I have added an inbound (and even outbound) firewall rule for all ports, ip addresses and protocols for this application but HA can not see it.
I can see the webpage or json data with a web browser on the machine Open Hardware Monitor is running on. I can’t see it on a remote machine (on the same network). I’m thinking it must be a firewall problem but this looks correct:
Has anyone had an issue where the openhardwaremonitor tables do not exist in the web page, but they do exist in the application? Its not a firewall issue because it is on the same machine. I have openhardware monitor installed on a few workstations without issues
I was having the same issue where the sensors became unavailable in HA
Tried the curl command and it did time out, went into openhardware and under options > remote web server - there is a run button, if it isn’t ticket then click it and the tick should then appear.
Guys i have just installed added ip adress to HASS but how can i now add it to the lovelace for monitoring, if i want to add as entity i can’t find any sensor or hardwaremonitor name to add it?
Hi, there is one more option that I have found. For future question :
Right Click the rule in Inbound Rules > Option > Advanced > Edge Traversal > Allow Edge Traversal
Firewall off
Incoming and outgoing rules for port 8085 anyways
Server on
Port definably set to 8085
Ethernet Network set to private on machine with Openhardwaremonitor running on it
I got no idea why it isn’t working…
