Open Hardware Monitor not working
- platform: openhardwaremonitor
  host: 192.168.1.XXX
  host: 192.168.1.YYY
LE: no http://
So I added it with a disabled firewall and it isn’t working
    host: 192.168.1.202
Firewall off
Incoming and outgoing rules for port 8085 anyways
Server on
Port definably set to 8085
Ethernet Network set to private on machine with Openhardwaremonitor running on it
I got no idea why it isn’t working…
So theirs something broken with this integration…
I have the integration running without problems for some time.
Have you checked if you can access the api endpoint from another computer?
http://[IP address]:8085/data.json
I can definitely access it. From the machine running the docker imagine that home assistant is on.
{"id": 0, "Text": "Sensor", "Children": [{"id": 1, "Text": "I7SERVER", "Children": [{"id": 2, "Text": "Intel NUC6i7KYB", "Children": [{"id": 3, "Text": "Nuvoton NCT6776F", "Children": [{"id": 4, "Text": "Voltages", "Children": [{"id": 5, "Text": "CPU VCore", "Children": [], "Min": "0.680 V", "Value": "0.712 V", "Max": "1.000 V", "ImageURL": "images/transparent.png"}, {"id": 6, "Text": "Voltage #2", "Children": [], "Min": "1.216 V", "Value": "1.232 V", "Max": "1.240 V", "ImageURL": "images/transparent.png"}, {"id": 7, "Text": "AVCC", "Children": [], "Min": "3.312 V", "Value": "3.328 V", "Max": "3.344 V", "ImageURL": "images/transparent.png"}, {"id": 8, "Text": "3VCC", "Children": [], "Min": "3.296 V", "Value": "3.328 V", "Max": "3.328 V", "ImageURL": "images/transparent.png"}, {"id": 9, "Text": "Voltage #5", "Children": [], "Min": "0.936 V", "Value": "0.944 V", "Max": "0.952 V", "ImageURL": "images/transparent.png"}, {"id": 10, "Text": "Voltage #7", "Children": [], "Min": "0.456 V", "Value": "0.600 V", "Max": "0.664 V", "ImageURL": "images/transparent.png"}, {"id": 11, "Text": "3VSB", "Children": [], "Min": "3.264 V", "Value": "3.280 V", "Max": "3.296 V", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/voltage.png"}, {"id": 12, "Text": "Temperatures", "Children": [{"id": 13, "Text": "CPU Core", "Children": [], "Min": "39.5 °C", "Value": "45.0 °C", "Max": "68.5 °C", "ImageURL": "images/transparent.png"}, {"id": 14, "Text": "Temperature #1", "Children": [], "Min": "37.0 °C", "Value": "41.0 °C", "Max": "48.5 °C", "ImageURL": "images/transparent.png"}, {"id": 15, "Text": "Temperature #2", "Children": [], "Min": "45.0 °C", "Value": "50.0 °C", "Max": "61.5 °C", "ImageURL": "images/transparent.png"}, {"id": 16, "Text": "Temperature #3", "Children": [], "Min": "62.5 °C", "Value": "64.5 °C", "Max": "66.0 °C", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/temperature.png"}, {"id": 17, "Text": "Fans", "Children": [{"id": 18, "Text": "Fan #2", "Children": [], "Min": "2727 RPM", "Value": "2812 RPM", "Max": "3006 RPM", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/fan.png"}, {"id": 19, "Text": "Controls", "Children": [{"id": 20, "Text": "Fan Control #1", "Children": [], "Min": "49.8 %", "Value": "49.8 %", "Max": "49.8 %", "ImageURL": "images/transparent.png"}, {"id": 21, "Text": "Fan Control #2", "Children": [], "Min": "27.5 %", "Value": "27.5 %", "Max": "29.8 %", "ImageURL": "images/transparent.png"}, {"id": 22, "Text": "Fan Control #3", "Children": [], "Min": "100.0 %", "Value": "100.0 %", "Max": "100.0 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/control.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/chip.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/mainboard.png"}, {"id": 23, "Text": "Intel Core i7-6770HQ", "Children": [{"id": 24, "Text": "Clocks", "Children": [{"id": 25, "Text": "Bus Speed", "Children": [], "Min": "99.7 MHz", "Value": "99.7 MHz", "Max": "99.7 MHz", "ImageURL": "images/transparent.png"}, {"id": 26, "Text": "CPU Core #1", "Children": [], "Min": "797.5 MHz", "Value": "897.2 MHz", "Max": "2592.2 MHz", "ImageURL": "images/transparent.png"}, {"id": 27, "Text": "CPU Core #2", "Children": [], "Min": "797.5 MHz", "Value": "897.2 MHz", "Max": "2592.2 MHz", "ImageURL": "images/transparent.png"}, {"id": 28, "Text": "CPU Core #3", "Children": [], "Min": "797.5 MHz", "Value": "1296.0 MHz", "Max": "2592.2 MHz", "ImageURL": "images/transparent.png"}, {"id": 29, "Text": "CPU Core #4", "Children": [], "Min": "797.5 MHz", "Value": "1694.8 MHz", "Max": "2592.2 MHz", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/clock.png"}, {"id": 30, "Text": "Temperatures", "Children": [{"id": 31, "Text": "CPU Core #1", "Children": [], "Min": "37.0 °C", "Value": "42.0 °C", "Max": "67.0 °C", "ImageURL": "images/transparent.png"}, {"id": 32, "Text": "CPU Core #2", "Children": [], "Min": "38.0 °C", "Value": "44.0 °C", "Max": "69.0 °C", "ImageURL": "images/transparent.png"}, {"id": 33, "Text": "CPU Core #3", "Children": [], "Min": "37.0 °C", "Value": "43.0 °C", "Max": "68.0 °C", "ImageURL": "images/transparent.png"}, {"id": 34, "Text": "CPU Core #4", "Children": [], "Min": "35.0 °C", "Value": "41.0 °C", "Max": "66.0 °C", "ImageURL": "images/transparent.png"}, {"id": 35, "Text": "CPU Package", "Children": [], "Min": "39.0 °C", "Value": "45.0 °C", "Max": "69.0 °C", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/temperature.png"}, {"id": 36, "Text": "Load", "Children": [{"id": 37, "Text": "CPU Total", "Children": [], "Min": "0.4 %", "Value": "16.2 %", "Max": "100.0 %", "ImageURL": "images/transparent.png"}, {"id": 38, "Text": "CPU Core #1", "Children": [], "Min": "0.0 %", "Value": "19.5 %", "Max": "100.0 %", "ImageURL": "images/transparent.png"}, {"id": 39, "Text": "CPU Core #2", "Children": [], "Min": "0.8 %", "Value": "14.8 %", "Max": "100.0 %", "ImageURL": "images/transparent.png"}, {"id": 40, "Text": "CPU Core #3", "Children": [], "Min": "0.0 %", "Value": "17.2 %", "Max": "100.0 %", "ImageURL": "images/transparent.png"}, {"id": 41, "Text": "CPU Core #4", "Children": [], "Min": "0.0 %", "Value": "13.3 %", "Max": "100.0 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}, {"id": 42, "Text": "Powers", "Children": [{"id": 43, "Text": "CPU Package", "Children": [], "Min": "3.2 W", "Value": "8.7 W", "Max": "28.2 W", "ImageURL": "images/transparent.png"}, {"id": 44, "Text": "CPU Cores", "Children": [], "Min": "0.5 W", "Value": "2.8 W", "Max": "20.7 W", "ImageURL": "images/transparent.png"}, {"id": 45, "Text": "CPU Graphics", "Children": [], "Min": "0.0 W", "Value": "0.5 W", "Max": "3.2 W", "ImageURL": "images/transparent.png"}, {"id": 46, "Text": "CPU DRAM", "Children": [], "Min": "0.7 W", "Value": "0.7 W", "Max": "1.5 W", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/power.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/cpu.png"}, {"id": 47, "Text": "Generic Memory", "Children": [{"id": 48, "Text": "Load", "Children": [{"id": 49, "Text": "Memory", "Children": [], "Min": "21.4 %", "Value": "34.8 %", "Max": "38.6 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}, {"id": 50, "Text": "Data", "Children": [{"id": 51, "Text": "Used Memory", "Children": [], "Min": "5.1 GB", "Value": "8.3 GB", "Max": "9.2 GB", "ImageURL": "images/transparent.png"}, {"id": 52, "Text": "Available Memory", "Children": [], "Min": "14.7 GB", "Value": "15.6 GB", "Max": "18.8 GB", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/power.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/ram.png"}, {"id": 53, "Text": "PLEXTOR PX-256M8VG", "Children": [{"id": 54, "Text": "Load", "Children": [{"id": 55, "Text": "Used Space", "Children": [], "Min": "84.2 %", "Value": "85.1 %", "Max": "85.8 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}, {"id": 56, "Text": "Data", "Children": [{"id": 57, "Text": "Host Writes", "Children": [], "Min": "23833.0 GB", "Value": "23889.0 GB", "Max": "23889.0 GB", "ImageURL": "images/transparent.png"}, {"id": 58, "Text": "Host Reads", "Children": [], "Min": "52553.4 GB", "Value": "52642.3 GB", "Max": "52642.3 GB", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/power.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/hdd.png"}, {"id": 59, "Text": "Generic Hard Disk1", "Children": [{"id": 60, "Text": "Load", "Children": [{"id": 61, "Text": "Used Space", "Children": [], "Min": "78.2 %", "Value": "78.2 %", "Max": "78.3 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/hdd.png"}, {"id": 62, "Text": "Generic Hard Disk 2", "Children": [{"id": 63, "Text": "Load", "Children": [{"id": 64, "Text": "Used Space", "Children": [], "Min": "99.4 %", "Value": "99.8 %", "Max": "99.9 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/hdd.png"}, {"id": 65, "Text": "Generic Hard Disk 3", "Children": [{"id": 66, "Text": "Load", "Children": [{"id": 67, "Text": "Used Space", "Children": [], "Min": "28.8 %", "Value": "28.8 %", "Max": "28.8 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/hdd.png"}, {"id": 68, "Text": "Generic Hard Disk 4", "Children": [{"id": 69, "Text": "Load", "Children": [{"id": 70, "Text": "Used Space", "Children": [], "Min": "50.2 %", "Value": "50.2 %", "Max": "50.2 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/hdd.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/computer.png"}], "Min": "Min", "Value": "Value", "Max": "Max", "ImageURL": ""}
There’s no integration listed called open hardware monitor. Theirs no device called i7server.
Can you post your entry into the config file? Because mine, it should be working. And isn’t.
    host: 192.168.2.81
    port: 8580
I have defined the rule in the windows firewall for private and public connections.
Also note that the entities in HA are called after the name of your computer.
so the network has an exception for the app. an exception for the port inbound and outobund. tried changing the ports. idk man. how to i look to see if the home assistant even understands that i tried to setup openhardware monitor in logs or whatever? seems like something is wrong.
Change the log level for the integration and look if something comes up when rebooting HA:
    homeassistant.components.openhardwaremonitor: debug
How do I change the log level?
And how do I search the logs instead of just looking through in config, then logs? Because I can’t search for specific things like “Openhardwaremonitor”
so i added
to the open hardware monitor line after port and i dont see anything in logs that says openhardwaremonitor
There is a service for changing the loglevel:
service: logger.set_level
Or you can add the part to the logger configuration when you want to see the logs when HA is starting.
logger:
  logs:
I added it and Openhardwaremonitor isn’t even mentioned.
Do I need to install it?
Nothing to install
my configuration.yaml entry:
  • platform: openhardwaremonitor
    host: 192.168.0.64
there will be no device in list just entities:
click on one
This entity (“sensor.alex_pc_amd_radeon_rx_5700_xt_fans_gpu_fan”) does not have a unique ID, therefore its settings cannot be managed from the UI
but all entities are in list of entities
I cannot find anything in entities. Like not there.
Manually looked through everything. I searched for it by the name of the computer from /data.json on the server. “I7SERVER” tried searching CPU gps drive, manually looked through everything. Nothing is in logs. Been trying to get this to work for over a month now…
Open local open hardware monitor server page on your local computer (web server should be running in OHM)
In my case
http://192.168.0.64:8085/
Is the page loading with all sensors or is empty?
If its blank, you should check that no sensor has a " or ’ in name, that will break json file; i had one SSD with that and i just renamed it in main OHM interface
After that it worked ok
