I can view Open Hardware Monitor from the host PC and from the browser at 192.168.1.xxx:8085 and from any other browser connected to my network. Tested it on my laptop and my phone, both work great. I’ve added the the address
I have added an inbound (and even outbound) firewall rule for all ports, ip addresses and protocols for this application but HA can not see it.
I can see the webpage or json data with a web browser on the machine Open Hardware Monitor is running on. I can’t see it on a remote machine (on the same network). I’m thinking it must be a firewall problem but this looks correct:
Has anyone had an issue where the openhardwaremonitor tables do not exist in the web page, but they do exist in the application? Its not a firewall issue because it is on the same machine. I have openhardware monitor installed on a few workstations without issues
I was having the same issue where the sensors became unavailable in HA
Tried the curl command and it did time out, went into openhardware and under options > remote web server - there is a run button, if it isn’t ticket then click it and the tick should then appear.
Guys i have just installed added ip adress to HASS but how can i now add it to the lovelace for monitoring, if i want to add as entity i can’t find any sensor or hardwaremonitor name to add it?
Hi, there is one more option that I have found. For future question :
Right Click the rule in Inbound Rules > Option > Advanced > Edge Traversal > Allow Edge Traversal
