Hi! just did a reboot. same behavior. this is my log.
2019-01-18 06:28:16 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2019-01-18 06:28:18 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.braviatv_psk which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-01-18 06:28:18 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.samsung_multi_room which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-01-18 06:28:18 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.alexa which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-01-18 06:28:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 212, in async_update_ha_state
raise RuntimeError("Attribute hass is None for {}".format(self))
RuntimeError: Attribute hass is None for <Entity yr Symbol: 1>
2019-01-18 06:28:22 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 344, in _async_add_entity
raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: calendar.alexa_inkopslista
2019-01-18 06:29:03 WARNING (MainThread) [songpal.service] Got duplicate signature for MethodSignature(name='getSourceList', input={'scheme': <class 'str'>}, output={'source': <class 'str'>, 'title': <class 'str'>, 'isPlayable': 'bool', 'isBrowsable': 'bool', 'playAction': <class 'str'>, 'outputs': 'string*', 'meta': <class 'str'>, 'iconUrl': <class 'str'>, 'protocols': 'string*', 'upnpOperationInfo': 'UpnpOperationInfo'}, version='1.2'), existing was <Method avContent.getSourceList({'scheme': <class 'str'>}) -> {'iconUrl': <class 'str'>,
'title': <class 'str'>}>. Keeping the existing one
2019-01-18 06:29:03 WARNING (MainThread) [songpal.service] Got duplicate signature for MethodSignature(name='getStorageList', input={'uri': <class 'str'>, 'isRegistered': <class 'str'>}, output={'uri': <class 'str'>, 'deviceName': <class 'str'>, 'volumeLabel': <class 'str'>, 'permission': <class 'str'>, 'position': <class 'str'>, 'formattable': <class 'str'>, 'mounted': <class 'str'>, 'wholeCapacityMB': <class 'int'>, 'freeCapacityMB': <class 'int'>, 'systemAreaCapacityMB': <class 'int'>, 'isAvailable': <class 'str'>, 'lun': <class 'int'>, 'type': <class 'str'>, 'protocol': <class 'str'>, 'format': <class 'str'>, 'error': <class 'str'>, 'isRegistered': <class 'str'>, 'registrationDate': <class 'str'>, 'isSqvSupported': <class 'str'>, 'hasNonStandardData': <class 'str'>, 'isProtected': <class 'str'>, 'isLocked': <class 'str'>, 'formatStatus': <class 'str'>, 'finalizeStatus': <class 'str'>, 'timeSecToFinalize': <class 'int'>, 'isSelfRecorded': <class 'str'>, 'isManagementInfoFull': <class 'str'>, 'timeSecToGetContents': <class 'int'>, 'hasUnsupportedContents': <class 'str'>, 'usbDeviceType': <class 'str'>, 'fileSystem': <class 'str'>}, version='1.2'), existing was <Method system.getStorageList({'uri': <class 'str'>}) -> {'deviceName': <class 'str'>,
'formatting': <class 'str'>,
'wholeCapacityMB': <class 'int'>}>. Keeping the existing one
2019-01-18 06:29:03 WARNING (MainThread) [songpal.service] Got duplicate signature for MethodSignature(name='getSystemInformation', input=None, output={'product': <class 'str'>, 'region': <class 'str'>, 'language': <class 'str'>, 'model': <class 'str'>, 'serial': <class 'str'>, 'macAddr': <class 'str'>, 'name': <class 'str'>, 'generation': <class 'str'>, 'area': <class 'str'>, 'cid': <class 'str'>, 'helpUrl': <class 'str'>, 'deviceID': <class 'str'>, 'version': <class 'str'>, 'duid': <class 'str'>, 'wirelessMacAddr': <class 'str'>, 'esn': <class 'str'>, 'iconUrl': <class 'str'>, 'ssid': <class 'str'>, 'bdAddr': <class 'str'>, 'initialPowerOnTime': <class 'str'>, 'lastPowerOnTime': <class 'str'>, 'bleID': <class 'str'>}, version='1.4'), existing was <Method system.getSystemInformation(None) -> {'area': <class 'str'>,
'updatableVersion': <class 'str'>,
'wirelessMacAddr': <class 'str'>}>. Keeping the existing one
2019-01-18 06:30:26 WARNING (MainThread) [homeassistant.components.light] Updating hue light took longer than the scheduled update interval 0:00:05
2019-01-18 06:30:32 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge 192.168.1.95 ()
2019-01-18 06:30:32 WARNING (MainThread) [homeassistant.components.media_player] Updating braviatv_psk media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:30:32 WARNING (MainThread) [homeassistant.components.media_player] Updating samsung_multi_room media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:30:32 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:30:32 WARNING (MainThread) [homeassistant.components.media_player] Updating kodi media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:30:32 WARNING (MainThread) [homeassistant.components.light] Updating hue light took longer than the scheduled update interval 0:00:05
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.entertainment_area_1 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.nattduksbord_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.koksfonster_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.forradsvagg2_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.golvlampan_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.sovrum is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.forradsvagg4_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.telefonladdare is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.lampststativ_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.golvlampa_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.vardagsrum is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.foradsvagg1_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.altan1_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.koksbank_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.kok is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.ute is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.forradsvagg3_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.vardagsrum_tak_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.badrum is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.taklampa_kok_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.entre_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.altan2_2 is taking over 10 seconds
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:30:40 WARNING (MainThread) [homeassistant.components.light] Updating hue light took longer than the scheduled update interval 0:00:05
2019-01-18 06:30:49 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:32:51 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:32:51 WARNING (MainThread) [homeassistant.components.light] Updating hue light took longer than the scheduled update interval 0:00:05
2019-01-18 06:32:56 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge 192.168.1.95 ()
2019-01-18 06:32:56 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:32:56 WARNING (MainThread) [homeassistant.components.light] Updating hue light took longer than the scheduled update interval 0:00:05
2019-01-18 06:33:02 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
2019-01-18 06:33:02 WARNING (MainThread) [homeassistant.components.media_player] Updating kodi media_player took longer than the scheduled update interval 0:00:10
