Numeric input_select state with human-readable labels?
wasn’t sure how to build the topic to contain my idea, but here’s the explaination:
I use quite a few input_select components to keep “settings” of my hass.io - different people preferences about notifications, specific scenes for rooms, and planned sprinkler integration. I want to keep the selects as readable for every user as possible, so couple of them are not only 1-word or number, but like a small sentences [for example one of the options for notifications: “Get all important, but none at home” etc.]. is there a way to create numeric aliases for the options to use them in conditions or while setting them via scripts/automations? I’m starting to think that words are confusing my automations & want to make it easier at the yaml-side, but keep informative for humans.
in simple words: I’d love to have a possibility to check input_selects in conditions like “if input_selects.week_option > 3” but have that options visible to user as words, not numbers. that way I could also set input_select.week_option to, let’s say, 4, and that would mean that users will see “thursday” as selected setting*.
*disclaimer: week days are only as an example, I know I can number them with now() function :wink: that’s not the case :slight_smile:
What you want is possible, but requires work.
You’ll need to have the following code in all your templates:
Automations where you aren’t using trigger object (trigger.to_state… etc)
{% set option_number = state_attr('input_select.xxx','options').index(states('input_select.xxx')) %}
Automations where you are using the trigger object
{% set option_number = state_attr(trigger.entity_id,'options').index(states(trigger.entity_id)) %}
The output of these templates is an index position of your input_selection. Remember list indexes start at zero.
Example
These are the options in your input_select.xxx
  • Item A
  • Item B
  • Item C
  • Item D
If your input_select.xxx is set to Item A, your output_number from the template contain a value of 0 after executing the template line supplied above.
If your input_select.xxx is set to Item B, your output_number from the template contain a value of 1 after executing the template line supplied above.
If your input_select.xxx is set to Item C, your output_number from the template contain a value of 2 after executing the template line supplied above.
If your input_select.xxx is set to Item D, your output_number from the template contain a value of 3 after executing the template line supplied above.
So, pretty much your selection option order is what drives what number you get from that template line.
looks good, thank you!
that definitely will work for attribute read and will make some of my conditions easier to grasp :slight_smile:
I guess that the opposite - selecting an option via automation/script based on number (“select 1” which would on fact select the “Item B” selection) is not possible?
No it is:
state_attr('input_select.xxx','options')[0]
would be Item A etc
great!
thank you so much!
I’m opening notepad++ and starting to rewrite my automations now :slight_smile:
@pejotigrek any chance that you can paste an example of your automation? I’m trying to do the same with my solax inverter states and I’d love to have a way to decode/encode the human readable inverter state with the [0,1,2,3] operation code needed to set the state.
Post the service call that you’ll be using to convert the options, and post what each option should mean.
@luismsousa I guess my automation won’t help you as it was altered maaaaany times after this post :wink: but here’s what you can try in your automation, assuming, that it is triggeredy by input_select’s option change:
- service: <state change service>
    entity_id: <entity to change the state in>
    state: {{ state_attr(trigger.entity_id,'options').index(states(trigger.entity_id)) }}
Another option would be to use a Template Select.
