Onkyo Integration
Was working for me on 2023.10.3 and 2023.10.4. Try restarting HA to see if it works.
I just found out I have the same problem. Were you able to solve it?
Hey there, I was going to chime in to say that the onkyo integration broke for me with the latest update of Home Assistant, it seems that power cycling my AVR however, fixes the issue for me. Hope this helps!
I noticed that when the home assistant integration didn’t work, the Android app that allows you to do some things didn’t work either. It just couldn’t find the device, and when that happened, turning the power off to the amplifier and turning it back on again solved the problem. Maybe a network problem rather than a home assistant problem at least in my case.
Can this integration send Personal Preset/Quick settings to the receiver? My previous denon could with a webhook and I’m looking to replace it. example: http://192.168.1.30:8080/goform/formiPhoneAppDirect.xml?MSQUICK1
