I am trying to setup the new ONVIF integration in 0.110. I deleted my old camera config from config.yaml and added ffmpeg: the camera has username/password and onvif is enabled (works in Synology Surveillance station).
When I add the integration the camera is found but then I get “Could not configure unique ID for ONVIF device”.
Any luck? I’m getting the same message when adding the ONVIF integration. It sees the cameras but it either aborts or I get a Could not configure unique ID for ONVIF device message.
I have 3 onvif compatible cameras. All of them work (tested it using an iOS app). Two of my cameras are recognized by HA but one of them is throwing this error
This camera is not using a standard rtsp port (554) and the stream name/path is also a bit peculiar too. Any idea how one can further refine setup parameters?
