Forgive my ignorance, but how do you add multiple instances of these monitors onto one screen?
I use this setup to send my Proxmox stats via MQTT to HA, I just changed to from RPi to Proxmox, which is almost the same:
This is my script in Proxmox:
# Python 2 script to check cpu load, cpu temperature and free space,
# on a Raspberry Pi computer and publish the data to a MQTT server.
# RUN pip install paho-mqtt
# RUN sudo apt-get install python-pip
from __future__ import division
import subprocess, time, socket, os
import paho.mqtt.client as paho
import json
import config
# get device host name - used in mqtt topic
hostname = socket.gethostname()
def check_used_space(path):
st = os.statvfs(path)
free_space2 = st.f_bavail * st.f_frsize
total_space2 = st.f_blocks * st.f_frsize
used_space = int(100 - ((free_space2 / total_space2) * 100))
return used_space
def check_free_space(path):
free_space = st.f_bavail * st.f_frsize
#total_space = st.f_blocks * st.f_frsize
#used_space = int(100 - ((free_space / total_space) * 100))
gb = 1024 * 1024 * 1024
return round(float(free_space / gb), 1)
def check_total_space(path):
#free_space = st.f_bavail * st.f_frsize
return round(float(total_space / gb), 1)
def check_cpu_load():
# bash command to get cpu load from uptime command
p = subprocess.Popen("uptime", shell=True, stdout=subprocess.PIPE).communicate()[0]
cores = subprocess.Popen("nproc", shell=True, stdout=subprocess.PIPE).communicate()[0]
cpu_load = p.split("average:")[1].split(",")[0].replace(' ', '')
cpu_load = float(cpu_load)/int(cores)*100
cpu_load = round(float(cpu_load), 1)
return cpu_load
def check_uptime():
p = subprocess.Popen("uptime -p", shell=True, stdout=subprocess.PIPE).communicate()[0]
#uptime = p.split("up ")
uptime = p.replace('up ', '').replace(',', '').replace('\n', '')
return uptime
def check_voltage():
full_cmd = "vcgencmd measure_volts | cut -f2 -d= | sed 's/000//'"
voltage = subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
voltage = voltage.strip()[:-1]
return voltage
def check_swap():
full_cmd = "free -t | awk 'NR == 3 {print $3/$2*100}'"
swap = subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
swap = round(float(swap), 1)
return swap
def check_memory():
full_cmd = "free -t | awk 'NR == 2 {print $3/$2*100}'"
memory = subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
memory = round(float(memory), 1)
return memory
def check_cpu_temp():
#full_cmd = "cat /sys/class/thermal/thermal_zone3/temp"
cpu_temp = subprocess.check_output("cat /sys/class/thermal/thermal_zone5/temp", shell=True)
#cpu_temp = subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
#cpu_temp = p.replace('\n', ' ').replace('\r', '').split("=")[1].split("'")[0]
cpu_temp = [int(i) for i in cpu_temp.split() if i.isdigit()][0]
return cpu_temp/1000
def check_sys_clock_speed():
full_cmd = "awk '{printf (\"%0.0f\",$1/1000); }' </sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq"
return subprocess.Popen(full_cmd, shell=True, stdout=subprocess.PIPE).communicate()[0]
def publish_to_mqtt (cpu_load = 0, cpu_temp = 0, used_space = 0, free_space = 0, uptime = 0, total_space = 0, memory = 0):
# connect to mqtt server
client = paho.Client()
client.username_pw_set(config.mqtt_user, config.mqtt_password)
client.connect(config.mqtt_host, config.mqtt_port)
# publish monitored values to MQTT
if config.cpu_load:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/cpuload", cpu_load, qos=1)
time.sleep(config.sleep_time)
if config.cpu_temp:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/cputemp", cpu_temp, qos=1)
if config.used_space:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/diskusage", used_space, qos=1)
if config.free_space:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/freespace", free_space, qos=1)
if config.total_space:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/totalspace", total_space, qos=1)
if config.memory:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/memory", memory, qos=1)
if config.uptime:
client.publish(config.mqtt_topic_prefix+"/"+hostname+"/uptime", uptime, qos=1)
# disconect from mqtt server
client.disconnect()
def bulk_publish_to_mqtt (cpu_load = 0, cpu_temp = 0, used_space = 0, free_space = 0, uptime = 0, total_space = 0, memory = 0):
# compose the CSV message containing the measured values
values = cpu_load, float(cpu_temp), used_space, free_space, uptime, total_space, memory
values = str(values)[1:-1]
client.publish(config.mqtt_topic_prefix+"/"+hostname, values, qos=1)
client.disconnect()
if __name__ == '__main__':
# set all monitored values to False in case they are turned off in the config
cpu_load = cpu_temp = used_space = free_space = uptime = total_space = memory = False
# delay the execution of the script
time.sleep(config.random_delay)
# collect the monitored values
if config.cpu_load:
cpu_load = check_cpu_load()
if config.cpu_temp:
cpu_temp = check_cpu_temp()
used_space = check_used_space('/')
free_space = check_free_space('/')
if config.uptime:
uptime = check_uptime()
total_space = check_total_space('/')
if config.memory:
memory = check_memory()
# Publish messages to MQTT
if config.group_messages:
bulk_publish_to_mqtt(cpu_load, cpu_temp, used_space, free_space, uptime, total_space, memory)
else:
I just added more cards to a view. Every card is another template custom card.
I’d like to do get the same data from Proxmox into Home Assistant.
Is this a script you run inside Home Assistant, or in a seperate vm?
Can you please provide more info on this?
return cpu_load
You need to run the script in Proxmox, so ssh into it. Then follow the guide just like the one for the RPi.
You can run that script on every debian based machine to get its stats.
There is an integration for Proxmox
Having great difficulty as it will only show the last card on my system - Can you share your Lovelace file so I can see what I’m doing wrong!
Sure! Here it is:
- title: SYSTEM2
path: system-2
icon: 'mdi:network'
visible:
- user: ###########################
badges: []
cards:
- id: rpi4_status
type: 'custom:config-template-card'
variables:
- 'states[''sensor.rpi4_diskusage''].state'
- 'states[''sensor.rpi4_memory''].state'
- 'states[''sensor.rpi4_cpu_load''].state'
- 'states[''sensor.rpi4_cpu_temp''].state'
- 'states[''sensor.rpi4_free_space''].state'
- 'states[''sensor.rpi4_total_space''].state'
- 'states[''sensor.rpi4_uptime''].state'
entities:
- sensor.rpi4_diskusage
- sensor.rpi4_memory
- sensor.rpi4_cpu_load
- sensor.rpi4_cpu_temp
- sensor.rpi4_free_space
- sensor.rpi4_total_space
- sensor.rpi4_uptime
card:
type: entities
show_header_toggle: 'off'
style: |
.card-header {
padding: 0px 0px 0px 0px !important;
entities:
- type: section
label: '${ ''RPi4 --- Raspbian 10 (buster) '' }'
- type: 'custom:hui-vertical-stack-card'
cards:
- type: horizontal-stack
cards:
- type: picture
style: |
ha-card {
--paper-card-background-color: 'rgba(0, 0, 0, 0.0)';
--ha-card-background: "rgba(0, 0, 0, 0.0)";
--ha-card-box-shadow: 'none';
image: /local/images/raspberrypi.jpg
- type: 'custom:button-card'
layout: icon_name_state2nd
show_icon: true
show_state: true
styles:
grid:
- grid-template-columns: 50px auto
icon:
- padding: 0px 0px
- height: 30px
- width: 30px
card:
- '--ha-card-background': 'rgba(0, 0, 0, 0.0)'
- '--ha-card-box-shadow': none
state:
- padding: 0px 10px
- justify-self: start
- font-family: 'Roboto, sans-serif'
- font-size: 15px
name:
- padding: 0px 10px
- color: var(--secondary-text-color)
entity: sensor.rpi4_uptime
icon: 'mdi:clock-outline'
- type: 'custom:bar-card'
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
unit_of_measurement: '%'
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
--paper-item-icon-color: 'var(--text-primary-color';
entities:
- entity: sensor.rpi4_diskusage
name: '${ ''Disk ('' + vars[4] + ''Gb/'' + vars[5] + ''Gb)'' }'
entity_row: true
cards:
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.rpi4_memory
entity_row: true
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.rpi4_cpu_load
entity_row: true
- type: 'custom:mini-graph-card'
height: 30
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
.info.flex {
font-size: 12px !important;
entities:
color_thresholds:
- value: 30
color: '#3498db'
- value: 50
color: '#f39c12'
- value: 80
color: '#ff0000'
- id: network_debian_status
variables:
- 'states[''sensor.network_debian_diskusage''].state'
- 'states[''sensor.network_debian_memory''].state'
- 'states[''sensor.network_debian_cpu_load''].state'
- 'states[''sensor.network_debian_free_space''].state'
- 'states[''sensor.network_debian_total_space''].state'
- 'states[''sensor.network_debian_uptime''].state'
entities:
- sensor.network_debian_diskusage
- sensor.network_debian_memory
- sensor.network_debian_cpu_load
- sensor.network_debian_free_space
- sensor.network_debian_total_space
- sensor.network_debian_uptime
card:
type: entities
style: |
.card-header {
entities:
- type: section
label: '${ ''VM --- Debian 10 (buster)'' }'
cards:
cards:
- type: picture
style: |
ha-card {
image: /local/images/debian.jpg
show_icon: true
show_state: true
styles:
grid:
icon:
- padding: 0px 0px
- height: 30px
- width: 30px
card:
state:
- padding: 0px 10px
- font-size: 15px
name:
- padding: 0px 10px
entity: sensor.network_debian_uptime
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entities:
- entity: sensor.network_debian_diskusage
name: '${ ''Disk ('' + vars[3] + ''GB/'' + vars[4] + ''GB)'' }'
entity_row: true
cards:
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.network_debian_memory
entity_row: true
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.network_debian_cpu_load
entity_row: true
- id: proxmox_status
variables:
- 'states[''sensor.proxmox_diskusage''].state'
- 'states[''sensor.proxmox_memory''].state'
- 'states[''sensor.proxmox_cpu_load''].state'
- 'states[''sensor.proxmox_cpu_temp''].state'
- 'states[''sensor.proxmox_free_space''].state'
- 'states[''sensor.proxmox_total_space''].state'
- 'states[''sensor.proxmox_uptime''].state'
entities:
- sensor.proxmox_diskusage
- sensor.proxmox_memory
- sensor.proxmox_cpu_load
- sensor.proxmox_cpu_temp
- sensor.proxmox_free_space
- sensor.proxmox_total_space
- sensor.proxmox_uptime
card:
type: entities
style: |
.card-header {
entities:
- type: section
label: '${ ''NUC i7 --- Proxmox VE 6.3-3 '' }'
cards:
cards:
- type: picture
style: |
ha-card {
image: /local/images/proxmox.png
show_icon: true
show_state: true
styles:
grid:
icon:
- padding: 0px 0px
- height: 30px
- width: 30px
card:
state:
- padding: 0px 10px
- font-size: 15px
name:
- padding: 0px 10px
entity: sensor.proxmox_uptime
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entities:
- entity: sensor.proxmox_diskusage
name: '${ ''Disk ('' + vars[4] + ''GB/'' + vars[5] + ''GB)'' }'
entity_row: true
cards:
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.proxmox_memory
entity_row: true
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.proxmox_cpu_load
entity_row: true
height: 30
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
.info.flex {
entities:
color_thresholds:
- value: 30
color: '#3498db'
- value: 50
color: '#f39c12'
- value: 80
color: '#ff0000'
- id: network_ubuntu_status
variables:
- 'states[''sensor.network_ubuntu_diskusage''].state'
- 'states[''sensor.network_ubuntu_memory''].state'
- 'states[''sensor.network_ubuntu_cpu_load''].state'
- 'states[''sensor.network_ubuntu_free_space''].state'
- 'states[''sensor.network_ubuntu_total_space''].state'
- 'states[''sensor.network_ubuntu_uptime''].state'
entities:
- sensor.network_ubuntu_diskusage
- sensor.network_ubuntu_memory
- sensor.network_ubuntu_cpu_load
- sensor.network_ubuntu_free_space
- sensor.network_ubuntu_total_space
- sensor.network_ubuntu_uptime
card:
type: entities
style: |
.card-header {
entities:
- type: section
label: '${ ''VM --- Ubuntu 20.04.1 LTS'' }'
cards:
cards:
- type: picture
style: |
ha-card {
image: /local/images/ubuntu.png
show_icon: true
show_state: true
styles:
grid:
icon:
- padding: 0px 0px
- height: 30px
- width: 30px
card:
state:
- padding: 0px 10px
- font-size: 15px
name:
- padding: 0px 10px
entity: sensor.network_ubuntu_uptime
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entities:
- entity: sensor.network_ubuntu_diskusage
entity_row: true
cards:
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.network_ubuntu_memory
entity_row: true
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.network_ubuntu_cpu_load
entity_row: true
True, but that only returns the state of a VM.
Liamstears,
Your card looks incredible and this is exactly what I’m looking for. It doesn’t appear to work in my HA. I’ve done the following steps:
- Installed all the cards from HACS
- Setup the sensor.yaml for get systemmonitor entities and verified they exist
- Copied your intel-nuc.png file into /local/images
- Rebooted
- Added a card “manual”
- Copied your yaml into the manual card and saved
It just shows up as a blank card. Even the NUC icon doesn’t show up. No error messages. Any ideas? Or maybe I’m not looking in the right place for error messages.
One of the entities at the top of the yaml doesn’t exist on your system
Delete them 1 at a time from both the entities and variables section at the top of the card yaml and the card will show when the entity that doesn’t exist is removed
When you know which one it is you can fix it from there
In chrome, hit f12. Error should be in the lower right corner
Thanks, this worked and I figured it out.
Thanks @Hs82H,
I’m a bit further now and installed the script. Only error is with getting the cpuload.
Any idea what could solve this?
root@proxmox:/home/user/proxmox-monitor# /usr/bin/python3 ./proxmox-monitor.py
File "./proxmox-monitor.py", line 140, in <module>
File "./proxmox-monitor.py", line 38, in check_cpu_load
TypeError: a bytes-like object is required, not 'str'
The code in the script:
return cpu_load
change your strings to bytes, put a b in front of every string e.g. b'average:'
, b','
, etc
I’m getting a strange placement of the CPU utilization. Below is a screenshot of the card and my YAML code. I can not figure out why the CPU Percentage is at a lower height than RAM %. Any ideas?
cards:
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.memory_use_percent
entity_row: true
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
entity: sensor.processor_use_percent
Never mind, I figured it out.
Can’t figure out how to get the image of the server into www to correct line 2.
