⛔ Offline Devices Report : Easy Customize Includes & Excludes, Notifications + More
When I cleared exclusions it started to show those devices (3 of them are inactive so I excluded them)
YAML from automation:
alias: ⛔ Offline Devices Report with Notification Actions
description: ""
use_blueprint:
  path: Ltek/offline-devices-report-ltek.yaml
  input:
    time: "17:00:00"
    include_time: time_enabled
    exclude_entities: []
    notify_message: all_sensors
    notify_device:
      - ###device entity was there
    include_easy_notify: enable_easy_okay_notify
    notify_data: []
    include_custom_actions: enable_custom_actions
    custom_actions:
      - action: telegram_bot.send_message
        metadata: {}
          config_entry_id: ###telegram entitity was there
          message: Батарейка `{{sensors}}` разряжена, нужно заменить
    include_persistent_notification: enable_persistent_okay_notification
I dont see any exclusions in your YAML so I cant see what could be causing the problem
description: ""
use_blueprint:
  input:
    time: "17:00:00"
    exclude_entities:
      - sensor.miaomiaoce_t2_bb68_battery_level
      - sensor.miaomiaoce_t2_b828_battery_level
      - sensor.miaomiaoce_t2_8670_battery_level
      - sensor.thermometer_cabinet_battery
      - sensor.thermometer_living_room_battery
      - sensor.thermometer_bedroom_battery
    notify_device:
      - e6ff3cbbbd29a63aa7e9c3e7be3b9719
    notify_data: []
    custom_actions:
        metadata: {}
          config_entry_id: 01K3TJRA3TJEHA7B4K45A5VNJG
I dont know why you would have a problem with you exclude entities. I have not see anyone else with that problem. I tested it with all different variations, and never have an empty list
alias: Offline Devices Report
description: ""
use_blueprint:
  path: LTek/offline-devices-report-ltek.yaml
  input:
    time: "06:00:00"
    enable_persistent_notifications: true
    mobile_notification_services: notify.s23
    enable_mobile_notifications: false
    format_option: combined
    days_to_run:
      - sat
      - sun
    notify_device:
      - 4c405513584e73a3a8a3a9996bc35562
    display_options: both
    include_persistent_notification: enable_persistent_notification
    include_easy_notify: enable_easy_notify
    include_logbook_debug: enable_logbook_debug
    exclude_strings: |-
      shuffle
      repeat
      battery
      Battery
      disturb
      schedule
      indication
    include_custom_actions: disable_custom_actions
    weekday_options:
      - sat
    include_debug: debug_enabled
    debug_offline_delay:
      hours: 0
      minutes: 0
      seconds: 0
    include_button: disable_button_trigger
    exclude_entities:
      - binary_sensor.2nd_floor_smoke_and_co_alarm_carbon_monoxide_detected
      - sensor.node_44_battery_level
      - sensor.aeon_labs_dsc06_electric_kwh
I have this running and get an iOS notification but am not getting anything added
To my todo list.
This error is logged
logger:%20homeassistant.components.automation.offline_devices_report_with_notification_actions_2%0ASource%3A%20helpers/script.py:2070%0Aintegration:%20Automation%20(documentation,%20issues)%0AFirst%20occurred:%2006:26:44%20(2%20occurrences)%0ALast%20logged:%2006:26:44%0A%0A%E2%9B%94%20Offline%20Devices%20Report%20with%20Notification%20Actions:%20Choose%20at%20step%205:%20Auto-add%20to%20To-Do%20list%20when%20enabled:%20Error%20executing%20script.%20Invalid%20data%20for%20call_service%20at%20pos%201:%20not%20a%20valid%20value%20for%20dictionary%20value%20@%20data%5B'entity_id'%5D%0A%E2%9B%94%20Offline%20Devices%20Report%20with%20Notification%20Actions:%20Errorjj%20executing%20script.%20Invalid%20data%20for%20choose%20at%20pos%205:%20not%20a%20valid%20value%20for%20dictionary%20value%20@%20data%5B'entity_id'%5D%0A
I don’t think the todo list is setup correctly. I added the local todo list integration. Local to-do - Home Assistant
What did I do wrong?
fixed it. To-Do Lists are a only 255 characters so I now truncate the output to it works properly.
Hello, how i can see offline daschboard?
Please explain, I dont know what that is. This blueprint detects the entity domains listed in the first post.
Hi, could you please let me know where I can find the :loudspeaker: Persistent Web UI Notifications feature, specifically the dashboard notifications for offline devices?
Thanks in advance!
section labeled “Notification Settings”. There are a lot of options, browse all the sections, you might find some you want to use :slight_smile:
Hi @Ltek , congrats on this great blueprint.
I have noticed a bug though.
I have enabled both notification to my android app and a custom action that should notify using telegram bot.
I have also set “Enabled with No Issues confirmation” so I would only receive the notifications when there is a issue i suppose, but what happens in this case is:
  1. If there is no issues:
    I will get an android notification with only a single quote and nothing else. And I will receive a telegram message with the message “No offline devices detected.”
  2. If there are issues ( some device offline )
    I will get the correct notification in android but no telegram notification at all.
    It would also be nice if the android notification could be of BigText type so it could be expanded to show several lines.
Hope you can fix those.
Thanks!
“Enabled with No Issues confirmation” means you will always get a notification, even if there are ‘No Issues’
Not sure why the Android is not giving you the same text as the telegram. Please turn on Notification Setting >> Persistent UI Notifications (Enabled with No Issues) and lets see what that gives you.
I’ll look into that, never knew about it
@Ltek Persistent UI Notifications wont have any change in the behaviour.
I keep receiving a " in the app and a correct telegram when there is no offline devices. Check this image:
( Up telegram, down HA )
@jsalas try Version 2026.01.21.39c, I just uploaded.
@Ltek Where can I download it ? Cant find it.
Link button at the top, same as your initial install
@Ltek Working perfectly now. Thanks!
@Ltek btw, just to let you know , the report low battery blueprint faces the same problems.
same code base, I’ll fix that too… thank you for testing
