = str(values)[1:-1]
client.publish(config.mqtt_topic_prefix+"/"+hostname, values, qos=1)
client.disconnect()
if __name__ == '__main__':
# set all monitored values to False in case they are turned off in the config
cpu_load = cpu_temp = used_space = free_space = uptime = total_space = memory = False
# delay the execution of the script
time.sleep(config.random_delay)
# collect the monitored values
if config.cpu_load:
cpu_load = check_cpu_load()
if config.cpu_temp:
cpu_temp = check_cpu_temp()
used_space = check_used_space('/')
free_space = check_free_space('/')
if config.uptime:
uptime = check_uptime()
total_space = check_total_space('/')
if config.memory:
memory = check_memory()
# Publish messages to MQTT
if config.group_messages:
bulk_publish_to_mqtt(cpu_load, cpu_temp, used_space, free_space, uptime, total_space, memory)
else:
