When installing for first time on an odroid n2+ using an SD CARD, the system tries to boot and gets an IP address you can see in the console but then it errors out with "serverip not set’ error and it does not continue with the install. See attached image.
The same process works with MMC module! only SD Card install fails.
Got image from https://github.com/home-assistant/operating-system/releases/download/7.6/haos_odroid-n2-7.6.img.xz per instructions.
Steps I used:
- download Odroid home assistance image file from https://github.com/home-assistant/operating-system/releases/download/7.6/haos_odroid-n2-7.6.img.xz
- flash in SD card
- insert the SD Card in Odroid n2+
- attach network cable on n2+ and power on
- system boots, even gets IP address, but then errors with serverip not set error
Any ideas on how i can get it working with SD Card?
